Create a Bootable USB drive with VistaPE
 by Flea
Step 2: Running Winbuilder
Winbuilder is a single file. Once you've downloaded it from Winbuilder's website, extract it to a folder on your hard drive and then run it.
:Edit:
Select the Server button and put a checkbox in VistaPE.net/project and click Download
:EndEdit:
Deselect everything except for the VistaPE Core option.
I unchecked some other options to speed things up, you can select applications that you want integrated into VistaPE.
Click download. This will take some time as it downloads scripts and files necessary for this operation.
budabob07 says: Mar 5, 2011. 4:53 AM
I get an error in this part that says: Run-Failed to find section [NotConfigured] in file: [%basedir%\ProjectVistaPE-Core\Base\00-api-main.script]
Lefacavus says: Nov 15, 2008. 9:29 AM
Nevermind, I got it. The VistaPE server was unchecked.
Lefacavus says: Nov 15, 2008. 8:40 AM
On my Winbuilder screen, I only have Optional, ReactOS, and Tools. How do I get the VistaPE Core?
tlhintoq says: Nov 11, 2008. 5:16 PM
Got a little more advice from here
http://www.themudcrab.com/vistapeguide.php#tagPart2
Using WInBuilder 074 and VistaPE v.11 as they were the two stable versions.
My end build however had multiple viruses in it from the downloads that were part of the build. Be sure to virus check as you go and after its done! Downloads from the net are still downloads from the net, and are dangerous even if from a source such as this.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
