Create nuclear meltdown victims from existing Halloween decorations. by mntbkrguy
I was inspired to make a nuclear meltdown theme for this years Halloween decorations after finding some old barrels behind the bike shop. But what is scary about a meltdown without the dead bodies. I looked all over the place for related Halloween decorations but there are few if any. I decided to use some old decorations and modify them to fit the new theme.
Edit:
I just wanted to add what else will go into the overall decorations.
The plan is to add what my wife calls my "Redneck Tiki Torch" which is simply a propane regulator attached to a valve and a long brass pipe with a tin can poked full of holes on top. It looks like a big ball of flames on the end of the pipe. in the grass alongside the tank will be an EMPTY, repeat EMPTY oxygen tank with the safety cap on it and another EMPTY CO2 tank. Inside the yellow barrel will be a green light with dry ice making green fog coming out.
If I can find one I plan on having a yellow rotating safety light, like those on top of a tow truck, flashing and that sound of an alarm blaring. (Same as the siren ring tone on the iPhone)
I will have video when it is all done from Halloween night.
Step 1: What you need
Here is what I used but obviously any substitutes can be made.
1) Old decorations, in this case I had an old foam mummy and a cheap Ghoul from Rite Aid that has a motion sensor and noise maker.
2) Duct tape
3) shrink wrap (moving supplies)
4) pieces of foam
5) paint suits
6) rubber boots
7) rubber gloves
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
