In this instructable, I'll show you how to create your own fluorescent compounds out of something you probably already have in your home.
Remove these ads by
Signing UpStep 1Gather Your Items
Grab some highlighters from your desk, bureau, backpack, friend's locker, mom's credenza...you know, wherever. They're lying all about if you really look for them, those unassuming little pearls hiding right in front of our piggish noses. You can use the big fat ones or the slimmer bic-type highlighters, depending on how much fluorescent solution you want to make. The slim versions are fine to make about 150mL to 200mL, depending on how much highlighter fluid is in the highlighter pen. The fat highlighters can make upwards of 500mL of fluorescent solution.
Now, go get 'em!
thanks
You might have better luck looking for a UV fluorescent tube. Use with caution!
Good luck!
There are several places out on the Intertubes where you can get these little bottles (called "scintillation vials") but here's a link from a science project supply store that has several types of bottles that could potentially be used.
http://www.sciplus.com/category.cfm/subsection/7
Good luck!
Good luck!
I am trying to dye the tube now with foresent dye. Alot of people online say to use 10% acetone to 40%water and remainder dye suspanded in water. So far the tube went from transparent to opaque and from clear to pinkish. I wonder if its cause the acetone is sperating the foresents from the dye and attatching to the tube.
i will try it for my cyber masks
greets
Off so it sticks in the cracks and crevices. But I already ground the paint off so i need to paint it. I'm gonna paint the body copper and the spoon brass. I'm using a mini tobasco bottle for the bulb (you get them in MRE's. I don't think their available in any other country but I'm 14 so I wouldn't know.I fill that with the Fliourescent dye and epoxy that into the hole that came drilled in the bottom of the grenade after adding the circutry. And that consists of A UV led and a pressure swith that once pressure is releived, it completes the circuit. I'd put the switch by the spoon so once i let it fly, the uv led lights up the dye. Pretty simple I guess.
-gian
p.s. those mini-Tabasco bottles used to sell for hard cash in the field among US Marines. Anything to cover the taste of MRE's after months of eating them is worth gold. :)
