3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Create your own operating system!
Nearly every true computer geek has, at some point, wanted to write an operating system. However, writing a custom kernel and other bits takes years of study, experience and patience. If you intend to keep your sanity, then the best course of action is to use someone else's code.
Cosmos*, or C# open source managed operating system, is a pre-made kernel that provides you with "OS legos" that allow you to quickly and easily create your own operating system.
You will need:
@ Microsoft Visual C# 2008.
@ A knowledge of the C# programming language (don't worry if you don't have this, it's a pretty easy language).
@ The Cosmos user kit (milestone 4).
Step 1Getting the software
Let's do a run down of the necessary software mentioned earlier.
Microsoft Visual C# can be downloaded free if you get the express edition. You can download it at http://www.microsoft.com/express/downloads/ You can also download the entire Visual Studio including visual basic and visual c++ as an ISO image (these can be tricky, see below for details on reading ISO images). Even on a blazing fast computer, downloading visual studio will take two hours at most, though.
WARNING: make sure that you get the 2008 edition and not 2010. This may seem backwards, but the Cosmos user kit has yet to support 2010.
The cosmos user kit is the platform that we will write our OS in. It's an all-in-one micro-kernel operating system that is written in 100% C#. You can download it at http://cosmos.codeplex.com/releases/view/35194
A note about ISO images:
If you opted to download the entire visual studio, then you're going to need to read the ISO image file. An ISO image is a map of a virtual DVD, using the same encoding as any other disk. You have two option: Use a program like nero or roxio to burn the image to a CD-ROM then insert that disk into your computer and download it (The latest Windows XP comes with Roxio, and Windows 7 comes with Nero pre-installed. Other than that, you will almost certainly find something on your computer that will burn a CD. Explore a bit), or you can use Daemon tools lite edition to read the file directly.
Daemon tools lite is free and can be found at http://www.daemon-tools.cc/eng/downloads
A: After downloading it, running the setup program, and re-booting, fire up Daemon tools and click Add File (the picture of the CD with a plus sign).
B: Find the image, and open it.
C: Now, select the file and click Mount. A popup (see pic')  will show you some options, click "run setup.hta". This will install Visual Studio. Alternatively, you can find setup.hta in the virtual drive that was created, located in My Computer under Devices with removable storage.
9 comments
Dec 23, 2011. 9:53 AMsci4me says:
Alrighty, so I am trying to use Visual C# 2010 Express with the newest version of Cosmos. So it works, but when I build it, I get an error. And that's with the default code! I did add refrences to Cosmos.Hardware and all that and it still doesn't work! The error is about Cosmos.Hardware.Hardware... cant find it? Do you know of any way to fix this? If I use MS4 is 2008 Express, it works like a charm. But I want to use the newest version! Any ideas? Also, thanks for a great tutorial! It helped a lot! :)
Mar 27, 2011. 11:17 AMskatergirlcat says:
hey dungeon runner or anyone else i cant enter the link to cosmos dose anyone have the file???
Jan 10, 2011. 2:34 PMimBobertRobert says:
can you do it in notepad or notepad++ ? you can write BASIC in there.
Nov 29, 2010. 9:50 PMGuard13007 says:
This is interesting, but I've heard from many in the business that C# isn't a good language to use. Do you know of some good example codes in C/C++?
Aug 21, 2010. 11:32 AMaccount3r2 says:
There is periods after the links. you have to get rid of them
Aug 11, 2010. 10:33 AMPS118 says:
Why not just use Linux? It's a real OS, you can see the source, and you can acutally run stuff on it! Oh yeah, and if it's the ability to play with it inside Windows, that's attractive, google CoLinux.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:dungeon runner(A Billion Tiny Gates)
What's to say? A student, a writer, a builder, all the many hats of which I don. A person is not a person until someone tapes on a label, you know. My life is adventure, my interests are many, my fedo...
more »
