3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Create embroidered patches from digital images
Step 4Create a backing
Create a backing
  • last photo ←
This step is optional as well, but gives a nice finished look to your patch.
Cut a rectangle of your backing fabric with about a 3/8" border seam allowance all around your patch. Press in a 1/4" fold on all sides. Trim the corners at a 45 degree angle passing through the intersection of the two ironed creases. Iron in another 1/4" fold, turning under the first fold you made. Press in the corners so that the edge of the crease intersects the new corner intersecting folds, then press in the sides again. You should end up with nice mitered corners. Place the patch inside this frame and topstitch around all edges for a nice complete patch.
2 comments
Mar 21, 2008. 7:18 AMtimderami says:
Another tool one might use to transfer the design to the fabric is a glass cutter. It need not be sharp and does a good job especially on long, sweeping curves. Keep up the good work.
Mar 20, 2008. 5:33 PMmsthimble says:
Beautifully done! You have made embroidery so modern!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
111
Author:bekathwia
