Step 11Coating the foam and painting
The product I used to cover Sammael with a "skin" is Plasti-dip. Liquid latex would work in a similar way. Using a brush, coat the entire outside surface of the costume. It may take a few coats to get a decent surface. If using liquid latex, you can also mix it with acrylics so you get a base colour other than white to work with. Be sure you are working in a well ventilated area when coating your costume! Both Plasti-dip and latex are very smelly and are unhealthy to work with in confined areas.
Once you are happy with the skin, you can go ahead and start painting the entire costume with an airbrush. Start with a flat base coat of one colour, then start adding highlights and details to improve the look of it. Once you're happy with everything, give it a coat or two of matte spray sealer. If you have done tentacles, once you paint and seal them you can sew them to the costume.
Add Comment
