Introduction: Create Music Using One Transistor
Picture of Create Music Using One Transistor
Hello every one
I am vignesh raja . Today i make some transistor trick here. It is simple project every one can try it. It uses minimal parts to build. The project is when we touch the piezo electric sensor the buzzer will activate by transistor. Depending upon your touch speed and contact of your finger with sensor the buzzer sound will vary. let us see the output in the video above and then we start the project build.
Step 1: Parts Required for the Project
Picture of Parts Required for the Project
Step 2: Circuit Diagram and Working of the Project
Picture of Circuit Diagram and Working of the Project
Get the detailed circuit connection from above image
Every one knows that transistor can be used as a switching device.
When the voltage present in base then the transistor gets ON. if not the transistor gets OFF.
The operation of the project when the we touch the piezo sensor then it will produce voltage. That voltage goes to base of the transistor. so the transistor get ON and conduct current flow through the buzzer to collector of the transistor and to emitter and goes ground. so the buzzer sounds.
If the piezo sensor is not touched then it doesn't produce any voltage and base of the transistor doesn't get any voltage . so the transistor gets OFF. so there is no current flow in buzzer. hence buzzer doesn't sounds.
i hope you like my project. Built it yourself and have fun. If you want say something about project comment it
Thank you for reading.
Arman5592 (author)2014-10-29
2n3906 can't be used instead of bc547 . 2n3904 can .
vigneshraja (author)Arman55922014-10-29
i tried the circuit with 2n 3904 but it won't work properly but 2n3906 works fine in that circuit as like bc547
nardev (author)vigneshraja2016-05-17
strange, it's NPN and PNP.. can't just replace it
LuísR3 (author)2014-10-29
that would be a nice touch operated switch, just by adding a relay or something.
vigneshraja (author)LuísR32014-10-29
yes it would be a nice touch switch with micro controller to ON and OFF something when it touched.
About This Instructable
1,510views
19favorites
License:
More by vigneshraja:Speed control of dc motor from laptop using arduino and processingProgram Arduino Pro Mini Using Arduino UnoTouch switch for MSP430 launchpad
Add instructable to:
