3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a clock that projects time on the wall
Step 2Modify the display
Modify the display
Usually, LCD displays used in small clock are setup to be shown from the front. Our device needs to have the light source from behind, in transparence. So we need to modify the screen to let the light go through the display. However, the same could be used in reflection but in this case, the luminosity would be lower:
A typical LCD display is composed as seen on the picture.
The glass screen is placed between 2 polarized filters that orientates the light and allows for the time to be display in black on white.
To let the light go through the display, you will first need to remove the reflecting bottom of the screen. To get an inverted display (white on black), you will then need to remove the second polarized filtered and turn it by 90° clockwork or counter-clockwork, no mater. These two steps are quite difficult since the filter and reflecting surface are strongly stick together and very thin. When removing the filter from the screen, be careful not to damage them.
1 comment
Sep 9, 2008. 1:26 PMslimguy379 says:
you know if you used a lcd from a digital camera, and hacked it to have an input you could have a mini lcd movie projector, but this idea is cool as well. keep up the good work
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:tonypascal
