3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Creating Printed Circuit Boards with a INKJET Printer
Step 4Prepare Your Component Footprints
With this step you are going to use the Grafix Rub-onz sheets. This time, I opened the component .PS file in Photoshop but created a 8.5" x 11" image at 300 dpi. I then created another grid and pasted the component footprint layout onto the sheet over and over again. The extra space down the side I placed some small copies of my blog logo.
When you print, make sure you mirror this image as well. The reason this image gets mirrored is because you will turn the sheet over, and then rub the bottom side to transfer the image to the top side of your PCB.
Follow the manufacturers directions that come with the Grafix Rub-onz sheets.
3 comments
Apr 5, 2010. 8:45 PMFoxau2 says:
When you use the rub onz film, does it apply a continuous film across the entire surface? Or does it only apply exactly what you printed? My question is just, could I use these rub onz sheets to create my first circuit layout so i don't have to use the photochemical process, instead using this to do something similar to using a laser printer with photo paper that you iron the design on?
May 14, 2011. 1:50 PMAgentClank says:
I'm afraid not- the PCBs are made with a piece of plastic/fiberglass and a layer of copper on top, coated in a photo resist layer that is resistant to corrosive acid. When black is printed on top of the photo resist, the covered portion of the photo resist is not exposed, and so stays active. However, the uncovered photo-resist layer is deativated under light, as it does not have any black covering, and so cannot protect the copper from corrosion (if this makes sense!).
Oct 29, 2009. 10:51 AMjeff-o says:
Now THIS is something I haven't seen before!  Excellent idea!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:ArduinoFun
