Introduction: Create Snake Program
Picture of Create Snake Program
This is a snake game and it's made in batch script and graphics are text based the only thing you need to make this is notepad
Step 1: Open Notepad
Picture of Open Notepad
Step 2: Then Copy and Paste This Code on Notepad
Picture of Then Copy and Paste This Code on Notepad
@echo off
if "%~1" == "startGame" goto :game
if "%~1" == "startController" goto :controller
:: setup some global variables used by both the game and the controller
setlocal disableDelayedExpansion
:getSession
if defined temp (set "tempFileBase=%temp%\") else if defined tmp set "tempFileBase=%tmp%\"
set "tempFileBase=%tempFileBase%Snake%time::=_%"
set "keyFile=%tempFileBase%_key.txt"
set "cmdFile=%tempFileBase%_cmd.txt"
set "gameLock=%tempFileBase%_gameLock.txt"
set "gameLog=%tempFileBase%_gameLog.txt"
set "signal=%tempFileBase%_signal.txt"
set "saveLoc=%userprofile%\Snake"
set "userPref=%saveLoc%\SnakeUserPref.txt"
set "hiFile=%saveLoc%\Snake!growth!Hi"
:: Lock this game session and launch.
:: Loop back and try a new session if failure.
:: Cleanup and exit when finished
call :launch 7>"%gameLock%" || goto :getSession
del "%tempFileBase%*"
exit /b
:launch the game and the controller
call :fixLogs
copy nul "%keyFile%" >nul
copy nul "%cmdFile%" >nul
start "" /b cmd /c ^""%~f0" startController 9^>^>"%keyFile%" 8^<"%cmdFile%" 2^>nul ^>nul^"
cmd /c ^""%~f0" startGame 9^<"%keyFile%" 8^>^>"%cmdFile%" ^echo(
:: Upon exit, wait for the controller to close before returning
:close
2>nul (>>"%keyFile%" call )||goto :close
if not exist "%~dp0CursorPos.exe" (
echo Game play can be improved by installing
echo Aacini's CursorPos.exe, available at
echo http://goo.gl/hr6Kkn
echo(
echo %cmdcmdline%|find /i "%~f0">nul&&pause
exit /b 0
:game
title %~nx0
cls
:: Playfield size
:: max playing field: (width-2)*(height-2) <= 1365
set "width=40" max=99
set "height=25" max=99
:: resize the console window
set /a cols=width+1, lines=height+10, area=(width-2)*(height-2)
if %area% gtr 1365 (
echo ERROR: Playfield area too large
%sendCmd% quit
exit
if %lines% lss 14 set lines=14
if %cols% lss 46 set cols=46
mode con: cols=%cols% lines=%lines%
:: define variables
set "configOptions=diffCode difficulty growth moveKeys up down left right"
set "configOptionCnt=9"
set "moveKeys=4"
set "up=W"
set "down=S"
set "left=A"
set "right=D"
set "pause=P"
set "space= "
set "bound=#"
set "food=+"
set "head=@"
set "body=O"
set "death=X"
set "growth=1"
if exist "%userPref%" for /f "usebackq delims=" %%V in ("%userPref%") do set "%%V"
set "spinner1=-"
set "spinner2=\"
set "spinner3=|"
set "spinner4=/"
set "spinner= spinner1 spinner2 spinner3 spinner4 "
set "delay1=20"
set "delay2=15"
set "delay3=10"
set "delay4=7"
set "delay5=5"
set "delay6=3"
set "desc1=Sluggard"
set "desc2=Crawl"
set "desc3=Slow"
set "desc4=Normal"
set "desc5=Fast"
set "desc6=Insane"
set "spinnerDelay=3"
set /a "width-=1, height-=1"
:: define LF as a Line Feed (newline) character
set ^"LF=^
^" Above empty line is required - do not remove
:: define CR as a Carriage Return character
for /f %%A in ('copy /Z "%~dpf0" nul') do set "CR=%%A"
:: define BS as a BackSpace character
for /f %%A in ('"prompt $H&for %%B in (1) do rem"') do set "BS=%%A"
set "upper=A B C D E F G H I J K L M N O P Q R S T U V W X Y Z"
set "invalid=*~="
:: define macros
if exist "%~dp0CursorPos.exe" (
set "cls=CursorPos 0 0"
set "ClearLine=echo( &CursorPos 0 -1"
set "ClearPrev=CursorPos 0 -0&echo( "
) else (
set "cls=cls"
set "ClearLine="
set "ClearPrev="
:: define a newline with line continuation
set ^"\n=^^^%LF%%LF%^%LF%%LF%^^"
:: setErr
::: Sets the ERRORLEVEL to 1
set "setErr=(call)"
:: clrErr
::: Sets the ERRORLEVEL to 0
set "clrErr=(call )"
:: sendCmd command
::: sends a command to the controller
set "sendCmd=>&8 echo"
:: getKey [ValidKey] [ValidKey...]
::: Check for keypress from the controller. Only accept a ValidKey.
::: Token delimiters and poison characters must be quoted.
::: Accept any key if no ValidKey specified.
::: Return result in Key variable. Key is undefined if no valid keypress.
set getKey=%\n%
for %%# in (1 2) do if %%#==2 (%\n%
set key=%\n%
set inKey=%\n%
set keyTest=%\n%
^<^&9 set /p "inKey="%\n%
if defined inKey (%\n%
set inKey=!inKey:~0,-1!%\n%
for %%C in (!args!) do set /a keyTest=1^&if /i !inKey! equ %%~C set key=!inKey!%\n%
)%\n%
if not defined keyTest set key=!inKey!%\n%
) else set args=
:: draw
::: draws the board
set draw=%\n%
set screen=%\n%
for /l %%Y in (0,1,%height%) do set screen=!screen!!line%%Y!!LF!%\n%
set screen=!screen!Speed = !Difficulty! !replay!!LF!Growth Rate = !growth! HighScore = !hi!!LF!Score = !score! Time = !m!:!s!%\n%
if defined replay if not defined replayFinished (%\n%
set screen=!screen!!LF!!LF!Press a key to abort the replay%\n%
)%\n%
%cls%^&echo(!screen!
:: test X Y ValueListVar
::: tests if value at coordinates X,Y is within contents of ValueListVar
set test=%\n%
for %%# in (1 2) do if %%#==2 (for /f "tokens=1-3" %%1 in ("!args!") do (%\n%
for %%A in ("!line%%2:~%%1,1!") do if "!%%3:%%~A=!" neq "!%%3!" %clrErr% else %setErr%%\n%
)) else set args=
:: plot X Y ValueVar
::: places contents of ValueVar at coordinates X,Y
set plot=%\n%
set "part2=!line%%2:~%%1!"%\n%
set "line%%2=!line%%2:~0,%%1!!%%3!!part2:~1!"%\n%
)) else set args=
:: start the game
setlocal enableDelayedExpansion
if not exist "%saveLoc%\" md "%saveLoc%"
set "replay= Aborting... "
set "replayAvailable="
call :loadHighScores
call :mainMenu
:: main loop (infinite loop)
for /l %%. in () do (
%=== check for and process abort signal if in replay mode ===%
if defined replay if exist "%signal%" (
del "%signal%"
set "replayFinished=1"
%draw%
echo(
%ClearLine%
call :purge
for %%A in (!configOptions!) do set "%%A=!%%ASave!"
call :mainMenu
%=== compute time since last move ===%
for /f "tokens=1-4 delims=:.," %%a in ("!time: =0!") do set /a "t2=(((1%%a*60)+1%%b)*60+1%%c)*100+1%%d-36610100, tDiff=t2-t1"
if !tDiff! lss 0 set /a tDiff+=24*60*60*100
if !tDiff! geq !delay! (
%=== delay has expired, so time for movement ===%
set /a t1=t2
%=== compute game time ===%
if not defined gameStart set "gameStart=!t2!"
set /a "gameTime=(t2-gameStart)"
if !gameTime! lss 0 set /a "gameTime+=24*60*60*100"
set /a "gameTime=(gameTime-pauseTime)/100, m=gameTime/60, s=gameTime%%60"
if !m! lss 10 set "m=0!m!"
if !s! lss 10 set "s=0!s!"
%=== get keypress ===%
%getKey% !keys!
if /i !key! equ !pause! (
%=== pause game ===%
echo(
call :ask "PAUSED - Press a key to continue..."
%ClearPrev%
%sendCmd% go
set /a pauseTime+=tDiff
) else (
%=== establish direction ===%
if not defined replay (echo(!key!.) >>"!gameLog!"
for %%K in (!key!) do if !moveKeys! equ 2 (
set /a "xDiff=xTurn%%K*!yDiff!, yDiff=yTurn%%K*!xDiff!"
) else if "!%%KAxis!" neq "!axis!" (
set /a "xDiff=xDiff%%K, yDiff=yDiff%%K"
set "axis=!%%KAxis!"
%=== erase the tail ===%
set "TX=!snakeX:~-2!"
set "TY=!snakeY:~-2!"
set "snakeX=!snakeX:~0,-2!"
set "snakeY=!snakeY:~0,-2!"
%plot% !TX! !TY! space
%=== compute new head location and attempt to move ===%
set /a "X=PX+xDiff, Y=PY+yDiff"
set "X= !X!"
set "Y= !Y!"
set "X=!X:~-2!"
set "Y=!Y:~-2!"
(%test% !X! !Y! playerSpace) && (
%=== move successful ===%
%=== remove the new head location from the empty list ===%
for %%X in ("!X!") do for %%Y in ("!Y!") do set "empty=!empty:#%%~X %%~Y=!"
%=== eat any food that may be present ===%
(%test% !X! !Y! food) && (
%=== initiate growth ===%
set /a grow+=growth
%=== locate and draw new food ===%
if defined replay (
<&9 set /p "F="
) else (
set /a "F=(!random!%%(emptyCnt-1))*6+1"
(echo !F!) >>"!gameLog!"
for %%F in (!F!) do (%plot% !empty:~%%F,5! food)
if !grow! gtr 0 (
%=== restore the tail ===%
%plot% !TX! !TY! body
set "snakeX=!snakeX!!TX!"
set "snakeY=!snakeY!!TY!"
set /a emptyCnt-=1
%=== manage score ===%
set /a "score+=1, grow-=1"
if not defined replay if !score! gtr !hi! set /a "hi+=1, newHi=1"
) else (
%=== add the former tail position to the empty list ===%
set "empty=!empty!#!TX! !TY!"
%=== draw the new head ===%
if defined snakeX (%plot% !PX! !PY! body)
%plot% !X! !Y! head
%=== Add the new head position to the snake strings ===%
set "snakeX=!X!!snakeX!"
set "snakeY=!Y!!snakeY!"
set "PX=!X!"
set "PY=!Y!"
%draw%
%=== failed move - game over ===%
call :spinner !PX! !PY! death
%draw%
if defined newHi (
echo(
echo New High Score - Congratulations^^!
set "hi!diffCode!=!score!"
copy "!gameLog!" "%hiFile%!diffCode!.txt" >nul
>>"%hiFile%!diffCode!.txt" echo ::!score!
echo(
%ClearLine%
call :ask "Press a key to continue..."
call :mainMenu
:getString Prompt Var MaxLen
:: Prompt for a string with max lengh of MaxLen.
:: Valid keys are alpha-numeric, space, underscore, and dash
:: String is terminated by Enter
:: Backspace works to delete previous character
:: Result is returned in Var
set /a "maxLen=%3"
set "%2="
%sendCmd% prompt
call :purge
:getStringLoop
(%getKey% !upper! 0 1 2 3 4 5 6 7 8 9 " " _ - {Enter} !BS!)
if defined key (
if !key! equ {Enter} (
echo(
exit /b
if !key! neq !BS! if !maxLen! gtr 0 (
set /a maxLen-=1
set "%2=!%2!!key!
if !key! equ !BS! if defined %2 (
set /a maxLen+=1
set "%2=!%2:~0,-1!"
if defined inKey %sendCmd% one
goto :getStringLoop
:ask Prompt ValidKey [Validkey]...
:: Prompt for a keypress.
:: Wait until a ValidKey is pressed and return result in Key variable.
:: Token delimiters, ), and poison characters must be quoted.
%sendCmd% prompt
(set validKeys=%*)
(set validKeys=!validKeys:%1=!)
call :purge
:getResponse
(%getKey% !validKeys!)
if not defined key (
goto :getResponse
exit /b
:purge
set "inKey="
for /l %%N in (1 1 1000) do (
set /p "inKey="
if "!inKey!" equ "{purged}." exit /b
)<&9
goto :purge
:spinner X Y ValueVar
set /a d1=-1000000
for /l %%N in (1 1 5) do for %%C in (%spinner%) do (
call :spinnerDelay
%plot% %1 %2 %%C
%draw%
call :spinnerDelay
(%plot% %1 %2 %3)
exit /b
:delay centiSeconds
setlocal
for /f "tokens=1-4 delims=:.," %%a in ("!time: =0!") do set /a "spinnerDelay=%1, d1=(((1%%a*60)+1%%b)*60+1%%c)*100+1%%d-36610100"
:: fall through to :spinnerDelay
:spinnerDelay
for /f "tokens=1-4 delims=:.," %%a in ("!time: =0!") do set /a "d2=(((1%%a*60)+1%%b)*60+1%%c)*100+1%%d-36610100, dDiff=d2-d1"
if %dDiff% lss 0 set /a dDiff+=24*60*60*100
if %dDiff% lss %spinnerDelay% goto :spinnerDelay
set /a d1=d2
exit /b
:mainMenu
cls
set "loadAvailable="
echo Growth rate = !growth!
echo(
echo Main Menu:
echo(
echo N - New game
if defined replayAvailable echo R - Replay previous game
if defined saveAvailable echo S - Save a game
if exist *.snake.txt echo L - Load and watch a saved game&set "loadAvailable=L"
echo C - Control options
echo G - Graphic options
echo Q - Quit
echo(
set "hiAvailable="
for /l %%N in (1 1 6) do if defined hi%%N (
if not defined hiAvailable (
echo Replay High Score:
echo(
set "desc=!desc%%N!........"
set "hiAvailable=!hiAvailable! %%N"
echo %%N - !desc:~0,8! !hi%%N!
if defined hiAvailable echo(
set "keys=N C G Q !hiAvailable! !replayAvailable! !saveAvailable! !loadAvailable!"
call :ask ">" !keys!
if /i !key! equ Q (
%sendCmd% quit
cls
exit
if /i !key! equ N (
set "replay="
set "replayAvailable=R"
set "saveAvailable=S"
goto :initialize
if /i !key! equ S (
if defined replayAvailable (
call :ask "HighScore # or P for Previous:" !hiAvailable! P
) else (
call :ask "HighScore #:" !hiAvailable!
echo !key!
if /i !key! equ P (set "src=!gameLog!") else set "src=%hiFile%!key!.txt"
call :getString "Save file name:" file 20
copy "!src!" "!file!.snake.txt"
if /i !key! equ L (
call :getString "Load file name:" file 20
if exist "!file!.snake.txt" (
set "replay=!file!.snake.txt"
goto :initialize
echo Error: File "!file!.snake.txt" not found
if /i !key! equ R (
set "replay=!gameLog!"
goto :initialize
if !key! geq 1 if !key! leq 6 (
set "replay=%hiFile%!key!.txt"
goto :initialize
if /i !key! equ C call :controlOptions
if /i !key! equ G call :graphicOptions
goto :mainMenu
:controlOptions
cls
set "keys={Enter} T L R P"
if !moveKeys! equ 4 set "keys=!keys! U D"
echo Control Options:
echo(
echo T - Type... = !moveKeys! keys
echo(
echo L - Left... = !left!
echo R - Right.. = !right!
if !moveKeys! equ 4 echo U - Up..... = !up!
if !moveKeys! equ 4 echo D - Down... = !down!
echo(
echo P - Pause.. = !pause!
echo(
echo {Enter} - Return to Main Menu
echo(
if !key! equ {Enter} goto :saveUserPrefs
if /i !key! equ T (
if !moveKeys! equ 2 (set "moveKeys=4") else set "moveKeys=2"
goto :controlOptions
set "option= LLeft RRight UUp DDown PPause"
for /f %%O in ("!option:* %key%=!") do (
call :ask "Press a key for %%O:"
for %%K in (0 1 2) do if "!key!" equ "!invalid:~%%K,1!" goto :controlOptions
for %%C in (!upper!) do set "key=!key:%%C=%%C!"
set "%%O=!key!"
:graphicOptions
cls
echo Graphic Options:
echo(
echo B - Border...... = !bound!
echo E - Empty space. = !space!
echo H - snake Head.. = !head!
echo S - Snake body.. = !body!
echo F - Food........ = !food!
echo D - Death....... = !death!
echo(
echo G - Growth rate. = !growth!
echo(
echo {Enter} - Rturn to Main Menu
echo(
call :ask ">" B E H S F D G {Enter}
if /i !key! equ G (
call :ask "Press a digit for growth rate (0 = 10)" 0 1 2 3 4 5 6 7 8 9
if !key! equ 0 set "key=10"
set "growth=!key!"
) else (
set "option=-BBorder:bound:-EEmpty Space:space:-HSnake Head:head:-SSnake Body:body:-FFood:food:-DDeath:death:"
for /f "tokens=1,2 delims=:" %%A in ("!option:*-%key%=!") do (
call :ask "Press a key for %%A"
for %%K in (0 1 2) do if "!key!" equ "!invalid:~%%K,1!" goto :graphicOptions
set "%%B=!key!"
:saveUserPrefs
(for %%V in (moveKeys up down left right space bound food head body death pause growth) do echo %%V=!%%V!) >"%userPref%"
exit /b
:initialize
cls
if defined replay (
echo Replay Speed Options:
) else (
echo Speed Options:
echo delay
echo # Description (seconds)
echo --- ----------- ---------
for /l %%N in (1 1 6) do (
set "delay=0!delay%%N!"
set "desc=!desc%%N! "
echo %%N !desc:~0,11! 0.!delay:~-2!
echo(
call :ask "Pick a speed (1-6):" 1 2 3 4 5 6
set "difficulty=!desc%key%!"
set "delay=!delay%key%!"
set "diffCode=%key%"
echo %key% - %difficulty%
echo(
set "axis=X"
set "xDiff=+1"
set "yDiff=+0"
set "empty="
set /a "PX=1, PY=height/2, FX=width/2+1, FY=PY, score=0, emptyCnt=0, t1=-1000000"
set "gameStart="
set "m=00"
set "s=00"
set "snakeX= %PX%"
set "snakeY= %PY%"
set "snakeX=%snakeX:~-2%"
set "snakeY=%snakeY:~-2%"
for /l %%Y in (0 1 %height%) do (
set "line%%Y="
for /l %%X in (0,1,%width%) do (
set "cell="
if %%Y equ 0 set "cell=%bound%"
if %%Y equ %height% set "cell=%bound%"
if %%X equ 0 set "cell=%bound%"
if %%X equ %width% set "cell=%bound%"
if %%X equ %PX% if %%Y equ %PY% set "cell=%head%"
if not defined cell (
set "cell=%space%"
set "eX= %%X"
set "eY= %%Y"
set "empty=!empty!#!eX:~-2! !eY:~-2!"
set /a emptyCnt+=1
if %%X equ %FX% if %%Y equ %FY% set "cell=%food%"
set "line%%Y=!line%%Y!!cell!"
for %%A in (!configOptions!) do set "%%ASave=!%%A!"
set "replayFinished="
if defined replay (
%sendCmd% replay
%sendCmd% !replay!
call :waitForSignal
set "replay=(REPLAY at !difficulty!)"
set "read=1"
<&9 (
for /l %%N in (1 1 !configOptionCnt!) do if defined read (
set /p "ln="
if "!ln!" equ "END" (set read=) else set "!ln!"
set "keys="
set "hi=0"
for /f "delims=:" %%A in ('findstr "^::" "%hiFile%!diffCode!.txt" 2^>nul') do set "hi=%%A"
(%draw%)
call :delay 100
) else (
if defined hi%diffCode% (set "hi=!hi%diffCode%!") else set "hi=0"
(%draw%)
>"!gameLog!" (
for %%A in (!configOptions!) do (echo %%A=!%%A!)
(echo END)
echo(
if !moveKeys! equ 4 (
echo Controls: !up!=up !down!=down !left!=left !right!=right !pause!=pause
) else (
echo Controls: !left!=left !right!=right !pause!=pause
echo Avoid running into yourself (!body!!body!!head!^) or wall (!bound!^)
echo Eat food (!food!^) to grow.
echo(
call :ask "Press a key to start..."
%sendCmd% go
set "pauseTime=0"
set "xDiff!up!=+0"
set "xDiff!down!=+0"
set "xDiff!left!=-1"
set "xDiff!right!=+1"
set "yDiff!up!=-1"
set "yDiff!down!=+1"
set "yDiff!left!=+0"
set "yDiff!right!=+0"
set "!up!Axis=Y"
set "!down!Axis=Y"
set "!left!Axis=X"
set "!right!Axis=X"
set "xTurn!left!=1"
set "xTurn!right!=-1"
set "yTurn!left!=-1"
set "yTurn!right!=1"
set "playerSpace=!space!!food!"
set ^"keys="!left!" "!right!" "!pause!"^"
set "newHi="
set "grow=0"
if !moveKeys! equ 4 set ^"keys=!keys! "!up!" "!down!"^"
cls
exit /b
:waitForSignal
if not exist "%signal%" goto :waitForSignal
del "%signal%"
exit /b
:loadHighScores
set "saveAvailable="
set "hi%%N="
for /f "delims=:" %%A in ('findstr "^::" "%hiFile%%%N.txt" 2^>nul') do (
set "hi%%N=%%A"
exit /b
:fixLogs
for %%F in (*.snake) do (
ren "%%F" "%%F.txt"
call :fixLog "%%F.txt"
pushd "%SaveLoc%"
for /f "delims=" %%F in ('dir /b SnakeHi*.txt 2^>nul') do (
set "file=%%~nF"
set "file=Snake1Hi!file:~-1!.txt"
ren "%%F" "!file!"
call :fixLog "!file!"
popd
exit /b
:fixLog filePath
>"%~1.new" (
<"%~1" (
for %%A in (diffCode difficulty moveKeys up down left right) do (
set /p "val="
(echo %%A=!val!)
(echo growth=1)
(echo END)
more +7 "%~1"
move /y "%~1.new" "%~1" >nul
exit /b
:controller
:: Detects keypresses and sends the information to the game via a key file.
:: The controller has various modes of input that are activated by commands sent
:: from the game via a cmd file.
:: Modes:
:: hold - No input, wait for command
:: go - Continuously get/send key presses
:: prompt - Send {purged} marker to allow game to purge input buffer, then
:: get/send a single key press and hold
:: one - Get/send a single key press and hold
:: replay - Copy a game log to the key file. The next line in cmd file
:: specifies name of log file to copy. During replay, the controller
:: will send an abort signal to the game if a key is pressed.
:: quit - Immediately exit the controller process
:: As written, this routine incorrectly reports ! as ), but that doesn't matter
:: since we don't need that key. Both and Enter key are reported as {Enter}.
:: An extra character is appended to the output to preserve any control chars
:: when read by SET /P.
for /f %%a in ('copy /Z "%~dpf0" nul') do set "CR=%%a"
set "cmd=hold"
set "inCmd="
set "key="
if "!cmd!" neq "hold" (
for /f "delims=" %%A in ('xcopy /w "%~f0" "%~f0" 2^>nul') do (
if not defined key set "key=%%A"
set "key=!key:~-1!"
if !key! equ !CR! set "key={Enter}"
<&8 set /p "inCmd="
if defined inCmd (
if !inCmd! equ quit exit
set "cmd=!inCmd!"
if !inCmd! equ replay (
<&8 set /p "file="
type "!file!" >&9
copy nul "%signal%"
set "inCmd="
if defined key (
if "!cmd!" equ "prompt" (echo {purged}.)
if "!cmd!" equ "replay" (
copy nul "%signal%" >nul
(echo {purged}.)
set "cmd=go"
) else (echo(!key!.)
if "!cmd!" neq "go" set "cmd=hold"
set "key="
)>&9
Step 3: How to Save
Picture of How to Save
Then goto file on the top left and select save as please listen properly to this part then click on desktop then you can save it as any name but it MUST have .bat at the end for example if I want to save it as snake game il have to do it like this snake game.bat it must have .bat at the end
Step 4: Enjoy
Picture of Enjoy
This game also has settings for controls ingame and if you want to do a new game you press n and etc it will show you what things to press
Mohbuscus (author)2014-12-26
hey gyes i made this is the code above doesent work try this
@echo off
:getSession
exit /b
call :fixLogs
cmd /c ^""%~f0" startGame 9^<"%keyFile%" 8^>^>"%cmdFile%" ^<nul^"
echo(
:close
echo(
exit /b 0
:game
title %~nx0
cls
:: Playfield size
%sendCmd% quit
exit
:: define variables
set "moveKeys=4"
set "up=W"
set "down=S"
set "left=A"
set "right=D"
set "pause=P"
set "space= "
set "bound=#"
set "food=+"
set "head=@"
set "body=O"
set "death=X"
set "growth=1"
set "spinner1=-"
set "spinner2=\"
set "spinner3=|"
set "spinner4=/"
set "delay1=20"
set "delay2=15"
set "delay3=10"
set "delay4=7"
set "delay5=5"
set "delay6=3"
set "desc2=Crawl"
set "desc3=Slow"
set "desc4=Normal"
set "desc5=Fast"
set "desc6=Insane"
set ^"LF=^
set "invalid=*~="
:: define macros
) else (
set "cls=cls"
set "ClearLine="
set "ClearPrev="
:: setErr
set "setErr=(call)"
:: clrErr
:: sendCmd command
set getKey=%\n%
set key=%\n%
set inKey=%\n%
set keyTest=%\n%
)%\n%
) else set args=
:: draw
::: draws the board
set draw=%\n%
set screen=%\n%
)%\n%
set test=%\n%
)) else set args=
set plot=%\n%
)) else set args=
:: start the game
call :mainMenu
del "%signal%"
%draw%
echo(
%ClearLine%
<nul set /p "=Aborting... "
call :purge
call :mainMenu
set /a t1=t2
%getKey% !keys!
echo(
%ClearPrev%
%sendCmd% go
) else (
set "X= !X!"
set "Y= !Y!"
set "X=!X:~-2!"
set "Y=!Y:~-2!"
set /a grow+=growth
if defined replay (
<&9 set /p "F="
) else (
if !grow! gtr 0 (
set /a emptyCnt-=1
) else (
%plot% !X! !Y! head
set "PX=!X!"
set "PY=!Y!"
%draw%
%draw%
if defined newHi (
echo(
echo(
%ClearLine%
call :mainMenu
set /a "maxLen=%3"
set "%2="
%sendCmd% prompt
<nul set /p "=%~1 "
call :purge
:getStringLoop
if defined key (
echo(
exit /b
set /a maxLen-=1
<nul set /p "=.!BS!!key!"
set "%2=!%2!!key!
set /a maxLen+=1
<nul set /p "=!BS! !BS!"
set "%2=!%2:~0,-1!"
goto :getStringLoop
%sendCmd% prompt
<nul set /p "=%~1 "
(set validKeys=%*)
call :purge
:getResponse
goto :getResponse
exit /b
:purge
set "inKey="
set /p "inKey="
)<&9
goto :purge
set /a d1=-1000000
call :spinnerDelay
%plot% %1 %2 %%C
%draw%
call :spinnerDelay
(%plot% %1 %2 %3)
exit /b
:delay centiSeconds
setlocal
:spinnerDelay
set /a d1=d2
exit /b
:mainMenu
cls
echo(
echo Main Menu:
echo(
echo N - New game
echo Q - Quit
echo(
set "hiAvailable="
echo(
if /i !key! equ Q (
%sendCmd% quit
cls
exit
if /i !key! equ N (
set "replay="
goto :initialize
if /i !key! equ S (
) else (
echo !key!
if /i !key! equ L (
goto :initialize
if /i !key! equ R (
goto :initialize
goto :initialize
goto :mainMenu
:controlOptions
cls
echo(
echo(
echo(
echo(
echo(
if /i !key! equ T (
set "%%O=!key!"
:graphicOptions
cls
echo(
echo(
echo(
echo(
if /i !key! equ G (
set "growth=!key!"
) else (
set "%%B=!key!"
:saveUserPrefs
exit /b
:initialize
cls
if defined replay (
) else (
echo Speed Options:
echo delay
echo(
echo(
<nul set /p "=Initializing."
set "axis=X"
set "xDiff=+1"
set "yDiff=+0"
set "empty="
set "gameStart="
set "m=00"
set "s=00"
set "snakeX= %PX%"
set "snakeY= %PY%"
<nul set /p "=."
set "line%%Y="
set "cell="
set "cell=%space%"
set "eX= %%X"
set "eY= %%Y"
set /a emptyCnt+=1
if defined replay (
%sendCmd% replay
%sendCmd% !replay!
call :waitForSignal
set "read=1"
<&9 (
set /p "ln="
set "keys="
set "hi=0"
(%draw%)
call :delay 100
) else (
(%draw%)
>"!gameLog!" (
(echo END)
echo(
) else (
echo(
%sendCmd% go
set "pauseTime=0"
set "xDiff!up!=+0"
set "yDiff!up!=-1"
set "!up!Axis=Y"
set "!down!Axis=Y"
set "!left!Axis=X"
set "!right!Axis=X"
set "xTurn!left!=1"
set "newHi="
set "grow=0"
cls
exit /b
:waitForSignal
del "%signal%"
exit /b
:loadHighScores
set "hi%%N="
set "hi%%N=%%A"
exit /b
:fixLogs
ren "%%F" "%%F.txt"
pushd "%SaveLoc%"
set "file=%%~nF"
ren "%%F" "!file!"
popd
exit /b
:fixLog filePath
>"%~1.new" (
<"%~1" (
set /p "val="
(echo %%A=!val!)
(echo growth=1)
(echo END)
more +7 "%~1"
exit /b
:controller
:: Modes:
:: since we don't need that key. Both <CR> and Enter key are reported as {Enter}.
set "cmd=hold"
set "inCmd="
set "key="
set "key=!key:~-1!"
<&8 set /p "inCmd="
if defined inCmd (
set "cmd=!inCmd!"
<&8 set /p "file="
type "!file!" >&9
copy nul "%signal%"
set "inCmd="
if defined key (
(echo {purged}.)
set "cmd=go"
set "key="
)>&9
JeffersonL20 (author)Mohbuscus2017-07-10
It doesn't work if just gives an error repeating,
' set' is not recognized as an internal or external command, operable program or batch file.
001DeLeon (author)Mohbuscus2016-05-26
Hey... Just for help, click on my profile and try my snake game...
ingwaldb (author)Mohbuscus2016-04-06
it does work write it in notepad and save it ?.bat
I_boom5245 (author)Mohbuscus2015-10-11
Uh... It didn't work. Both of them.
Mohbuscus (author)2015-01-05
and also gyes if even this code in the description doesent work for you or the code in the instructable goto this website of mine il paste a link here that should work if not it may be compatibility issue
http://copy-batch-codes-for-free.webs.com/snake-game
gamerdude197 (author)Mohbuscus2017-01-02
it is frozen
MrD28 (author)Mohbuscus2016-12-10
your web site is Froszen
JavaProgrammer (author)2014-12-26
that is a very impressively sized program! good job
Mohbuscus (author)JavaProgrammer2014-12-27
Thanks it took me a long time to do it without spelling errors etc I hope you enjoy it ?
CallumD1 (author)2015-07-31
I cant type anything in
RJP15 (author)CallumD12017-12-22
same :(
INFINITYK (author)CallumD12016-08-18
same here
Mohbuscus (author)CallumD12015-08-04
Try deleting it and writing the code again onto notepad make sure when you save it you put .bat at the end
tedd njagi (author)2017-03-22
cwuul
INFINITYK (author)2016-08-18
thanks man and check out my youtube it is infinityids5
RaymondS43 (author)2016-06-22
This dosnt even work at all
AashiK2 (author)2016-06-14
it doesnt work stupid people
Parvjoshi2004 (author)2016-04-15
I tried it 7 times but nothing happend
AndoniH (author)2016-02-23
it doesnt work for me
ZemByte (author)2015-11-29
Hello everyone!
If the code on this instructable does not work, try this one: https://www.instructables.com/id/CMD-Snake-Game/
With kind regards,
Niels, Media Manager of Zembyte
Also Gyes if you liked this please remember to favourite this and comment and follow me I would really apreatiet it peace?
About This Instructable
155,239views
36favorites
License:
Bio: Hi I'm Mohbuscus il be doing guides on pets and gaming and technology I hope you enjoy my guides and please follow peace
More by Mohbuscus:how to create funny computer prankHow To See Infrared LightCreate Snake Program
Add instructable to:
