Create Cheap homemade Modge Podge!
 by nkeda14
Run out of modge podge? Don't want to spend the money to get a bottle from the craft store? Use stuff around your kitchen to make your own! Make it as thick or watery as you'd like with the added advantage of deciding how much varnish you want.
Step 1: Gather it
You will need the following to make your own modge Podge:
1. Stove
2. Sauce Pan
3. 1 1/2 cups Flour
4. 1/4 of a cup of granula sugar
5.1/4 tsp oil (Veggie or olive)
6. Spoon
7. Mason Jar or air tight container
8. 1 cupWater
Step 2: Mix it
Take the Saucepan and put it on Medium to Low heat on the stove top (3 or 4)
add the 1 and 1/2 cups flour 1/4 a cup of sugar, 1 cup water, and 1/4 a tsp oil.
You should add flour and water until you get your desired consistancy as these measurements are just ideas of what you may want.
If you'd like a higher varnish you should add more oil.
Step 3: Stir it
Stir up all your ingredients over medium to low heat ( depending on how hot your stove top gets) for 5 to 10 minutes but make sure NOT TO BOIL  the mixture.
Stir constatnly until well mixed
Step 4: Store it
Take your Mason jar or other air tight container and pour the mixture in, let it cool to room temperature and seal.
tgonzalez11 says: Feb 22, 2013. 1:55 AM
All of these homemade Mod Podge recipes are inferior to the real product since they eventually turn yellow. Mod Podge does not yellow.
tgonzalez11 says: Feb 22, 2013. 1:53 AM
It's "Mod Podge", not "Modge Podge"..
jirfan says: Jan 28, 2013. 11:42 PM
i tried this recipe it was veeery thick didnt work!
PaganRaven says: Jun 27, 2012. 7:06 PM
The actual Mod Podge is not a true varnish. You will need to seal whatever you are making with a non-waterbased varnish, if there is a chance of your project coming in contact with water.
Also, there is no Mod Podge product that is 100% waterproof.
Meaning, you can't use this or the actual mod podge to make dishes, bowls..anything you would be putting drink or food in.
But! This mix and 'podge can be used for tons of things -- including furniture and walls.
lshiny in reply to PaganRavenAug 16, 2012. 12:52 AM
I haven't used anything other than Mod Podge. What do you recommend as a non-waterbased varnish?
life_uncommon101 says: Apr 9, 2011. 8:58 PM
I was wondering about the sugar that is added to this recipe. Will it attract bugs? What properties doe the sugar give the finished product?
Thank you!
-J
lshiny in reply to life_uncommon101Aug 16, 2012. 12:50 AM
I was wondering about this myself, did you find an answer elsewhere?
amelia123 says: May 3, 2012. 4:34 AM
hi there iv'e just joined the site, i was wondering if you could use your own home made modge podge to stick paper to ceral boxes, and thankyou for showing us how to make our own, Amelia x
steelnix says: Mar 7, 2012. 11:15 AM
Can this be used on a jigsaw puzzle???
mimthing in reply to steelnixApr 14, 2012. 2:24 PM
Yes but you would need to use a varnish finish as this will probably take in moisture.
atrumbell says: Nov 12, 2011. 8:29 PM
one part flour to two parts water works wonderful for paper sculpting. i tear news paper and old books and cover random things using this recipe. you can also add more white glue, as well if you need it "stickier" for yor project. try adding a little cinnamon or coffee ground for a cool effect. Many a homemaker wallpapered her walls with this whitewash method....happy crafting
taluntain says: Nov 8, 2011. 10:23 PM
does anyone know the drying times for this yet????????? please reply quickly
eogle1 says: Oct 22, 2011. 3:52 PM
So I definitely just made it but the consistency is very very thick. After adding water consistently, it just wouldn't liquify! Letting it cool now. Hopefully it will be more like a liquid, and less like a bread after a while.
jwalker37 in reply to eogle1Nov 7, 2011. 1:55 PM
Eogle,
To thin the consistency, I replaced the oil with 1/2 Tbs of Vinegar.
It works just perfectly! =D
gemgh says: Jul 1, 2011. 3:06 PM
Has anyone ever used this recipe for glass? I found a glass site that had mod podge used in the formula and it is suppose to work on fabric and glass.
Thanks bunches,
Glenda
theartisticpixie says: Dec 21, 2010. 12:30 AM
Just made this, and Im going to use it to decorate some boring pencils for school
Im not sure about the consistency though.
cokecola says: Dec 4, 2010. 1:08 AM
alexsolex you must young enough that you didn't experience the decoupage fad of the 70's. Mod Podge is for decoupage, it is a varnish / glue.
alexsolex in reply to cokecolaDec 4, 2010. 12:46 PM
sorry for that but I'm French.
Concidering your explanations, I think I have an idea of what it is. I think it is like the glue used to stick wood with wood.
If not, I never used it at school, but while travelling in australia. We used such a thing, a milky thing that becomes transparent, used to varnish the didgeridoo we made.
dchall8 says: Dec 4, 2010. 12:11 PM
This is a recipe for paper mâché paste.  Besides this stuff, I have also used white glue when I could not find Mod Podge.  After using both Mod Podge and white glue, I think they are the same adhesive in different containers.
Mod Podge is not a varnish but it is used like one.  I suppose you could call it a water based varnish.  It goes on milky and dries clear.  I never tried more than one coat to know whether it can build up thickness and still look okay.  One issue with it is that it will become cloudy if it gets wet.  As I recall it will dry out and become clear again.
alexsolex says: Dec 4, 2010. 12:11 AM
hello
what is mod podge ?
nkeda14 (author) in reply to alexsolexDec 4, 2010. 10:34 AM
Its like decopodge. You use it to layer items onto paper or other surfaces like wood. Its really fun to use in colleges in water color sketchbooks and such.
cokecola says: Dec 4, 2010. 1:10 AM
Does it make a nice thick clear covering?
nkeda14 (author) in reply to cokecolaDec 4, 2010. 10:30 AM
Yeah it turns out looking like a pale cream color but it dries clear.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
