Create Your Own Top-Down Blinds
Create top-down blinds for a fraction of the cost of special order blinds!
Step 1Getting Ready
Getting Ready
Why Create Your Own Top-Down Blinds?
My reasons are simple. I live in an apartment. It is temporary housing, and therefore I don't want to spend the nearly $150 per window to purchase custom top-down blinds. I also need the privacy that they offer because of my ground floor apartment.
What is the Cost and Time Commitment?
This particular project was done for under $30 (that includes all three windows). This is a bargain compared to the nearly $450 it would cost to have it done professionally. It also took me only an hour to create and install (not including shopping time).
What You'll Need:
- Make sure to measure your window first!
- One set of bargain mini-blinds per window. You are only going to use the top bar and strings for this project, so the quality of the slats is irrelevant. I found some for $2.50 each on sale, $4 each regular.
- One set of temporary shades*. They should be the kind that have an adhesive strip on one end. I bought the Redi Shades that are "room darkening" for more privacy. These cost me about $6 each.
*(These shades can be substituted for something of a better quality if desired. You will simply need to find a way of attaching the more complex shades/blinds to the top bar of your bargain blinds.)
- A cutting knife ($1.50) and cutting board or hard surface.
- Tape (optional).
35 comments
Mar 31, 2011. 6:50 AMruthgct says:
You only left about 5" of string. I'm confused by that. Does that mean you can only lower the blinds from the top 5"? I'd like to lower mine about 2 FEET from the top. Do I need to leave 2 feet of string?
Apr 1, 2011. 5:21 AMruthgct says:
OH! So then in Step 4 where it says "unknot the strings and allow for about 5 inches of string"...that's what I thought you meant. Sorry to be slow!! Can you explain that step to me another way? Thanks so much! I have all the blinds and plan to put them up this weekend in my 3 living room windows.
Apr 1, 2011. 10:30 AMruthgct says:
OK, I get it now! Thanks so much for guiding me through it, especially from an older project. I'll let ya know how they turn out! =)
Feb 11, 2010. 10:40 PMmat9973 says:
So if you bought the bargain blinds...why not use them?  Sorry...might be a dumb question but I realy need you to explain it.
Thanks
Feb 4, 2010. 11:36 AMbettbee says:
My experience has been that the temp blinds don't hold up. I've seen some that were in a window for 3 years and they were coming to bits. I'm tempted to make some of my own for this 'ible by learning to pleat fabric.
Aug 7, 2009. 12:17 PMshutdown_exploded says:
I tried this sort of from scratch, that is not using any parts from an existing blind set, just using hook-eyes as string guides and a tying up the string at whatever height. The shades folding themselves up is a serious problem, enough to almost make the whole project not worth it, but i'm still working on solutions. Some kind of guide bar to keep it from bowing out so much was one idea, but it doesn't entirely work. I also thought about applying water by cue-tip onto tho creases so as to weaken them, since it's the spring-like qualities of the blinds that make it want to bow outwards.
Jul 7, 2009. 12:13 AMshabrach says:
Thank you so much for your instructions. We want these types of blinds in our hot tub room but do not want to spend a fortune on them. This will be wonderful!
May 13, 2009. 1:37 PMmomo the dog says:
thanks for this posting! it was easy to follow. got it done in 10 min. it's up and working beautifully. thanks again.
Apr 3, 2008. 4:59 PMLinksep says:
Cool! This was the first intructables project I've actually DONE... It took WAY longer than it should have (2.5 hours) but I attribute most of that to the HORRIBLE instructions included with the cheap Chinese blinds (much bad Engrish). Cost me $30 (big 48"x52" window)
I looked for the shades that Warlord mentions but my local Home Depot didn't have them (that I could find... nobody around to help me.)
I looked all over online for top-down / bottom-up blinds and the cheapest I could find was $95 (likely plus shipping) so this saved me $60+ on one window! Thumbs up!
I do have to mention though, as a person that has never had top-down blinds, they look funny. I'm sure I'll get used to it pretty quick though.
Dec 15, 2007. 12:19 PMKaytiCat says:
These are awesome! Great job!
Dec 9, 2007. 5:07 PMwarlord says:
Thank you for this Instructable. The wifey loves our new cheap top down blinds. For those who want to do the top down and bottom up blinds you can buy the "temp shade" brand from home depot. You construct them the same but this brand has a cable and clip at the bottom that can lift and hold the bottom of the shade. It also has a little weight at the base which means no need for alligator clips to keep the shade down. I'll post pics in a bit... Thanks again.
Dec 9, 2007. 5:41 PMwarlord says:
here are the pics:
Nov 30, 2007. 7:45 PMhcold says:
Those brackets make me want to cry. So aesthetically wrong...
Dec 7, 2007. 7:42 AMchucka says:
You could fashion some wooden trim. Stained to match the sill and frame that once tacked on with some finishing nails would cover the unsightly mini blind mechanisms. Also, if your into working with tin you could make a nicely folded, U shaped cover that one might paint to match or polish and set over top of the blind inter-workings.
Dec 7, 2007. 4:12 AMGrizzlyAdams says:
Thanks for the great idea! I'm going to suggest something though: 1: Get two draw bars per set of blinds. 2: Get an extra draw string set. 3: Drill holes in the bottom caps for the first draw bar so the second string can pass through. 4: Punch holes carefully through your pleated blinds to run the extra draw set. This way you can have both top down and bottom up blinds. Color the draw string end caps so you can tell which is which. If you're lucky a local print shop will have a hole punch meant for use on large catalogs they might let you use.
Dec 7, 2007. 1:08 AMleebryuk says:
I love the shades. I will make some soon. And I also want to compliment you on the quality of the instructable. It was full of useful photographs and I found the written instructions excellent. Good Job!
Dec 6, 2007. 4:27 PMdonna421 says:
I'm new to this site - GREAT instructions, and fantastic idea! Question: If you would want to open your windows completely, it seems this would not work so well, because the blind wouldn't fold on top of itself without falling out of the window- kind of into the room. Am I right, and do you have a suggestion for how to make that work any better?
Dec 6, 2007. 8:14 PMEndif says:
See my comment above; the midrail will provide enough weight to smush the pleats/cells into a stack. Locking the strings at the point you want will ensure a stable stack. =]
Dec 6, 2007. 7:03 PMEndif says:
I am a Hunter Douglass certified professional installer/repair tech; our company is The Blind Man. Nuff said.
This instructable works, but really, you just need a travelling mid-rail and a restring that terminates at that new midrail.
A visit to your local blind company will probably yield free parts (they toss lots of blinds in the dumpsters, having replaced them). Probably get enough string that way too (you want the right guage of nylon cord, or the cordlock wont grab).
Hope this helps. =]
Dec 6, 2007. 4:13 PMUPdrafter says:
bravo! great idea. cant wait to try it.
Dec 6, 2007. 3:41 PMSMRUDOLPH says:
Well done! I love this. How clever you are!
Dec 2, 2007. 4:25 PMDoctor What says:
It may sound weird, but thank you for making seventeen steps. Usually other people (myself included) combine multiple steps into one. This is super easy to understand, and it produces an amazing result. (favorited) (+).
Dec 1, 2007. 11:04 PMdchall8 says:
Had you written this a year ago, it would have saved me about $600. Very nice. I might have to do some of the windows I couldn't afford before.
Dec 1, 2007. 10:56 AMjongscx says:
So are you able to raise and lower the shades with the old blind controls? I'm kinda confused as to how it works.
Dec 1, 2007. 11:02 AMjongscx says:
Nevermind, I figured it out. So you attach the heavy bottom plate off of the old miniblinds to the top of the new shade. So that when you want them down(open), you release the string and when you want them up(closed) you pull on it. Did you attach the bottom of the shade to the window frame or is it just held there by the weighted bar?
Dec 1, 2007. 12:46 AMDirectorsCUT says:
GREAT!!!
Nov 30, 2007. 11:35 PMcanida says:
Well done! Blinds are ridiculously expensive.
Nov 30, 2007. 9:43 PMGorillazMiko says:
awesome!
Nov 30, 2007. 6:36 PMxsmurf says:
Very neat! Great for ground level and half basement apartments! Nice Instructables too :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jen_higginbotham
