Creating a Minecraft Bukkit Server
8,162
10
4
Posted in TechnologySoftware
Introduction: Creating a Minecraft Bukkit Server
Hello my friends in this instructable i am gonna show you how to create a bukkit server,This is my first instructable
Step 1: Download Bukkit
First of all
Download CraftBukkit at http://dl.bukkit.org/downloads/craftbukkit/
Put it where you want
Then name jar as craftbukkit
Step 2: Batch File
Windows:
Open a notepad and type:
java -Xmx1024M -jar craftbukkit.jar -o true
PAUSE
(Not with lines!!)
and save name as run.bat and place it where your server is
Step 3: Setting Up Server.properties
Open run.bat
When console say something like that:
Done(726,5 or whatever)Type ? for help
Type "stop"(without parantahses)
In your server folder there is something called server.properties
Open with notepad
Find ip=
And do ip=write your own ip here
Save and close it
Step 4: Done!
Open run.bat
İt's opened whenever you type
stop
server will close
Step 5: Troubleshooting & Tips
Troubleshooting
Error:Unable to access crafbukkit.jar
Fixing:You didn't rename jar rename it as craftbukkit.jar
TİPS
You can load plugins to bukkit servers!
Download plugins at:
http://plugins.bukkit.org/
When you download the plugin jar put it in to plugins folder
Thank You For reading this instructable I'll change it later
    • Microcontroller Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    When I click the run.bat at the end It has a ton of words then Users/abe and junk then it says PAUSE, after that it says Press any key to continue . . . and I do not get any folder called server.properties
    You have to restart your pc James and then you can rename it
    when I try to rename the .jar it says that the action cant be completed because the file is open in java. Close it and try again. I closed all the programs that were using java and it still doesn't work! HELP!
