3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Creating Printed Circuit Boards with a INKJET Printer
When I first started looking into how to etch my own printed circuit boards, every Instructable and tutorial I found used a laser printer and ironed on the pattern in some sort of fashion. I don't own a laser printer but I do have an inexpensive inkjet printer.
This Instructable will show you how to use your inkjet printer to etch your own printed circuit boards, as well as be able to display a printed component footprint on the top side of the board giving you a professional looking design.
CAUTION:
  • For this instructable you will be working with chemicals and power tools. Please wear appropriate protective wear. i.e. goggles, latex gloves, etc.
  • The chemicals used in this instructable will stain clothes and your skin.
  • DO NOT pour chemicals down your drain. Properly dispose of chemicals according to your local waste management.
  • Chemicals used in this instructable will eat metal. i.e. your copper plumbing pipes, metal sink, etc.
Why would you want to etch your own printed circuit board from home? For one it can be cheaper than sending your boards out to a fabrication company. The second reason is if you are planning to send your boards out to have them professionally done, by printing a few prototypes at home to test first will save you money! Nothing like getting your boards back in the mail to find out you had something wrong with your design!
Step 1Equipment and Materials
REMINDER: DO NOT use anything metal that will be in contact with the chemicals. You want plastic, plastic, plastic...
Tools:
  • Dremel
  • Various sizes of drill bits
Chemicals:
  • Nail Polish Remover
  • Copper Etchant - available at Radioshack.
  • Positive Photo Resist Developer - available at various online stores. I purchased from Parts-Express.
Hardware:
  • Daylight fluorescent bulb - available at any Lowe's
  • (Optional) Crock pots - I picked up two small crock pots at a thrift store for $2.00
  • Clear sheet of Acrylic around 8x10 in size
  • Start/Stop Timer (picked on up at the 99 cent store)
  • Plastic containers. Large enough to hold the size of your circuit board. I found some plastic paint trays at Lowe's for $1.00 each
PCB Items
  • Presensitized PCB board - I purchased from Parts-Express (they have various sizes, and even double sided versions)
  • 3M transparency film for Ink Jet Printers (this is a key component, the surface is textured, otherwise your ink would run off the sheet)
  • Grafix Rub-onz sheets - I purchased from Hobby Lobby
56 comments
1-40 of 56next »
Nov 11, 2009. 11:17 AMals_liahona says:
What do you use on the dremel for cutting the boards?
Do you drill the holes prior to etching?
Thanks!
Jan 29, 2012. 6:37 PMfiearo says:
I use a paper cutter like schools use. It makes a decent cut but don't use it on paper any more. I got mine from Harbor Freight Tools for $14.
Nov 12, 2009. 11:16 PMals_liahona says:
Thanks much!  I tried using my scroll saw on a board and while it worked, the friction nearly caught the board on fire.  I'll try a dremel router bit.
Apr 5, 2010. 8:45 PMFoxau2 says:
When you use the rub onz film, does it apply a continuous film across the entire surface? Or does it only apply exactly what you printed? My question is just, could I use these rub onz sheets to create my first circuit layout so i don't have to use the photochemical process, instead using this to do something similar to using a laser printer with photo paper that you iron the design on?
May 14, 2011. 1:50 PMAgentClank says:
I'm afraid not- the PCBs are made with a piece of plastic/fiberglass and a layer of copper on top, coated in a photo resist layer that is resistant to corrosive acid. When black is printed on top of the photo resist, the covered portion of the photo resist is not exposed, and so stays active. However, the uncovered photo-resist layer is deativated under light, as it does not have any black covering, and so cannot protect the copper from corrosion (if this makes sense!).
Dec 8, 2010. 2:29 PMcoleyy says:
how do you make the zip file make the pdfs???????????????????????????
Jan 3, 2011. 4:58 PMbleh.bleh says:
you have to move it or copy it to your desktop
Dec 9, 2010. 5:16 PMcoleyy says:
i mean aftr i get the ps files, i double clicked them and it asked me what program to open it with. i tried every one but none of them worked
Jan 3, 2011. 4:13 PMThe Incredible IT Maker says:
i think you right click and click extract
Dec 8, 2010. 2:03 PMcoleyy says:
can you just use grafix rub-onz to put the pattern on the pcb?
Sep 30, 2010. 9:23 AMjackdi says:
Great & innovative ideas! Thanks.
- Jack -
Jan 31, 2010. 2:48 PMplanet sutcliffe says:
Yes very good, I will try this at some point, still veroboarding for the time being; nice to know I can use the inkjet in the future though. Thanks!
Jan 30, 2010. 2:08 PMShadyman says:
+1 Ingenuity!
Jan 30, 2010. 2:07 PMShadyman says:
So THAT's what that stand thing is for! Epic. Thanks!
Nov 13, 2009. 10:07 PMPyromaniacDaniel says:
I have a printer designed to print on CDs. the CD goes in this tray thing and then it passes through the machine. I wonder if there is a way to sub the tray for a PCB board and print directly on it and if that would be enough to keep it from etching? I don't know how well it would like printing on metal but who knows might work.
Nov 13, 2009. 10:20 PMPyromaniacDaniel says:
HA! what do ya know someone else already came up with it. And its the exact same printer I have.
hackaday.com/2009/09/02/direct-to-pcb-inkjet-printing/
Nov 5, 2009. 11:57 AMtechnicaldude says:
Hi, would you specify the wattage of your bulb please?  Thanks.
Nov 12, 2009. 10:26 AMtechnicaldude says:
Thanks a lot!
Nov 6, 2009. 8:00 AMbrunoxyz says:
 awesome tutorial,  it really makes me want to build a circuit board for something.....        too bad I don't know much about electronic circuits.
Oct 31, 2009. 7:00 PMjohnpombrio says:
Well, the traces are there anyways. I would assume that some drilling would be necessary at some point to actually use the PCB! As drilling usually causes some lifting of material as the drill bit removes the debris, I wonder how much chance the pad would lift or break. For one of's, this looks like too much work. Breadboarding or wire wrap sounds more reasonable.
Nov 5, 2009. 10:29 AMstoobers says:
Believe it or not, you can skip drilling the holes!
Instead of little circles, make little square pads with no holes.  Then, snip the legs off some component sockets and solder the sockets to the pads.
After the sockets are tested for conductivity, insert the chips into them.  LEDs and capacitors can be soldered directly to the little square pads.
I use the sockets because sometimes I mess up and melt things.  Sockets are usually cheaper than the chips.  You can make double sided boards this way, and connect the two sides with a little hoop of wire, if needed.
The only problem doing it this way, is the glue under the pad can overheat the the trace can lift off the board surface.
I am trying to find some way to use a conductive glue, so I can skip the soldering phase, as it is hot and stinky.  I'm not sure if there is a SMD glue or not.
Nov 5, 2009. 6:08 AMHerbie says:
The trick for successful drilling of vias (the through-holes for component parts) is to use the correct carbide "bits" and to use high RPMs.
The correct bit isn't really a "drill", it isn't the regular fluted drill bit, it looks more like a router bit (but very small).  The flutes on a regular bit are what "pull up" on the material and might lift the pads.  The router bits aren't as efficient as moving the debris, but they don't lift pads either!  I got a graduated set of bits from my local electronics place for $10 or so.
These bits also require high RPMs.  Much faster than my drill press can spin.  Fortunately the size of the shank matches perfectly to a Dremel tool.  The first few boards I etched were drilled "by hand" just holding the dremel, but I purchased the dremel "drill press" holder since I was doing enough boards to justify the expense.
Nov 5, 2009. 10:57 AMjohnpombrio says:
Good solution Herbie! I know the kind of bits you are talking about and makes good sense. Thanks!
Nov 5, 2009. 10:57 AMZybeon says:
I don't use the copper etchant from R-shack anymore. You can make your own etchant much cheaper using two items. Using one part muriatic acid and two parts peroxide. There is an instructable on how to make it in here somewhere. It takes a bit to maintain the solution but with a little care and practically no money, it can be used almost indefinitely.
Nov 5, 2009. 9:57 AMkea says:
Hi, Folks I use A commercial program lite version PCB3 from England.
I pint the circuit with a laser printer & use Kinsten Positive acting presnsitised board. Exposure by light box useing  compact UV flouro tubes for 10 minutes on a 4 by 4 board. I am in the process of building another light box which will be shallower & have 2 tubes. Etching upuntill this time I have used Ammonium Persulphate which is slow & has to be heated. This method I have found to be 100% reliable unlike the iron which does not take completely at times.
I also intend to try Hydrogen Peroxide with Hydrochloric acid or solder flux easy to get. This I think was picked up from Instuctables.
Cheers guys Kiwi John
Nov 5, 2009. 7:51 AMmikej_w says:
Just a couple of notes:
you have the holes showing on your resist pattern, which is vital to get the drill to center.
Usually you would drill a couple of registration holes on the board before exposing the first side, so that the other side can be placed correctly afterward. I didn't see how you did that, but you must have because you had good results :)
Oct 30, 2009. 10:15 PMeli2k says:
Thank you for writing up the tutorial! I'm unfamiliar with PCB boards in general, but on the third image in step 2, it looks like most of the board is copper (like the area where you placed the graphics in)? I thought the traces would only be connected to the holes where you place components in. It looks like it would be easy for solder to end up on there and cause short-circuits? Unless I have it all backwards somewhere.
Nov 5, 2009. 6:37 AMjlew says:
You would want to connect your ground plane to the ground of the circuit.  Otherwise it is floating isolated from the circuit.  Very nice looking boards!
Oct 31, 2009. 10:01 PMeli2k says:
Ah, I see. Thanks for the explanation, that makes sense because on kits and PCB boards with the holes already in them, the solder stays inside the metal pad and making a solder bridge between two of them is pretty hard without a wire.
Can you reuse the chemical, ie store it between uses, or you have to use it during that day?
Nov 1, 2009. 3:09 PMmad_mat says:
Awesome 'ible ArduinoFun, nice work.
Just to clarify for eli2k; its best to store used ectchant separately, dont put it back in the bottle with your new stuff.
And just adding a bit more new etchant to used etchant doesn't really make it work faster, it just makes more used etchant ;-)
Cheers
Nov 5, 2009. 5:00 AMTopJimmy says:
Good article.
I have been looking for a method for using an inkjet instead of laser.
I saw that J-Tron had a sale of PCB chemicals last week.
www.j-tron.com
Will have to give this a try and see how it works out.
Thanks & Best Regards,
Oct 29, 2009. 10:49 AMNerdz says:
Grafix Rub-onz? Ive never heard of that, and your silkscreen looks A LOT better than how I do it. Can you use different colors other than black for the Silkscreen? If So, that would be sweet!.
1-40 of 56next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:ArduinoFun
