3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Create a shower spa for a few bucks.
Create a pleasant, rain-like shower "head".
I have tried several different (and expensive!) shower heads, but none of them gave me the spread pattern and coverage I wanted. Doing some other projects with PVC pipe, I hit upon this idea.
Step 1Parts
Parts
You will need:
1/2 inch PVC pipe (12 to 24 inches)
1/2 inch PVC end cap
1/2 inch PVC end connection
Shower hose (standard 1/2 inch connection)
1/8 inch drill bit
3M Command hooks and adhesive strips
48 comments
1-40 of 48next »
Mar 28, 2012. 10:40 AMRich_D says:
I was thinking of doing the same exact thing, and, like many of the other folks, am trying to come up with all sorts of directions and patterns. Now that I've seen this build, I know my plans will work (within my available water pressure limits, of course!) Nice work!
Nov 23, 2007. 9:47 AMrollingstoner357 says:
What about copper if every ones worried about pvc is there anything wrong with copper other than the price
Mar 11, 2012. 12:44 PMtinker234 says:
you could also use steel
Dec 3, 2007. 8:36 PMqwerty90210 says:
it could corrode and turn green like how lady liberty did
Feb 8, 2012. 12:53 PMDoc Holliday says:
Easy, let it corrode to the point you don't like it.
Then wait a bit. If you still have the green part, (you shouldn't), wipe it down with catchup. I do this with a LOT of copper, and it takes almost no time.
I get a nice antiqued look.
Mar 1, 2012. 6:15 PMtinker234 says:
wow i wonder if i could make one that wraps around all around the shower also could i paint it with a a sliver finsh
Jan 12, 2012. 7:20 AMdana-dxb says:
Thats an awesome idea simple yet greet
Im looking who's the lucky one im going to gift im
Dec 5, 2011. 5:39 AMPetar92 says:
Great project!!! Now u can think of making a square out of pvc pipes :)
Dec 3, 2011. 3:28 PMChanio says:
Perhaps I might try to make thinner holes by burning them with a hot needle. And pointing their radius to an imaginary center (where I would be receiving all the water).
I love the water-spay showers! They are like clouds...
Nov 13, 2011. 8:46 PMNelyan says:
If I'd got this on my hands (or on my bathroom), I'd never leave the shower again!!! :D I already spend two hours just with a regular wash up (excluding the hair-wash) because I like standing in the hot, steamy shower.
I also found out recently that when your voice is too sore to sing, you can blow soap bubbles in the shower and watch how the hot air makes them swirl upwards.
"Hey, honeyy, there's something I you need to bring with you from the hardware store next time~! :)"
Dec 3, 2011. 9:28 AMKingSky says:
2 hours? I hope that is a joke. If you have a normal 2.5 gallons per minute shower head you are using 300 gallons of water.
Nov 23, 2011. 5:12 AMda_fisher says:
wow im impressed. i allways had an idea like this but didnt nkow how to connect it tothe shower or the wall. :p
Oct 27, 2011. 3:06 AMacosicris says:
Nice!!! I will try to make one, but a rectangular shape 4-pvc pipe. Connected by elbows.
Sep 19, 2011. 5:55 PMskiddyfisk says:
Another idea would be suspending it overhead by mounting an extra shower curtain rod up there and zip-tying the pipe to that. Plus you have gravity adding a bit of pressure that way.
Sep 6, 2006. 3:58 PMtego_01 says:
i have a question will the command sticky thing really work if you wash the shower/tub
Sep 1, 2011. 12:36 PMkyoumans says:
I had 3M strips and hooks holding things to my shower walls all through college, and I never once had one fall down. Definitely follow the application instructions on the back of the box, but I wouldn't worry about them falling off.
Nov 27, 2006. 10:48 AMcchance says:
my idea is to split this up into 3-4 pipes one in front side and then back and use very small holes and lots of them on all 3 so that it gets to be a fine mist from 3 directions... perhaps 4 if i can put one overhead as well... that would be wicked! In fact i juts got the idea to put a small tank before this with some peltier heaters to heat up the water before it hits the pipe since my main hot water tank isnt exactly the best.... hmmmmmmmm
Sep 1, 2011. 12:33 PMdigitalmonkeyman says:
you could add landscape misters to the pipe!
Sep 1, 2011. 11:39 AMespdp2 says:
FAVORITE! Genius, really. I'm going to make one with several hooks at different levels for myself and my kids!
Jan 6, 2011. 6:56 PMParrhesia says:
Very cool! I'm making one now. I'm going to look for the double shower head connection you've got here, too, as I think this could solve the shiver factor during shared showers. Maybe some LEDs for mood lighting...
There are no boring marriages, only boring people ;)
Nov 27, 2006. 7:44 AMZorlack says:
Beware! There are some important reasons that PVC is not generally used for suppling potable water. Not the least of which is that PVC leaches chemicals into the water when it is exposed to higher temperatures. To protect yourself against this you should use CPVC instead of PVC. CPVC (chlorinated poly vinyl chloride) is safe for use with hot or cold water. -Z
Dec 16, 2010. 8:11 PMdadoffour says:
What about using PTEX?
Jul 12, 2006. 1:12 AMDeightine says:
This is a great introduction for people who have never thought of doing the same. I can only imagine what you could do with a shorter PVC tube (allowing higher pressure water), and a round PVC ball on the end... Heck, with enough work you might be able to take a current shower stall (usually crappy, and made of "space age plastics") and convert it with PVC into an older style shower... For example, some of the rich people in the early 1900s would put up 3 different sets of knobs with variable pressure on each side.
Oct 4, 2006. 11:01 PMtheRIAA says:
"I can only imagine what you could do with a shorter PVC tube (allowing higher pressure water), and a round PVC ball on the end..." ...wait what?
May 18, 2007. 2:21 PMDeightine says:
Apparently that day I was very incoherent, and I don't pay enough attention to my responses ;) What I meant was a shorter tube (allowing fewer sideholes), and a round pvc globe (can't remember where I saw one last, but we used them back in highschool for electrical conduit work) with holes drilled all over it in sort of a pinhead type pattern. Allowing a ~300 degree spray effect from it. The Victorians would build brass shower hookups with 5-6 shower heads arranged all around you, so that when you turned the water on, it hit every part of your body all at once. This design, with some creativity, could probably do that. Only obstacle of course being water pressure reaching all of them without having to put bigger piping all through your water system to accommodate the extra flow.
Jul 10, 2008. 2:38 PMOscelot says:
wiffle ball?
Jul 10, 2008. 6:34 PMDeightine says:
Basically a W(h)iffle ball, yes, but for this purpose with much smaller holes and all of them placed on 2/3rds of the ball facing into the showerer. Though I hadn't thought of comparing it to one. Entertaining suggestion.
Nov 27, 2006. 10:00 AMMindTorm says:
*cough*
Nov 26, 2007. 6:59 PMSlothOnSpeed says:
To remove the attractive lettering on the pipe, simply use a rag or cotton ball soaked in acetone. (I know you said that aesthetics didn't concern you, but you might want to try this) Where do you get acetone? Easy. Cheap nail polish remover. Check the label to make sure it's not the Earth-saving, anti-pollution type nail polish remover and there you go. You can get enough remover for many projects for about a dollar.
Jun 24, 2007. 7:42 PMMr. Smart Kid says:
mmmmmmmmmmm yum yum shower water
Dec 19, 2006. 10:50 AMΩσ porkpie hat says:
I think it would be cool to make four of those and position them in a square around you, that would be amazing
Feb 27, 2007. 7:56 PMsilentdeath says:
that would be great! nice idea i may try it over the summer outside for a shower in the pool house great thing to mod maby some more holes some a little more wat can get on you? reply to this plz
Mar 13, 2007. 12:04 AMsilentdeath says:
so what?i will remember that. reply to this please
Dec 6, 2006. 1:56 AMmrsayao says:
Zorlak is right, PVC at high temperatures give off chemicals, vinyl chloride. PVC is never used in construction to carry water into a building or house, but only out.
Nov 27, 2006. 9:33 AMpascha says:
Why not use a scrap piece of copper pipe? Sure would improve the aesthetics of the project...for a few extra bucks for the brass fittings, but I'd guess it would last virtually forever.
Sep 13, 2006. 11:24 AMMz3FRS says:
Good use of PVC. If you're interested in painting it at all, I have found Krylon Fusion plastic spray paint adheres to PVC very well. Comes in many colors, I got mine at Michaels.
Jul 30, 2006. 12:43 PMpluish says:
very cool, but it looks kinda ghetto with all the white plastic ;)
1-40 of 48next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:impulse94
