Create an action sequence with a series of pictures by radiorental
Featured
It is very rewarding to create an image that conveys much more than what can be captured in a single picture. Whether it is baby’s first steps or an Olympic gymnast, the process at work here is conveying motion in a static image.
Stitching multiple images together is a form of time-lapse photography. You are displaying a change in an object’s position over time. In traditional time-lapse work the output is a video, however here we will go through the steps to place each frame on top of the other allowing the viewer to re-play the action in their mind.
Photo sequencing only works when the object moves across a static background. A dog running through a series of tricks at a show works well, a runner coming directly at the camera does not.
Subjects can be anything from a bird in flight to a snowboarding jump, all you need is a camera with an Action Sequence mode, a computer and the patience to experiment.
Photographer: Ethan Ford
Step 1: Set up your canvass, align the images.
First off you will need a graphics application that can handle multiple layers. www.gimp.org is a free open source application similar to Adobe's Photoshop. You will find some steps much easier if you have a graphics pen. Using a mouse is OK but a little cumbersome. I recommend whatever you can afford from www.wacom.de
Picture yourself with your series of photographs in hand and you start to lay them out on a table. In the digital world this is called the canvass. Create your canvass with a height double that of the image and as wide as all your images end to end. That is if you had 3 pictures, each 800 by 600 pixels then your canvass should not be around 2400 by 1200 pixels. Its fairly easy to adjust this later if you find yourself running out of room, but making it too big might slow your computer down.
Now you will place your images on the canvass. However, instead of laying them all together as you would on a table, they each have their own layer. There is one important rule to follow, place the first image in the first layer, image 2 on the second layer, etc.
If the photographer has panned the camera during the sequence then you need to line up the background. In the example here I used the horizon for vertical alignment and spaced the rider evenly for horizontal alignment, the waves were moving to so I had no other common point of reference between images. Tip: start by aligning image 1 & 2, turn all other images to 'invisible' and set image 2 to 50% transparent. Then move image two around until you are set. Repeat with image 3 at 50% over 2 and so forth.
All lined up, on to the next step, image editing.
asadat says: Feb 13, 2013. 8:31 PM
I am really very much pleased to be acquainted with this type of article which increased my knowledge a lot.I will try to be a regular reader of this writer .
by- www.etunescafe.com
berickson5 says: Oct 26, 2011. 5:58 PM
What do you think about this? Thanks for the help!!
Alex Jalland says: May 17, 2012. 1:37 PM
F-ing Splendid
radiorental (author) says: Oct 29, 2011. 1:23 PM
awesome!!
Tookayo says: May 8, 2011. 9:46 AM
Hope you like this too
radiorental (author) says: Jun 9, 2011. 6:08 AM
again, very cool! it almost looks like he's jumping out of the pool. I guess that's because my mind might correlate the nearest shot to being the last shot, maybe?
animes25 says: Dec 15, 2010. 12:54 AM
hope you like the photo
radiorental (author) says: Dec 15, 2010. 11:24 AM
Very cool, I like the way you've blurred the background to make your job easier. I would touch up the guy's legs on the right just to finish that off.. it caught my eye.
But otherwise - really nice work (o;
JarrydGothix says: Feb 8, 2010. 12:14 PM
I assume this is how skateboarding magazines do it? Very cool.
-insertnamehere- says: Jun 22, 2008. 4:17 PM
this is awesome! I always wondered how they did those type of pictures. I will do this with me doing a backflip into a pool. Thanks for the help!
fungus amungus says: Sep 8, 2006. 10:20 PM
What the? How did this get put up again?
radiorental (author) says: Sep 9, 2006. 6:26 AM
Craft mag contacted me with respect to publishing it, I felt it was not up to O'Reilly's high standard of content so I made some improvements. In doing so, you're hokey 2 bit, steam powered, shoe string and buggy db kept hanging every time you clicked the All Steps button. So I decided to republish it, the older version will be taken down when it suits me. You're welcome.
crankyjew says: Jul 8, 2007. 10:44 PM
"hokey 2 bit, steam powered, shoe string and buggy" hey, thats not very nice...
ewilhelm says: Sep 9, 2006. 11:24 AM
Are you using Firefox on a mac? We've got a bug that causes some projects to freeze Firefox when viewed with all steps.
stasys says: Oct 17, 2008. 9:05 PM
I use firefox it neeeever frfeezes
Aeshir says: Jan 31, 2007. 3:50 PM
Yeah! So get Opera!
radiorental (author) says: Sep 12, 2006. 6:34 AM
Another bug, I cant delete the older instructable, on win/fox
radiorental (author) says: Sep 10, 2006. 6:01 PM
anything less would be backward. Do you need a detailed fault report? or are you on top of it?
trebuchet03 says: Sep 8, 2006. 10:33 PM
iono, that's kinda weird.... perhaps something to do with the recent changes?
amcq says: Jun 24, 2007. 9:36 AM
Good Instructable. Here's an example of a Panoramic Action Image. I actually panned from right-to-left for these images, and there is a slight overlap of each image, which allowed me to use "PanoTools Assembler", or any Panoramic Stitcher program, to put them together, then just had to do some post-processing in Photoshop to make each airplane visible in it's own photo.
Black Jelly says: Apr 22, 2007. 6:42 PM
were is the string hes holding on to?
emericanskater says: Jun 3, 2007. 9:00 PM
its a wind kite used for wind surfing
kennytatheguy says: Oct 28, 2006. 5:01 PM
whoah, when i first saw the pic, i tohught it was a bunch of people riding together... cool
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
