Step 8Applying Graphics to Your PCB
Now comes the tricky part. Cut out one of the Component side graphics that you made earlier. You will place this inkside down on the top section of your PCB. (Make sure both are going the same direction, in my photo they are not. I did line them up correctly but when I took the photo I was holding the rub-onz wrong).
The Grafix Rub-onz are on a light colored material. To make things easier to line up, I used a small light board and laid the PCB down on it. Then when I had the rub-onz close to the PCB I could see through it which enabled me to line up the holes.
TIP: If you don't have a lightboard... you can take a cardboard box, cut out the bottom, place a piece of plexiglass on top, and a lamp underneath it.
Once you have the rub-on in place, take a Popsicle stick and start rubbing firmly over the back. Peel off paper and your footprint design will be transferred to your PCB.
You are now finished!
You could also use a hobby screen printing kit for this process, but that is a whole other Instructable.
comments
Add Comment
achollowell
says:
Add Comment
