Creating a S.L.A.C.K. by ElgerJonker
Featured
Step 2: Required tools
This tutorial uses a lot of power tools. Be sure to be familiar with these tools and that you’ve had proper training or education before using them. They can do a lot of harm if not handled correctly. For example: make sure they are OFF when you plug them in. Make sure you have the skills and similar (or the same) equipment.
Welding
- Welding equipment: Gude Inverter GC 100 PM (art nr 20056)
- On the lower settings (below 40 amps) since the iron used is very thin.
- Slag removal tool and brush  (see above)
- 2mm electrodes
- Welding clothing: welding cap, apron, gloves, shoes, etc
- Welding table (pref in a workplace or outdoors)
- Rare Earth magnet (about 5 centimeter) to hold things together
- Grip plier
- Assorted clamps you have anyway in case you need them
- Extra metal for heat distribution
Grinding and polishing
- Power grinder: Black & Decker KG915, Type 2. 10.000 rotations per minute, 115 millimeter blades.
- Small grinder / brusher: Dremel multipro. 10.000 to 33.000 rotations per minute. Model 395.
- File: bahco 100-08-1
- Vice: paramo hi-duty vice #2 (or similar)
- Hacksaw: Bahco 320
- Safety glasses
Enough lighting and workspace. Also a clear mind and energy.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
