Create a flashing lights circuit with a 555 timer and a relay
Picture of Create a flashing lights circuit with a 555 timer and a relay
I'm gonna you how to make a alternating pulsating circuit (using 555 timer) to run a relay.
Depending on the relay you may be able to run 120vac light.
It does not alternate that good with small capacitor(I will explain later on).
Step 1: What you will need.
Picture of What you will need.
-1 5 pin relay (5 vdc)
-Ceramic capacitor(For reducing arcing on the relay)
-1 red LED(optionnal)
-1 green LED(optionnal)
-2 110 ohm resistor(to go with LED)
-10 to 1000 uf electrolitic capacitor
-2 1k ohm resistor
-1 555 timer
-perf board
-wire
-soldering iron
-solder
-wire cutter
Step 2: The Circuit
Picture of The Circuit
The red LED is to indicate power and the green LED is to show the speed that it is pulsing at.
I would suggest using a 330 uf electrolytic capacitor(this capacitor will determent the speed at witch the relay is pulsing the bigger the capacitor the slower the pulsing).
(Small capacitor don't alternate good, they don't give anoff time for the light to stay on.)
Step 3: Now your done!
Picture of Now your done!
I would suggest putting this in a project box.
You can pulse lights, motor and other ,anything you relay can withstand.
afb19662 years ago
Hi Steven, Thanks for the great instructable. Could You tell me how to modify this circuit? I'm using this for a sequential tail light flasher. I need the relay to stay on 3 seconds and off 1 second. I'm assuming just changing cap values changes the both on and off. Thanks in advance
Hi.
I am planning to buld a 10 x 3W amber led bulb night rider type system, with 5 on each side of my 4x4.
Could anyone help by suggesting a good layout as Im kind of new to all this but keen to learn.
I am planning to use a 9V battery by the way.
Thanks.
steven123654 (author)  foxtrotbravoone2 years ago
Here is the circuit you will need to use: http://www.555-timer-circuits.com/knight-rider.html
You will need to add transistor where the LEDs are to power your 3watts LEDs.
I wont tell you how to put the transistors in that circuit do some reasurch on how they work (many good site out there) (here a hit use NPN type transistors)
A 9volt battery wont have the power for your circuit use the vehicles power.
Good luck!
Steve
Hi foxtrotbravoone,
did you build your 'Knight Rider' lights on your 4x4?
Would like to hear about the circuit you used.
If you still interested in building it, let me know.
I have some ideas.
Regards,
Carl
tuscani4 years ago
oye como elecrtonico no se,pero como dibujante jejejeje uffffffff.....
agis686 years ago
try this circuit (but made it for 12V) or do the needed changes This can carry more leds (due to 12V)
suteke agis685 years ago
i need to learn 15 led
agis68 suteke5 years ago
 might works if you put them in parallel...I assume you want to make a "knight Rider" flash light???
Renagade6 years ago
thanx for the instructable! question: can you do this with a bunch of LEDs? you know like making a ring of flashing lights, one lights up at a time.
steven123654 (author)  Renagade6 years ago
LED Chaser?? If so, this circuit can't but there are many on the net.
You probably could with more 555,you should look it up on the net (lots of projects for the 555)
this can make a wave with more LEDs? you know like one turns on while the last turns off?
i dont know
k thanx, i'll check it out _
SurferGeek6 years ago
More pictures and uploading the video to Youtube or other online service.
Cool. You could have a few better pictures, that would be cool, and you might want to embed the video into the Instructable.
steven123654 (author)  GorillazMiko6 years ago
ill try to add more pics
GitarGr86 years ago
I feel like there is a lot between steps 2 and 3 that got left out. Instructables is more about explaining how you built something than just simply posting the schematics. I'd really like to know how the 555 chip works, and the theory behind the circuit's design.
