Create Objective Type Questions in Excel
45,742
26
33
Posted in HomeEducation
Introduction: Create Objective Type Questions in Excel
About: I am a hobist with lots of hobies from carpentry to mechanics. There is hardly any thing that i am not interested in.
I used this kind of question paper to create sample questions for ISTQB sample papers for the candidates to test their aptitude. The same template can be used to make many other question papers in the same way. You just have to use the same template and add your own set of questions. The questions are objective type with 4 options. I got the idea from Kaun banega carorepati (an Indian version of Who wants to be a millionaire)
Step 1: Creating the Worksheets
Open Excel. Make sure you save the file as .xls (office 2003 format) as in the office 2007 and above formats the macros is not saved properly.
Create 2 worksheets named "Querstions" and "Testing Questions"
In the Questions worksheet create or copy the questions that you want to be asked, with the correct answers ofcourse.
In the cell H1 put the formula =COUNTA(G:G) (this will keep track of the questions marked to be asked)
In the cell I1 put the formula =COUNTA(A:A) (this will keep track of total number of questions)
In the Testing Questions worksheet create a button that will launch the question form.
Step 2: Creating User Form
Open VBA and create a user form.
Put 7 controls as shown in the image.
Create proper names for the controls (final file is attached)
Step 3: Write the Code
Create a macro for the Button on the worksheet
Sub Button1_Click()
Randomize
totalq = CInt(Range("Questions!I1").Text)
For i = 1 To totalq
    Range("Questions!G" & i).FormulaR1C1 = ""
Next
While (Range("Questions!H1").Text <> 10)
    i = Round(1 + ((totalq - 1) * Rnd()), 0)
    Range("Questions!G" & i).FormulaR1C1 = "A"
Wend
QForm.Show
End Sub
Also create the VBA code for the form to work
Dim counter, ans, qcounter
Private Sub Answer1_Click()
Button.Enabled = True
End Sub
Private Sub Answer2_Click()
End Sub
Private Sub Answer3_Click()
End Sub
Private Sub Answer4_Click()
End Sub
Private Sub Button_Click()
If (Answer1.Value = True) Then
    ans = 1
ElseIf (Answer2.Value = True) Then
    ans = 2
ElseIf (Answer3.Value = True) Then
    ans = 3
ElseIf (Answer4.Value = True) Then
    ans = 4
End If
ansacc = CInt(Range("Questions!F" & counter).Text)
If (ansacc = ans) Then
    status.Width = status.Width + 30
End If
Answer1.Value = False
Answer2.Value = False
Answer3.Value = False
Answer4.Value = False
counter = counter + 1
qcounter = qcounter + 1
If qcounter <= 10 Then
While (Range("Questions!G" & counter).Text <> "A")
Wend
Question.Caption = Range("Questions!A" & counter).Text
Answer1.Caption = Range("Questions!B" & counter).Text
Answer2.Caption = Range("Questions!C" & counter).Text
Answer3.Caption = Range("Questions!D" & counter).Text
Answer4.Caption = Range("Questions!E" & counter).Text
End If
Button.Enabled = False
If qcounter = 11 Then
MsgBox ("Your score is " & 10 * status.Width / 30 & "%")
QForm.Hide
End If
End Sub
Private Sub UserForm_Activate()
counter = 1
status.Width = 0
ans = 0
Wend
qcounter = 1
End Sub
Step 4: Execute the Code
Click the start test button. The user form should open and the options with the questions should be populated. If it does not open, that means your macro settings are not set. Kindly google for the same.
Step 5: How Does It Work
1. First 10 questions are marked at random.
2. The user form is opened and the first question is put to the user.
3. When the user selects an answer the Next button is enabled.
4. When the next button is clicked the code compares the right answer with the user's answer and if it is OK the score bar is increased.
5. This happens till all the 10 marked questions have been answered.
Step 6: Secure the Questions
Now the questions have to be hidden from the user, so that he/she should not be able to see the answers.
For doing this, In the VBA window mark its visibility as VeryHidden.
You can also protect the sheet by password protecting it etc. But that's up to you.
The attached workbook does not have these things incorporated.
    • Spotless Contest
      Spotless Contest
    • Woodworking Contest
      Woodworking Contest
    • Flowers Challenge
      Flowers Challenge
    33 Comments
    want to add explanation column
    Hi thanks a lot..
    Can you help me in two things
    1. I want name of the candidate to fill in.
    2. I want to see script at the end which questions got correct and which got wrong.
    Can you provide the code, so that o can include in this code.
    Please reply.
    Thanks
    hey thanks a lot.
    i needed hekp in two things:
    1) how should i remove the randomness of questions.
    2) what should i do if i want the options selected to be stored in the excel sheet
    Hi,
    Any idea how do we store the scores if there are 50 concurrent users giving the same test?
    How would you create a "complete" button, that when the test taker is done, that outputs their answers along with their score to another file (or even to an email address), or to a printer?
    You see, I am a lazy guy. The code for what you ask is available on google. But It will take some time to get incorporated into the code. I will surely add those in v2.0.
    Hi,
    Hi, Iam new vba any one help me what are 7 controls which was added to the userform plz
    The default userform controls in excel VBA are
    Label: used for showing text to user
    TextBox: used to take user input
    ComboBox: Dropdown list
    ListBox: Scrolling list (can be multi selection)
    CheckBox: Used to take tick marks (multi selection)
    OptionButton: Used to take tick marks (single selection)
    ToggleButton: On off switch
    Frame: Used to group controls
    CommandButton: ok/cancel/submit or any other button
    TabStrip: Used for multi tab effect
    MultiPage: Used for multi form effect
    ScrollBar: Used to scroll/slider
    SpinButton: Used as counter
    Image: Insert pics
    RefEdit: External controls like file read wizard
    I have used: Labels, RadioButtons and CommandButtons in the above user form.
    Hope this helps.
    http://www.excelfilepasswordrecovery.com
    Hi team,
    Can we copy the test result of one person in different sheet to Validate. and also can we add timer (for Ex. for 30 mins) it should end the test.
    Please help!
    Thanks & Regards
    Satish
    hi... i have completed and found the answer..tks
    another question i would like to ask is on the present page is it possible to attach pictures as objective questions.....
    Yes! This can be done. But some addins are required for images to be ported from the excel sheet to the VBA forms. Have to do some R&D. This is out of my scope for now. Will make another ible if get to know about this feature.
    tks..
    also i would like to know on the prsent page as im setting up something for my office staff as soon as the test starts will it be possible for the staff to enter their names and after the exam/test their percentage is auto printed on as a PDF file which can be generated as an email.
    hi. i would like to know how to change the mark percentage for the sheet .. i am giving 50 questions .. i need to get after the exam total percentage of 100%. how to indicate it..
    Sir how can I change the questions into 10? I made a questions of 127 items and marked the questions to 50 random but when I tried to start the questions it appears only 10 random questions. Please help me Sir.
    Change the line
    to
    While (Range("Questions!H1").Text <> 50)
    to
    If qcounter <= 50 Then
    AND
    to
    If qcounter = 51 Then
    The scoring thing will still have a glitche.
    This is a temporary solution. I will have to make a newer improved customizable version of the question paper.
    Wow superb work sir. I was searching similar from last week. I would like to have one more feature. I am planning to make around 1000 questions in excel, and then select some questions from them, say 25, and print a small test. In this way we will be able to make different questions in each test without copy pasting anything.
    For print we can use sheet2 and make some code that will fetch questions with 'A' in column G. I dont know how to write that code or formula. If you can write it will be very useful.
    How do you change it so it doesn't do just 10 questions randomly? I would like to do 50 questions randomly.
