Create Glass Balls in Photoshop
12,069
185
9
Published
Introduction: Create Glass Balls in Photoshop
Here, i want to show how to make a beautiful glass balls in Photoshop. it can be used in many fields specially if you are a graphic designer. it is simple and doesn't need high designing knowledge.
Step 1: Drow the Basic Shapes
All the complicated shapes includes these three basic : circle, triangle and square. So, start with a circle. Choose your favorite color and size.
To make this circle become a sphere, you should add lighting effect.
Go to  Filter >  Render  >  Lighting effects and do the adjustments like the pictures.
Step 2: Adding Reflects Inside the Ball
Adding some light reflects make the ball more transparent.
Draw another circle right on the top. In the layers set the "Fill" of this layer to 10%. Now, change the dimensions using ctrl+T botton and set it like the pictures. Duplicate this layer to made another circle. Put it to the right or left of your shape.
Step 3: Adding Window Reflection
To make the window , make 4 squares with Rectangle tool. Now merge the layers of the window. Rotate it and make to to appropriate shape by using Wrap tool.
Drag the window to your ball and change the color to white and the Opacity to 60%.
Step 4: Adding Shadow Under the Ball
There are many ways to add shadows in Photoshop. I use this method :
-Draw an oval under the ball
-Drag it to the middle of your ball
-Right-click on the layer and choose Blending option
-Check the drop shadow box and make the adjustments as shown on the picture
Step 5: Finish
Now it is finished.
Design and Show how creative you are.
Enjoy !!!
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    9 Discussions
    This was very nice and well explained. If you can, then please upload more instructables about using photoshop because I found that it was hard to learn use it without any prior knowledge.
    simple and amazing
