Making this mouse is very easy: a light sensor detects the shadow of hand on the mouse and activates a timer that turns on a motor for about a second and the motor makes mouse running.
If you want to make your own mouse read the rest of this instructable.
Remove these ads by
Signing UpStep 1Things You Need
-Copper Boards
-Printed Circuit (Find files on next step)
-Photocell
-22k Resistor
-47uF Electrolyte Capacitor
-TIP122 Transistor
-555 IC
-10k Potentiometer
-Some Wire
-Iron
-Soldering Iron
-Soldering Wire
-Circuit Boards Acid
-Paper Tape
-Sandpaper
-Wire Cutter
-1mm Drill
To make the mouse you need the followings:
-Old Computer Mouse
-Small Motor
-4 AA Batteries
-A piece of Rubber Tube
-Glue
-1N4148 Diode
-0.1uF Ceramic Capacitor (104)
-Soldering Iron
-Soldering Wire
-Some Wire
-Some Tools
anyways, if you want to power it with just the computer, it CAN be done ;)
I have a USB REAL mouse, so it would make sense for me to make the mouse that way I think.
I used one simple photocell, it is not IR.
Only way it would get any better is with a loud "squeak" recording and if it acclerated faster, so it just LEAPS away from the person's hand. Hmmmm my engineering prof. always leaves his door wide open when he is away.....
If you want longer battery life, try the new CSS555 micropower timer. It is pin compatible with the venerable 555's, but uses far less power.
555 IC works correctly with 9V battery.
But you may need to optimize potentiometer value. (see the last step)
"EEK!" *scurry away*
nice you need to make it usb powered
you should find a faster motor... it only works on absent-minded people.
Thanks for sharing!!!
