Introduction: Create Your Very Own Widget
Picture of Create Your Very Own Widget
This Instructable will teach you how to create a basic Yahoo! Widget. By the end of this tutorial, you will have learned some JavaScript and XML.
Step 1: Getting Started
Picture of Getting Started
Some tools you will need to make a widget are:
- A computer with Mac OS X or Windows Xp/Vista
- A text editing program. (Notepad is perfect.)
- An image editing program. (Microsoft Paint is fine.)
- Patience and time.
- Yahoo Widgets
- Widget Converter Widget
Once you have these programs and widgets, you are ready to move on to step two.
Step 2: Creating Folder Structure
Picture of Creating Folder Structure
Now you will need to create the folder structure to house all the files that make up a widget.
The structure looks like this:
-Widget Name
Contents
Widget.kon
Main.js
Resources
All of the images the widget will use
You can download this widget to automatically create the folder structure
Structure - Reinier Kaper
Set the preferences of a widget by right-clicking on any part of it, and click on preferences.
Change the preferences of Structure to the following:
root: Navigate to your widget folder. (Located in 'My Documents' on Windows)
Now you can click on the widget and a dialog box will pop up, asking you for the name of the widget.
Step 3: Creating All of the Necessary Files
Picture of Creating All of the Necessary Files
We will start with creating the widget.xml file, which tells the widget engine information about your widget.
Download a template a have created for you to use. Download link below. Place the file in the 'Contents' folder located in the folder titled the name you chose earlier. Open the file with the text editor of you choice and replace YourNameHere with your name. Save and close.
Next we will create the .kon file which is the main file that tells the widget what to do. The .kon file is just an XML file with a renamed extension. Download this basic widget.kon file and also place it in the 'Contents' folder. Again, open up the file with a text editor. The first line signifies that the file is an XML file created with the UTF-8 encoding. The next tag to add is the widget tag; <widget>
Then you declare your settings, like debug; <settings><setting name="debug" value="on"/></settings>. Now you are ready to add your window elements; <window>. Widgets have multiple objects that do certain things and have certain properties. For example the text object,<text ..../>, creates text. Here are a list of some of the properties of the text object:
-name (self-explanitory)
-window (depreciated)
-data (text to display)
-color (self-explanitory)
-size
-font
-hOffset (a.k.a x)
-vOffset (a.k.a. y)
-width
-height
With that said, let's start coding. Add the following code to the kon file, in the <window> tags:
<text>
<name>myText</name>
<data>Hello World!</data>
<color>blue</color>
<font>Arial</font>
<size>18</size>
<alignment>left</alignment>
<vOffset>25</vOffset>
<hOffset>2</hOffset>
</text>
In english, this sets up a text object named myText, that displays "Hello World!" in font Arial, color blue, and size 12.
Save your kon file, and continue to step four.
Step 4: Rejoyce!
Picture of Rejoyce!
Double-Click on the kon file and your widget will load. Congratulations! You have created your first widget. But we're not done coding yet. Your probably thinking, "That's all?", right? Continue to step 5 to add some function to your widget.
Step 5: Adding Function
Picture of Adding Function
Now we are going to make the widget display the current time. This will require a timer that updates every minute, and another file. The next file will be a JavaScript file, that will go in the 'Contents' folder.
Open your text editor and create a file called main.js. To add the time, we will use "the Date object". To setup the date object, you create a function. Add this function to the js file:
function updateText()'
theTime = new Date();
theHour = String(theTime.getHours());
theMinutes = String(theTime.getMinutes());
myText.data = "The time is: "+ theHour+":"+theMinutes;
print('update');
Your widget will not show the time yet, because it doesn't know what to do with the js file. To take care of this, we add this event handler to the Kon file, in the <widget> tags but not in the <window> tags:
<action trigger="onLoad">
include('main.js');
</action>
To make the time update, we need to create a timer, which goes in the Kon file, in the <widget> tags but not in the <window> tags:
<timer name="myTimer" interval="1" onTimerFired="updateText()" ticking="true"/>
Save the files and load the widget. It should show the time. If it doesn't work, download both the kon and js from below and replace with the old ones.
Step 6: Summing It All Up
Use the widget converter widget to convert the widget to a .widget file. NOTE: Drag the folder that is titled the name of your widget onto the converter, not the kon file. If you want to go even further with your widget, grab some resources here.
Here are a list of things that you can try to accomplish with your widget:
-Add preferences to control the font using the <preference> tag, and the <type>font</font> sub-tag
-Add some event handlers like onClick using the <onClick> or <onMultiClick> tags.
-Display an image from a local file using the image object
Hope you found this tutorial useful and you will enjoy the endless possibilities of widgets,
Hunter
phant0m_sp00f3ra (author)2009-03-20
i was about to follow this guide, but i found that my leopard MbP has dashcode so it was fairly easi making my own widget :P
Yeah, some people wish there was something like dashcode for yahoo! widgets.
jegreene (author)2007-12-31
Incorrect, if read Clearspring's site, you will see that it has implemented Desktop Support for Widgets Which shows support for windows, yahoo, and apple. I haven't implemented it yet, but from what I have read it will still be quite useful.
hunter890 (author)jegreene2007-12-31
Oh. I get you now. Glad you found the tutorial useful.
Followed the guide, it was extremely helpful. After I built my widget I implemented some widget analytic tools so I could track my widget across the web. I searched around for free services that did it, and found Clearspring. Here is a document about widget analytic its quite informative. If your interested you can just make an account and use their service.
jegreene (author)jegreene2007-12-31
Widgets are a small piece of code that can be inserted into a website, similar to a youtube video. Its perfect for users who don't know how to code, but found a simple program they want on their site.
Megax29 (author)2007-12-29
what is a widget for?
hunter890 (author)Megax292007-12-30
Whatever you wish it to be.
xtank5 (author)2007-12-29
This thing is for Mac right?
hunter890 (author)xtank52007-12-30
It's for mac and pc
GorillazMiko (author)2007-12-29
Awesome, great Instructable, good pictures, files and all, nice job.
hunter890 (author)GorillazMiko2007-12-29
Thank you. Glad you liked it. Did you actually try it out, or did you skim through it? Hunter
GorillazMiko (author)hunter8902007-12-29
Skimmed through it, might try it out soon.
About This Instructable
10,065views
18favorites
More by hunter890:Create your very own widget
Add instructable to:
