Create personalized gift bows
 by Browncoat
Featured
You can create your own personalized gift bows.  You can make the bow a hint about what the gift is, like I did with this bow.  You can put pictures of the receiver and/or giver.  You can make the bow an ANTI-hint.  You could use wrapping paper, the comics, magazines, etc...  Get creative!
If you DO make one post a pic in the comments & I'll send you a badge.  :)
Step 1: Things you'll need
You will need:
*a razor blade cutter or similar
*a ruler to measure & to use as a cutting edge
*scissors
*tape
*stapler
*an image that will still look good when made pretty small
Step 2: Print & cut
You will need to cut strips about 3/4" wide, so find, resize, & print an image (or images).  Then use your razor cutter & ruler to cut your strips.  You're going to need 9 of them.
Step 3: Now cut your strips
You want to leave 3 strips the full length.
Cut 1" off of 3 strips.
Cut 2" off of 2 strips.
Cut one strip to 3 1/2".
Step 4: Figure 8 time!
This is the step that can get a little fiddle-y.  You want to take each strip &, basically, make a figure 8. Use tape to secure each strip.   You need to keep track of the sizes.  Keep the 3 longest strips in a group, the 3 smaller strips in a group, & the 2 smaller strips in a group.  The smallest strip that's 3 1/2", you just need to make a circle with it.
Step 5: Putting figure 8s together
Each set of strips needs to be put together.  I prefer to use a stapler to put the sets together.  Yes, it will fold a curl or 2, but you can reshape them back enough that no one will notice.
Step 6: Now we start making the bow! Yay!
Take your set of 3 biggest strips & put the set of next 3 biggest strips inside.  Staple.
Then, take your set of 2 smaller strips & put that set in the middle.  Staple.
Step 7: Finishing the bow
Last, you want to take your circle made from the 3 1/2 " strip & put it in the middle.  I used tape so no staple would show when the bow is put on the gift.  If you had time, glue might even be better if you have tape that you're not sure will hold well.
Step 8: Personalized bow!
Bam!  There you've got your own personalized bow.  Get creative & wow your gift recipients!  Most importantly, have fun! :)
Terricakes says: May 30, 2012. 8:15 PM
Great idea!
sokamiwohali says: Dec 25, 2011. 9:10 PM
thanks for sharing this. i wish this instructable was around when i posted my robot wrap your christmas gift 'ible!
Browncoat (author) in reply to sokamiwohaliDec 28, 2011. 4:33 PM
Yes, one could def put the cute lil' robot on these bows! :)
bovinize says: Dec 26, 2011. 10:14 AM
Great idea!
sunshiine says: Dec 23, 2011. 11:04 PM
Thanks for sharing! This is quite pretty!
Sunshiine
Browncoat (author) in reply to sunshiineDec 24, 2011. 9:31 AM
Thanks! :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
