3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Creamy One Minute Eggnog
Nothing goes better with the upcoming holiday season like a glass of creamy eggnog. And nothing is better than a glass of creamy homemade eggnog. Here's how to whip up a glass of your own - and fast.
Step 1Gather the necessary ingredients.
This recipe is for one generous serving of eggnog. It can easily be multiplied to serve several people, without adjusting quantities. I have had success with up to a dozen servings at once, to fill a large punch bowl.
You'll need:
- 1 cup milk
- 1 large egg
- 1 tbsp. sugar
- 1/4 tsp. vanilla
- grated nutmeg, to taste
- 1 oz. alcohol of choice*, for the adult version
* Good choices include, but are not limited to: Brandy, Rum, Spiced Rum, Amaretto, Amaretto Cream, Irish Cream, etc, etc...
47 comments
1-40 of 47next »
Jan 1, 2012. 4:50 PMAswa says:
This recipe is awesome. Very simple, straight forward, and for once it’s not a recipe for a huge party! :D
I have made this a few times now, and I love it, because I’m not a big fan of the really fluffy eggnog, for which I found lots of recipes.
Also, these are ingredients I always have on hand, and it only takes a minute or two to whip it all together.
Oh, I always wash eggs really hot and with soap before I crack them, if I plan to ingest them raw.
Sep 17, 2011. 7:01 AMtinker234 says:
hey could i heat this in a microwave for 30 seconds for a warm cup of eggnog
Dec 1, 2009. 3:14 PMSeleziona says:
wouldn't you risk getting food poisoning from the uncooked egg? Just wonderin' because i wanna make it!!!!!
Aug 19, 2010. 12:29 PMxXInmateXx says:
No, u can get sick if the egg touches the shell. That is the only bit that can give u salmanila. So don't worry.
Dec 22, 2009. 2:44 PMJavin007 says:
The whole "uncooked egg" scare is almost such as minor issue as to be considered "mythical."
According to the FDA, approximately 1 in 60,000 (uncracked) eggs have an imperfection AND exposure to allow them to become infected with Salmonella.
To put this into perspective, if you ate a raw egg every day of your life, the average person could live for more than 164 years and only encounter one "bad" egg.
For the vast majority of people, the Salmonella is nearly harmless, though a good enough dose of it will give you the runs.  For the immune compromised (babies, elderly, people with immune deficiencies, etc.) it becomes considerably more dangerous, and potentially deadly (though it responds quite readily to antibiotics).
For the average person, even eating the 1 in 60,000 egg that IS infected will go unnoticed (unless the egg is particularly rotten, in which case, why are you eating it anyway?!)
The stringent laws passed regarding eggs and infection are actually due to food service businesses.  These businesses would mix their ingredients in massive batches.  It only takes 1 egg out of 60,000 to infect ALL the eggs in a batch, so you can see where this is going.  Suddenly your entire batch of goods goes out and people who ARE immune compromised are no longer safe.
I've eaten raw eggs my whole life (never let an egg yolk go into the garbage!).  While I don't want to know what my cholesterol levels look like, I can assure you that I'm still alive, though I'm still not 164 years old, yet.
Raw eggs are fantastic in a huge number of cooking uses.  The yolks alone have incredible flavor, and the whites are used for a huge number of dishes.
As with many of the governmental germ scares (salmonella, mono, west nile, bird flu, swine flu, etc. etc. etc.) you can pretty much ignore them.  99 times out of 100 they're little more than someone trying to justify the reason they get a paycheck from the taxpayer.
Dec 22, 2009. 4:44 PMSeleziona says:
thanks for all that info!
Dec 22, 2009. 8:41 PMJavin007 says:
Wow, can't believe I didn't mention this... Any bacteria (including salmonella) produces "off gassing" when it multiplies.  It's VERY easy to see if you have a "bad" egg.  Drop it in a cup of water.  Eggs, like everything, are primarily water.  However, they do have an "air pocket" in them that the growing chicks breathe through.  However, the heavy calcium base of the shell keeps the egg JUST heavier than water, allowing the egg to sink.
If your egg is infected (ie: bad) it's very easy to tell.  Dropping it in a cup of water, a "bad" egg will float to the top, as the gasses given off by the bacteria will offset the balance in the egg.  Those that "try" to float are STILL good to eat (by any FDA standards) though, personally, I'd avoid eating them raw.  Those that stand on-end or even settle to the bottom are completely fine.  There's either NO bacteria in them, or not enough to be an issue.
Finally, eggs are designed (by nature) to prevent bacteria from entering the egg itself (I mean, let's face it, they come from a chicken's pooper.  They don't have separate orifices. )  It really does take an extreme situation to get a "bad egg."
There's many other foodstuffs that are similar.  Raw meat, for example got its bad name from ground beef.  Freshly butchered beef/fish could easily be eaten raw unless it was VERY poorly butchered, and even then, a medium rare steak would kill any bacteria on the surface of the meat.  The meat itself would resist "deeper" growth of the bacteria allowing even minor cooking to kill it off.  Again, by the point that it gets "deep" enough to be of danger, you shouldn't be eating it anyway because the smell would make it obvious (to an extent... look up "dry aged" beef to see how NORMAL bacteria eating at the meat actually makes it BETTER!).
The big scare with infected meat is SOLELY because of ground beef.  You grind up the beef, grinding any infectants INTO the beef and giving it PLENTY of surface area to attach to.  Unless you grind your own beef, a medium rare burger can be a bad night.  (Again, squirts at the worst.)
Okay, need to step off my anti-fear-mongering.
ENJOY your food!  Your immune system was BUILT to let you!
Sep 17, 2011. 6:57 AMtinker234 says:
thanks for the info about to make some eggnog
Dec 23, 2009. 6:11 AMSeleziona says:
WOW!
Dec 22, 2009. 8:28 PMJavin007 says:
*heh heh*  Sorry.  After doing medical research / food inspection with the Army for a few years, you tend to get a little jaded when it comes to food scares.  I learned that SO MANY of my fears about foods that had been pushed out by the government that had kept me from trying new foods were so ridiculously "out there" that I'd really been missing out.  I tend to be a bit over excitable about this particular subject.  I like food.  :D
E. Coli, Salmonella, staph, all of the buzzwords are, for the most part, utterly harmless.  Worse case scenario, you get the squirts.  (Though, to be fair, there are SOME (rare) antibiotic-resistant strains of staph that deserve true fear.)
Should we really avoid experiencing some of the best flavors in the world so as to resist a 1 in 60,000 chance of getting the runs?  I would argue: no.  Not to mention that the more we avoid any minor germ, the weaker our immune systems get... But now it's time to me to step off my soapbox...
Dec 23, 2009. 6:12 AMSeleziona says:
You type a lot!
Dec 23, 2009. 7:44 AMJavin007 says:
LMAO!  Sorry...
Dec 23, 2009. 5:52 PMSeleziona says:
You forgot the F! lolz
Why are you sorry?
Jan 9, 2010. 2:41 PMNoFiller says:
I love how easy this is. I'm never buying eggnog again.
I have made this both with real eggs and fake pasteurized eggs. I wanted to make this for a party and knew some of the people wouldn't try it if they knew there was raw egg in it, so I bought pasteurized eggs that come in a carton. Unfortunately all they had were "80% reduced cholesterol made with real egg whites" eggs. The eggnog made with this turned out alright, but only foamed up about half as much as it did with real eggs. Even though it didn't taste as good, I think the people who hadn't already had it with real eggs though it was good.
Dec 23, 2009. 7:19 AMXamith says:
 This is great stuff, even though i didn't have any vanilla and nutmeg to put in it.
Dec 5, 2009. 9:50 PMfinfan7 says:
Technically you should heat it just to the lowest slowest boil to ensure complete mixing, some thickening, and basic cooking.  It will turn out even better.
Dec 5, 2009. 8:13 AMTim Temple says:
Wait a minute ... where's the EDTA, the carageenan gum and  the bisphenols that were in my momma's eggnog?
Dec 5, 2009. 12:25 AMkronflux says:
I think I might make this right now, but I'm a walking murphy's law so I'm going to have to add rum or cook the egg. one or the other, unfortunately.
but I'm craving eggnog quite badly right now! thanks for the recipe!
Nov 24, 2009. 6:21 PMWasagi says:
 I'm off to make this now! Great instructions+incredibly simple=Ingenious! Great Job!
Nov 24, 2009. 7:15 PMWasagi says:
 Ok, I finished making it, so here's a Picture, I wanted t ot take a picture of the full glass, but that turned out to be impossible...
All I can say, Delicious!!
Nov 29, 2009. 3:58 PMWasagi says:
 I've made a few batches, I I think that I'm getting better with practice,
Whoops, I forgot the picture from earlier, sorry.
Nov 28, 2009. 4:56 PMquesoman says:
I am so glad i have found this recipe because now i dont have to wait till the holiday season to drink nog! thank you very much. my cat and i are going down stairs to do this now.
Nov 26, 2009. 11:05 AMApplejacks says:
Props to you, skyisblu. I managed this with a manual hand whisk and it turned out passably creamy.
Nov 25, 2009. 3:36 PMGarmann says:
This is easy to make and better than the commercial eggnog. I used skim milk (all I had on hand) and it turned out very well. Made one with rum and one with brandy. I like them both.
Nov 25, 2009. 1:13 PM__Master_ says:
thanks so much i love it
Nov 23, 2009. 7:45 PMArbitror says:
I just tried this, and it tastes just like the commercial thing! Great job! Rated *****!
Nov 23, 2009. 7:29 PMArcticChill says:
I can't wait to try this. My brother absolutely loves the nog, but never visits. But now we have a little bribe to convince him to come over.
Thanks!
Nov 23, 2009. 4:43 PMGravity Boy says:
I would make this recipe for breakfast before going to school when I was a teenager, I have to say that I cannot stand the pre-made stuff, it is too thick and sweet; and I love sweets.
Note: If you want it hot, you will have to use a double-cooker (water bath) to bring the nog to tempt, then add the spiced rum for a good drink.
temp -> do not know where that t came from
Nov 23, 2009. 3:34 PM2muchfreetime8 says:
looks very nice. does it have to be spiked though?
Nov 23, 2009. 4:12 PMItsTheHobbs says:
The eggs could have salmonella. The alcohol sterilizes them. I'm pretty sure that if you use egg substitute you'll be fine without it.
Jan 19, 2010. 12:45 AMsrwoodruff says:
Sounds like an excuse to use alcohol... works for me!
Nov 29, 2009. 4:37 PMexplosivemaker says:
...that sounds like a better idea....
Nov 23, 2009. 4:25 PMjonathan95123 says:
Ehhh. I did it, but it tasted more like a milkshake than eggnog.
Nov 23, 2009. 3:19 PMkillerjackalope says:
I'm definitely going to play around with the idea of eggnog, nobody does it here and I like the sound of it.
Nov 23, 2009. 7:53 AMandycyca says:
Here's the thing: I'm 22, home alone and I have everything desrcribed here... Thanks for sharing!
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
45
Author:skyisblu
