Step 7Etch Your PCB Board
I used my Dremel and a router bit to cut out the 8 circuit boards off my 4"x6" panel. Next you will want to pour the copper etchant into a PLASTIC container and then gently rock it back and forth until all the exposed copper has been removed.
TIP: This is where the crock pots come in handy. If you use the etchant at room temperature it will take some time to fully remove all the copper. However, if you heat the etchant up, the process is a LOT quicker.
If you use the crock pot method, make sure you have good ventilation. This stuff smells bad heated, and don't inhale the fumes when you lift the lid of the crock pot!
Make sure you wear latex gloves and old clothes. The etchant will stain your clothes no matter how careful you think you will be.
Do you drill the holes prior to etching?
Thanks!
