3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Create Solder Paste Stencils with Cricut
Step 8Prepare Transparency and Machine
Take a sheet of transparency film and cut it to the size of the Cricut's cutting mat. Tack the cut transparency to the cutting mat. Insert the cutting mat into the machine and press the Load Paper button.
Set the Cricut's Pressure wheel to High, the Speed wheel to High or Medium, and the cutting blade depth to 5 or 6. Detailed instructions can be found in the Cricut's manual. Some trial-and-error is required here. Speed and pressure may change the precision of the cuts, and larger cutting blade depth speeds up how quickly you will need to replace the cutting mat.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:opendous
