3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Create embroidered patches from digital images
Reproducing digital artwork in embroidery isn't hard if you follow these simple steps. I'll show you how using the fffffatlab text. These and more are available for purchase in the fffffat etsy shop.
Materials and tools:
fabric on which to embroider
embroidery floss
embroidery hoop
embroidery needle
fabric for backing (optional)
sewing machine (optional)
if using dark or opaque fabric the following are also needed:
paper
ballpoint pen
chalk or conti crayon
Step 1Trace your artwork
Trace your artwork
If you're using a light colored fabric, you may be able to trace directly on the fabric. In this case, I'm using a very opaque canvas fabric, so I had to first trace the design on paper, directly from my computer screen. Don't use a drawing implement that requires too much pressure or that will bleed through onto your monitor. A regular ballpoint pen works just fine.
17 comments
Mar 26, 2008. 8:16 AMsabbott says:
Great instructable, you've given me some good ideas. To add to what rusty said, if you have Photoshop elements, there is no "create path" command. Instead you would use Edit/Stroke after using the magic selector tool. You could also create a stamp of an image first, using the tools Filter / Sketch / Stamp -- although it would not be as smooth. But this method would permit creating images from photos of faces, for example, which could be quite interesting. Yeeks, too bad I need to get back to work!
Mar 24, 2008. 11:49 AMAlterscape says:
I've always wanted to learn how to make patches. This Instructable not only explains this specific technique, but includes enough extra links to pick up the basics. Lots of reading material here. Thank you for this content! :)
Mar 21, 2008. 1:29 AMrusty0101 says:
If you are looking for a way to trace from an image that is mostly solid colors, you could use the magic select in The GIMP or Photoshop, then use the function 'create path from selection, which will create a 'path' that follows the border of what you selected. Now create a new layer with a solid white background, then use the function 'stroke path' use a 2 or 4 pixel wide black pencil, to 'draw' the path onto this layer. Print the layer. Then you can use a light table for white/translucent fabrics, or the chalk / crayon (or even correction tape paper) technique to transfer onto other fabrics. Looks good by the way. As an observation, you could use a technique like this to embroider in several colors, The original image includes a drop shadow which you could emulate by adding a quarter to half an inch of a different shade along the right and lower edge of everything you did embroider. Just thoughts.
Mar 21, 2008. 7:18 AMtimderami says:
Another tool one might use to transfer the design to the fabric is a glass cutter. It need not be sharp and does a good job especially on long, sweeping curves. Keep up the good work.
Mar 20, 2008. 7:39 PMm.c.cookie says:
As a founding member of the He-Man Quilting Club and Needle Exchange Sewing Circle I've got to tell you I'm psyched. Nice technique and nice, thorough instructable. Rock on.
Hey computerwiz_222... NICE!
Mar 21, 2008. 1:22 AMplatdujour says:
are you the only member of said club? i could find no info about it on the internet
Mar 20, 2008. 5:33 PMmsthimble says:
Beautifully done! You have made embroidery so modern!
Mar 19, 2008. 6:12 PMcomputerwiz_222 says:
I like to make very tiny "x"'s when stitching computer graphics. I think it is called a crossstitch. Heres some pics of a hackaday one that i started, but never quite finished. What do you think?
Mar 17, 2008. 5:29 PMdonovand says:
It's not as low budget, but you could probably use the pre-chalked paper that is used to transfer sewing patterns to fabric instead of rolling your own. This would be less messy, since the pre-chalked stuff doesn't come off as easily.
Mar 16, 2008. 8:35 AMmikeyk says:
nice instructable. i gotta order some embroidery hoops.
Mar 16, 2008. 10:04 AMchristyturner says:
You should try looking at Goodwill before you order any. Thrift stores almost always have a ton of embroidery hoops, and they're really cheap.
Mar 16, 2008. 12:25 PMNotbob says:
my local one has a rubber,maid container full of them.
Mar 16, 2008. 11:46 AMGorillazMiko says:
Great job, I've been wanting to see an Instructable quite like this for some time, great job! +1 rating. +1 vote.
Mar 16, 2008. 12:49 AMrachel says:
Nice technique! and very well explained. I had honestly never thought of making my own patches but as I'm making a new backpack now I'll have a place to put patches so I may just use this.
Mar 16, 2008. 12:34 AMjamiew says:
siiiccckkk
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
111
Author:bekathwia
