Creating Circuits Using the Silhouette Portrait
3,094
42
6
Posted in TechnologyElectronics
Introduction: Creating Circuits Using the Silhouette Portrait
About: An educational nonprofit in west Baltimore, we run a shop where you can borrow tools, learn to use them, and collaborate with other nerds IRL. Find us on facebook or twitter and peruse our member projects!
Today we will be creating circuits using the Silhouette Portrait. While this may not be all that practical, it is an excellent introduction to circuit-board layout. Sort of a "My First PCB" if you will.
Materials:
  • Silhouette Portrait plotter
  • Foil tape (available at any auto-parts or hardware store)
  • Electrical components to populate your circuit
  • Non-conductive substrate (aka foam or cardboard)
Step 1: Step One: Design Your Circuit
We started by sketching out a circuit by hand. To keep things simple, we chose a basic LED circuit, with a battery, LED, and a current-limiting resistor.
We then laid out a path for the Silhouette to cut. We chose to use CAD software, although it would have been easier to do it in msPaint. The silhouette software has a very good edge-tracing algorithm which will create the paths from your shapes.
The important part to remember is to leave gaps in the circuit where you want your components to go. The battery symbol has a built in gap, and we added small gaps in the LED and resistor symbols too.
Step 2: Step 2: Cut!
We had to experiment with the cut depth and trace (conductive path) width, but the Silhouette was happy to cut through the foil for us. We even dialed it in so that the cut didn't slice all the way through the backing material so we could peel it up easily.
Step 3: Assemble!
First, transfer your foil paths to the substrate (styrofoam). A layer of masking tape overtop the cut-out pieces (similar to transferring decals) would help for complex designs, but ours was simple enough to transfer by hand one piece at a time.
After that, stab the legs of the components through the foil tape into the foam, and voila! the circuit is complete! After just a bit of jiggling our circuit worked too!
Of course, there is plenty of room for improvement:
  • Conductive glue for a more solid component-tape connection.
  • With thicker tape, you could even solder parts on.
  • Adding a narrow section for built-in fuses (though perhaps not on flammable substrate)
  • Multi-level circuit boards could be built by sandwiching layers!
  • Practically, this would be very useful in creating on-glass antennas.
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    6 Comments
    Damn, I can see myself using this for practical reasons. Thank you!
    Any info on how much current I could run through on something like this? Of course it depends on the circuit "wire" width, but a pointer would help.
    Well run some tests this Wednesday! ... You know, any excuse to set things on fire.
    It seemed to be more sensitive to voltage (perhaps a wattage concern?) than current. We shorted a 12v 1A power supply through a 1/8" trace and didn't see any problems.
    So we turned it up to 18v 3A and it set the Styrofoam on fire, even on a 1/4" trace... the weak point was the foam and not the foil though. If we ever find a good load we'll retest to get some better numbers.
    You went the extra mile here for me, thank you!
    The numbers seem good for the uses this could be useful for, like integrating circuits in, say, greeting cards.
    I am now wondering if there's such a thing as copper tape and where to get small flat, paper thin LEDs to try some stuff out. (:
    So damn cool
    I love this idea! Great way to help introduce people to schematic symbols!
