Introduction: Creating Custom Pencils in LectureNotes on the Samsung Galaxy Note 10.1
Picture of Creating Custom Pencils in LectureNotes on the Samsung Galaxy Note 10.1
Today we're going to create a custom pencil in LectureNotes and show some quick access features for modifying those customizations.
Step 1:
Picture of
First select 'settings' from the app's drop down menu (three vertical bars, on top right).
Step 2:
Picture of
Under the Tools menu we are going to check the option for 'Quick Custom Pencil Settings'
This option will allow you to double tap custom pencils in the pencil toolbox, and make changes to each pencil individually.
Step 3:
Picture of
Now open a new or existing notebook. In the notebook double tap the pencil icon to select 'Custom Pencil Settings'
OR
If you have the Pencil Toolbox enabled, simply double tap one of the custom pencils to modify it's settings.
Step 4:
Picture of
Image 1
In the custom pencil settings dialogue we can choose any of the pencils to modify. I have number 10 chosen here, which I have made into a highlighter.
Line width: sets the pencil width
Alpha: sets the transparency
Softness: sets the intensity
Use the color wheel to modify the color options.
Pencil is pressure sensitive: will choose width and intensity based on stylus pressure
Pencil is velocity sensitivewill alter the intensity based on speed of the stylus
Pencil does not leave round but flat end: when checked you will have flat ends, good for highlighting, when unchecked you will have round ends
Pencil does not draw in front but behind other color: While I don't have this option checked myself, this is very helpful for the highlighter custom pencil. This feature forces this pencil to draw underneath other drawn writing and objects, thereby not obscuring the item it is highlighting.
Pencil is eraser: negates all but the line width, and makes the pencil an eraser
Image 2
If you have the pencil toolbox enabled you can double click a custom pencil and edit only it's settings the same way as the previous menu.
ZheT (author)2015-07-08
Hi milessthomas,
Thank you for all this help. I have difficulty to find a feature that lets me to insert a line or two of a text inside a larger text of several pages. Could you help me with this?
Thanks,
Eugene.
milessthomas (author)2015-03-19
Hi Simon,
Unfortunately, I use this app on the Samsung Galaxy Note 10.1. Although, I do have a similar issue with the menu bar, for which there are a few solutions.
Disable the back button:
Go to Settings > Display > System and Status Bar (bottom of page)
and check mark the "Disable back key" option.
On rooted devices only, hide the menu bar:
and check mark the "Hide system bar"
Hope this helped!
eagel99 (author)2015-02-17
Hi,
I have a problem using leacutenotes on sony z tablet.
When i use "zoom box" to input handwriting, i put my hand rist on the screen and it press the home/back buttons, that cause the app to be minimized.
Do you know any setting / option how to avoid this?
Best Simon
About This Instructable
4,833views
3favorites
License:
Bio: Hi folks! My series of tutorials was originally created for the first generation Samsung Note 10.1. I no longer use this tablet, so I ... More »
More by milessthomas:Working with County NamesCreating Custom Pencils in LectureNotes on the Samsung Galaxy Note 10.1Add a Annotation Layer to PDF in LectureNotes on Samsung Galaxy Note 10.1
Add instructable to:
