loading
This will show you how to create a cmd messenger so you can send pop-up messages to otherpeople.
And after you are finish you can now send msgs to your self. NOTE: must enable it on other pcs to make it send msgs to the other pc.
Step 1: Create It!
after watching this video goto "Step 2"
Step 2: Enable The Messenger
Goto: Start>Control Panel>Administrative Tools>Services
Find Messenger. Double click on it.
Then the rest of the steps are below on the picture.
<em>Please </em>get rid of that <strong>evil </strong>video! Just add the text. I am on a blocked computer (curses to the guy who invented family saftey) and cannot view the video! No offense.
<p>Same Here</p>
this is very nice!!!!!!!!!!!
@ atomicpowerplant<br><br>@echo off<br>:A<br>cls<br>echo LAN Messenger<br>echo.<br>echo 1) Send message<br>echo 2) Quit<br>echo.<br>set /p menu=&quot;Option:&quot;<br>if %menu%==1 goto :B<br>if %menu%==2 goto EXIT<br>cls<br>echo LAN Messenger<br>echo.<br>echo The command entered is not a valid command. Please try again.<br>echo.<br>pause<br>goto :A<br><br>:B<br>sc config Messenger start= auto<br>sc start Messenger<br>cls<br>echo LAN Messenger<br>echo.<br>set /p target=Target IP Address:<br>set /p body=Message:<br>net send %send% %body%<br>cls<br>echo.<br>echo Your message has been sent.<br>echo.<br>pause<br>goto :A
hey do you know of a way to ping a list of web sites using a bat file pre programes with the web sites to ping and get it to creat a log file with the ping time info on it<br>
how to do it on windows 7? <br>
This will not work on Windows 7, Vista, ME, 95, 98<br>the net send command isn't supported by that version
hi, thanks for your instruct. I followed what you show, Start&gt;Control Panel&gt;Administrative Tools&gt;Services, but i cannot find Messenger. im currently using window 7. can u help me to figure it out.
@echo off <br>:A <br>Cls <br>echo MESSENGER <br>set /p n=User: <br>set /p m=Message: <br>net send %n% %m% <br>Pause <br>Goto A <br> <br> <br>your welcome :D
@echo off <br>:A <br>Cls <br>echo MESSENGER <br>set /p n=User: <br>set /p m=Message: <br>msg send %n% %m% <br>Pause <br>Goto A <br> <br>if u gots vista <br>
i got it but it said that the syntax of the command was and then it said NET with a list of things then it said hit any key to continue
If you are using Vista or Windows 7, the syntax for the network messaging command has changed. Instead of: net send [IP address] [&quot;message&quot;] Vista and windows 7 use 'msg' so change the line to: msg %n% %M% and that should work
hi
I just hate it when people say they put a video and just put a blank screen!
it isnt blank.
but i can watch it....................
yes it is...
Of course it doesn't work!<br/>the variable &quot;M&quot; and &quot;m&quot; ore two different things<br/>the right code should be:<br/><br/>@echo off<br/>:a<br/>echo messenger<br/>set /p n=user/IP:<br/>set /p M=Message:<br/>net send %n% %M%<br/>pause<br/>goto a<br/>
i want to use this at college but with the computers we have there all got the rights taken away so cant use much but will we still be able to use this without changing anything ?
nice but i wish you would have put the script in the instructable too instead of just the video.
does this work with vista, cuz i cant find messenger in the services menu.......
whoz IP do I enter mine or the person I wanna talk to?
please help it says that (a general network error occurred) wats dat? do i need to copy a script too to the another computer whom i want to send a msg? help
yes
Hi, are you sure that this program goes?? because I prove it, and it didn't go. It made me an error.
how do u start it?
@echo off<br/>:a<br/>echo messenger<br/>set /p n=user/IP:<br/>set /p M=Message:<br/>net send %n% %m%<br/>pause<br/>goto a<br/>
i cant watch the video
Quick question, can you do this over the Internet?
me too
Please read my earlier note. Video is great, but it doesn't replace written, step-by-step, instructions. Multiple attempts to republish, without correction, will result in project deletion.
Please include all of the instructions in your video as written, step by step, instructions with images. For now, I am unpublishing this - but please feel free to republish once you've made these corrections.
About This Instructable
59,203views
20favorites
License:
More by surffinn:Create A CMD Messenger Softmod Your Xbox (play games without disk) **UPDATED**
Add instructable to:
