How to build a clock that projects time on the wall
This Instructable shows you how to build a projector clock. This device allows you to project time on the wall. Based on a small LCD alarm clock (not too small, instead, you won't be able to project it and to work on it), this is a good way to display current time.
Step 1Gather the parts and plan
For this Intructable, the main parts you will need:
An LCD clock with a wide screen (mine also display date and temperature)
A magnifying lens (the one used to magnify pictures for example)
A halogen light bulb
A power electric source to feed your light. I used a 12V 60W light bulb, but the power source only provide 6V, dividing by 2 the provided power. A too powerful source would feeding the light would generate too much heat and burn your LCD display.
A fan to evacuate heat generated by the light in the box
A box that you can easily work out (maybe avoid wood since heat could cause it to burn
Other: electric wires, screws, duck tape, glue and welding iron
Your first and most delicate work is to modify the LCD
14 comments
Jul 4, 2010. 9:29 PMarikyeo says:
instead of "weld" use the term "solder"
Dec 31, 2008. 1:41 PMnewtonn2 says:
Hi there, That's a cool time projector. Have you tried to use a fresnell lens b4 the lcd? that could fix the problem of the black borders. it could give you a even projection. Thank you for your Instructable.
Oct 19, 2009. 4:30 AMarikyeo says:
what's a fresnell lens?
 is there any chance that the halogen bulb will melt the glass?
it happened in real life, and the part that got exposed by halogen light 8 hours a day got 'eroded'
Mar 27, 2009. 11:48 AMLastDevil says:
is that a standard MR16 or GU10? You can get them both in a wider light rather than the 25 direct light that might sort the borders out. Great instructable ;)
Mar 14, 2009. 12:02 AMosgeld says:
i happen to have that same clock (probably in a slightly different case, mines a pen holder, and you can remove the clock, which removes a wall in the pen holder so you leave it in all the time ...) but it seems to be a semi common promo item, its not the first time ive seen it
Dec 21, 2008. 3:39 PMJakeg says:
does anyone know how I could do this with a laptop moniter? If not how can I wire the laptop moniter to a regular desktop. Better yet, both!
Sep 9, 2008. 1:26 PMslimguy379 says:
you know if you used a lcd from a digital camera, and hacked it to have an input you could have a mini lcd movie projector, but this idea is cool as well. keep up the good work
Jun 16, 2008. 2:46 AMawkrin says:
looks nice, but would there be any way to make a kind of glasses with two lcds that act as filters and replace the monitor, move while playing games etc
May 12, 2008. 4:08 PMac1D says:
nice! you can make it for 2$ also, but WAY more cheap. buy a 1$flashlight and a 1$ lcd transparent clock at dolar store. i guess u know what to do after..
May 12, 2008. 4:57 PMgamer says:
You also need to buy batteries and you need to diffuse the light because the flashlight is focused... -gamer
May 12, 2008. 2:22 PMjoejoerowley says:
Cool! Great Instructable! Thanks Joe
May 12, 2008. 2:16 PMLinuxH4x0r says:
Nice! I tried to do this once, but the optics were wrong. Oh well, try 2
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:tonypascal
