Step 2Designing Your PCB Files
Once your design is finished you need to print it out to size. Since this is the bottom side of the PCB, make sure you do a mirror print.
If you are using Eagle Cad, I have attached a zip file containing the CAM print job that will print your files out for you. It will make two .PS files one for the solder side, one for the component side and will also make your solder side mirrored. Once you have those files, you double click on them and it will make two PDF files that can be printed.
TIP for APPLY TEXT and Graphics
If you want to include any text on the copper side or a silhouette of an image the best way I have found is to open the .PS file in a graphics program like Adobe Photoshop. Keep the resolution of 300 dpi. You can then added textual or graphic elements to the design and they will come out crisp. You won't need to reverse the text either since the copper traces, etc. are already mirrored.
home_camprint.zip690 bytes| « Previous Step | Download PDFView All Steps | Next Step » |
You can remove all the copper and just leave the traces going from component to component. It all depends on the person. I like to etch less copper away so I don't have to use up a lot of the chemical.
Likewise, when you design your PCB you could make the area between the traces wider and then you would still etch less copper.
Can you reuse the chemical, ie store it between uses, or you have to use it during that day?
Just to clarify for eli2k; its best to store used ectchant separately, dont put it back in the bottle with your new stuff.
And just adding a bit more new etchant to used etchant doesn't really make it work faster, it just makes more used etchant ;-)
Cheers
