Creating a University Monument and Replica Bronzes
 by precisionart
FeaturedContest Winner
In 2008 My father and I were commissioned to create a 14' high monument of a cougar for Washinton State University. We also created three smaller sized bronze replicas of the monument to sell to alumni and fans.
In this instructable I will show you how I created a monument and three smaller sized replica bronze editions using ZBrush and the latest rapidprototyping technology. This was my first experience with this process and perhaps the first time this entire process has ever been used in this way!
You will learn about the lost wax process, ZBrush, CNC machines, scanners, 3d printers, SLA machines, and much more. I hope you enjoy. You can view the project at cougarpride.com
Step 1: Materials and Equipment
This Instructable is quite involved and has many phases or work.
Shown here is are the general tools, materials, software and equipment used in the process. This is not a comprehensive list, but some of the most important items are itemized.
Clay tools
These tools were used in creating the monument.
1. Clay - 2AB-225 Plasticine Oil Clay - a very nice blend that does not casue irritation under your fingernails
2. Detail tools - Richeson Double Wire End Tools - This is merely my choice here but any similar tools can be used.
3. Curved Rake - These are to even out large smooth areas.
And of course you thumb and finger for lots of handwork!
Equipment
Here is the equipment used in creating the replicas, however, Zbrush was used in creating the original sculpture.
1. Zbrush, Modo and Rhino
2. Scanner - Atos
3. 3d Printer - Objet 250
4. Sla Machine - Viper Pro
There was additional harware specific software used as well.
Hard Surface Tools
These materials are used to cleanup the objet and viper models which have build lines and sometimes need minor correction.
1. Filler - Adtech P-14 - a high grade filler.  One can use standard body filler as well but this is nice stuff.
2. Surfacer - SEM Flexible Primer Surfacer.  This is thinner than the filler and great for filling holes and smaller cracks.
3. Pallete knife - great for small mixes and application of filler and surfacer
4. Die Grider - Harbor frieght cheapy, but works great
5. Ruby and diamond bits - they run very clean and smooth.
6. Abrasive Paper - Mirka Abranet - very nice to use
7. Wax - Ferris Patch-Eze - really, nearly any kind of wax can be used to fill pinholes.
8. Wax tools - helps to press the wax into holes.
9. Mixing Board - Clean Sheets - mulitple paper sheets are great to mix filler on.
Step 2: Design and Review
At this stage it is important to have clear communication with your client to understand what they envision. Very often they don't have a well defined vision so it is very helpful to put together some concept sketches. Take advantage of this stage to make adjustments as changes become progressively more difficult and expensive as you proceed.
For this project we felt it was important to create a large monument for full impact and presence. As you can see, one of the sketches helps visualize various scales.
As a side note for projects - it is very important to have definitive language that spells out all expectations for both parties in contractual form. Deposits and milestone payments are also very important. Always remember that if there are no hidden assumptions or expectations then a project is much more likely to go smoothly.
Step 3: Creating Master in Zbrush
Creating a master in Zbrush was a great experience; with unnatural abilities like sculpting on layers, posing, undo's and the ability to make proportional changes without affecting detail! Creating the master in Zbrush made the project much quicker than a traditional approach and enabled going directly to monument without a maquette.
Spend as much time in the presence of your subject as possible and make sure you collect dozens, if not hundreds of images. The more time you spend studying your subject before starting, the better.
First, create a mesh within Zbrush, or as i did, in another traditional program like Modo. Ideally the mesh will be in a static and symmetrical pose to take advantage of Zbrush's symmetrical sculpting. In this pose it is also easy to superimpose it over an image in orthogonal view to ensure an accurate silhouette - take care to select a photo with minimal distortion. http://www.photomatters.org/lens-angle
Next, focus on getting the primary level of form down, adding general volume and getting your sillouettes correct along the three major axis. Add subdivision levels as you progressively move through secondary and tertiary levels of form. Make sure you have a thorough understanding of your subject's anatomy. It is not enough to have a surface level understanding. Creating ecorche drawings is helpful. Example here from a great artist: http://www.scott-eaton.com/anatomy-for-artists-online-course
It is crucial to pay attention to how light interacts with your sculpt. Pay close attention to both the shadows and reflections as they are key to understanding the form. Notice how light and shadow break up and have continuity in across the sculpt.
A major advantage of Zbrush is that you can move back to the lowest subdivision level even after you have added fine details and make corrections to primary form without destroying your dertail work. At this point, you are still sculpting in symmetry mode, which cuts your work in half.
Next, you will be posing your sculpt to give it proper gesture and attitude. This stage is most important in conveying your intentions to the viewer. Although you can use poseable symmetry after posing a sculpt, it is important to add a sufficient amount of detail before posing your sculpt to prevent unnecessary sculpting. Keep in mind that when you pose your sculpt the anatomy will shift and you will have to redo some work after you break symmetry.
Throughout this process it is also helpful to have your client involved (assuming it is a commission). This ensures that they are happy and minimizes the amount of rework later.
Step 4: CNC Foam Monument
Once you and your client are happy with the final model, you are ready to send it to the CNC machine (or 3d printer). Find a company that has extensive experience in this as it requires a high level of skill and experience to properly deal with the files and machine. Rob Arps at Additive Workshop in portland was great to work with and a superp gentleman. It is important to cut up and orientate the 3D model to optimize for detail and minimize "shadowing," which is where the CNC cannot access undercuts. Robotic arms can potentiall minimize shadowing.
Selecting the proper foam is important. Lower cost lightweight foams are much cheaper, but do not maintain as much detail. A low grade insulation foam was used on the cougar which meant a loss of detail and some outgassing issues later (clay bubbles when exposed to heat).
Once the foam has been milled by the CNC machine, it is necessary to assemble the pieces using glue, fittings and armatures. We made the head removeable so it would be easier to sculpt.
Next project, I will CNC or 3d print a draft model before going directly to monument. There is too big of a risk that you are not seeing things properly in the virtual world.
Step 5: Clay Refinement
Now that the foam is assembled the fun begins. First a thin layer of clay is painted, sprayed or hand applied to the foam ensuring complete coverage. Less is more in this case. Apply what is necessary to get a clean surface that does not show foam texture, but not so much as to cover detail or waste clay.
Once the clay had been applied, we began scraping back some of the clay. The goal of this piece was to achieve a hybrid of contemporary and traditional style so it was important to keep the original clean curves intact.
Next is a rough out pass where detail that was lost, or not in the orginal model, is fleshed out.  At this stage -- since application is still rough -- it is important to apply the same concept of gesture to the detail to ensure the overall feel of the piece is expressed and supported. Once detail as been rougly laid out, now it is time to go back over the detail to clean it up and make sure it has the final touch.
Once the head was covered in clay it became apparent that not enough time was spent properly sculpting it in Zbrush. It would have been much easier to do it right in Zbrush the first time. I almost completely resculpted the head since the head is the most important part of a subject. Most of that work was done with my hand and basic clay tools.
Rob machined some eyes out of hard plastic to ensure that they were perfectly round and would interact with the light properly once cast in bronze. Eyes are the most imporant part of the head. In this case, I chose not to simulate the pupils with cut-ins.
Step 6: CNC Rock and Finish
The original rock created in Zbrush was much too simplistic and inaccurate so after looking over litterally thousands of basalt rocks we finally found a great one. Some customization needed to be done by breaking and adding rocks and doing some clay work. This rock was then scanned and CNC'd out of dense and very expensive foam. We used wall compound to fill the seams which proved to be a little too hard to easily sand and tool. Once all the seams and shadowing were tooled and sanded, the whole rock was painted in a urethane coating.
The monument name, as well as my father and my name were CNC'd out of a hard plastic and embedded in the rock.
Since the cougar could never be lifted up and set on the rock without incurring damage, a three dimensional template with the positions of the cougars feet was welded together to ensure the rock at cougar fit together properly.
Step 7: Molding The Monument
Now that the rock and cougar are completed, it is time to mold them. Foundries can only cast small panels 16" x 16" so the sculpture needs to be cut or partitioned into pieces which seperate the individual mold panels.
Once the sculpture as been partitioned into sections (in this case with playing cards), then a silicon rubber is painted over the surface. Once the entire surface has been coated in silicon rubber it must be backed by a "mother mold". This is usually plaster or epoxy and holds the shape of each panel since the rubber has no structure.
Each mother mold panel should be numbered and a map created so the foundry can later assemble the bronze panels.
Step 8: Wax Pour, Chase and Gate
Now that molding is completed, it is time to pour wax in each panel, in this case 165 of them!  A thin layer of wax is poured or brushed on the inner surface of the mold making sure to get and even and complete coat. The thickness of the wax will eventually be the thickness of the bronze, which is roughly 3/5" - bronzes are almost entirely hollow, especially the larger they are. The wax has to be poured at a very specific temperature, which determines its viscosity and tendency to create bubbles.
Once the wax cools, "wax chasers" retools the wax to remove "bogies" which are pinholes or other defects in the pour. The chased waxes then have gating applied to them. The gating determines how the bronze will flow into the panel. For some complicated pieces a well designed gating structure is critical to getting a casting without cracks and "porosity", which are small holes in the bronze. As the bronze cools it contracts differently for convex shapes vs contour shapes which causes the bronze to pull apart. Some times chills are added which pull heat away from certain areas faster as the bronze cools. The cooling issues make it very important to cut up a piece properly.
Step 9: Slurry, Shell and Pour Bronze
The tooled and gated waxes are now ready for a slurry dip. The wax patterns are dipped in progressively coarser grades of ceramic slurry over the coarse of several days. Allowing each layer to dry properly is essential to a good casting, otherwise the bronze may break through the shell. The slurry room is kept at a very precise temperature and humidity.
Once the shells have dried they are then placed in a furnace where the wax is melted out leaving an empty shell with a negative of the original wax pattern. The still warm shells then have molten bronze poured in them, filling the precise void left by the wax pattern.  Minimizing turbulence in the pour as well as minimizing crude elements is important to a clean casting.
Step 10: Chase, Weld and Fabricate
Now that the bronze has cooled, the shell is broken off, leaving a replica of the original wax pattern in bronze. Since each panel cools and contracts differently, each panel needs to be reshaped to make sure they all fit together seamlessly.  Image assemblying a 165 piece puzzle in three dimensions with each piece curled up a little!
Each piece is then tack welded together and then finally welded completely. The welds not only cover the seams but also are crucial to the structural integrity of the piece.  Every weld needs to be chased out to make it flush with the bronze casting. This sculpture had literally thousands of feet of welds that needed to be chased!
No casting is perfect so bogies - pinholes and "nurds" (small protrusions of bronze) - must be welded and chased to keep the casting true to the original.
Unfortunately, the template for fitting the cougar to the rock had an error, so the foundry needed to to cut the rock and pour some more panels to fill in the gap in order to raise one of the cougar's paws.
Step 11: Superstructure and Metal Refinement
Unfortunately, a bronze monument will not stand without superstructure. The superstructure must be to code for wind and earthquakes.  For this project we designed the superstructure and then had an engineer sign off on it.  Sometimes the intuition of an antist is consistent with that of an engineer.
The superstructure was steel tubing and had to connect the cougar to the rock, the rock to the pedestal and the pedestal to the foundation. The tail needed solid superstructure since it was likely that some drunk college students with hang or sit on it.
A sold 2" diameter steel rod sleves inside steel tubing and ties the foundation, pedestal and rock together.
Step 12: Foundation, Superstructure and Pedestal
From a project management perspective, the foundation and pedestal had to be poured inline with the casting. 30" deep of concrete was poured as a foundation. Originally we planned to have a solid black granite rock carved and imported, but this offered a risk of missing our deadline. The granite rock was going to weigh 100k lbs and the foundation was poured to support that.
An elongated and tapered octagon was chosen as the pedestal design. The concrete form had to be designed in CAD to ensure precision. The form needed external and internal support. Once poured and given some cure time, the pedestal was ready for its decorative granite.
Tan Brown Granite slabs were precision cut and installed over the cement pedestal form. Before being installed, we had the WSU logo waterjet cutout and inlaid and also had a dedication sandblast etched into the front facing granite slab. Since the cement continues to dry out and contract, it is not only important to have strong rebar to reinforce the form, but it was also important to add a rubber bladder between the granite and the cement. This allows the granite to float on the granite. It turned out the granite weighed almost as much as the bronze cougar!
Next, the solid steel rod was epoxied in place.  We needed to have a custom welded support to make sure the rod was perfectly vertical since the tubing was quite a bit larger than the rod. The cougar would suspend on this rod, floating just above the granite. We cut out a rubber pad to place on the granite to eliminate the gap and avoid chatter between the bronze and granite.
Step 13: Sandblasting
Now that  the tooling is completed on the monument, it is ready for sandblasting which prepares the sculpture for patina. Sanblasting adds a texture that gives a "tooth" for the patina to adhere to. Sandplasting removes any chemicals or oils that can affect patina application. Sanblasting also reveals deformaties, bogies and obvious welds by making the surface homogoneous. Some times it is necessary to rework the metal post sandblasting. Sandblasting is a nasty process and definately requires resperatory gear and good ventilation.
Step 14: Patina
Now the sculpture is ready for the most exciting part of the process..patina. This is where dyes, chemicals, acids, waxes and clearcoats are applied to give bronze its final look.
First, the entire piece is coated in Brichwood Casey. This acts as a dark base coat. The patina process is opposite to how you might paint a picture. It is sometimes challenging, but it is important to get an even coat over the entire piece. Birchwood progressively darkens or "antiques" the bronze the longer it is left on. Water stops the chemical reaction. Sometimes, if the chemical is applied excessively or left on too long it will burn through itself and flake off creating further challenges. The entire piece is rinsed with water and now the real fun begins.
Secondly, the entire piece needs to be wire wheeled (pnuematic tool) or hand brushed with brass bristles. As you can see, the Birchwood Casey quickly oxidizes and leaves an unatractive rust look. This is tediously removed.
Thirdly, the birchwood is hand rubbed back. Some of the work has to be done with a pnuematic tool and scothbrite wheels. This leaves the birchwood in the recesses. Areas that will be lighter like the snout, ears, chest, eyes and muzzle are rubbed back farther. This actually is the most artistic part of the process for this particular patina.  With care you can control gradation, subtle in some areas, aggressive in others and transitions where necessary. We wanted to give life to the eyes and claws so they were polished at this stage.  Sometimes the patina reveals some imperfect metal work which in this case had to be repaired an repatinated. A skilled patina artist can do these local fixes and still keep the patina continuos, which can be challenging.
Fourthly, the bronze is heated to a specifc temperature with a torch before, and as, ferrric nitrate is sprayed on the sculpture.  This chemical, depending on heat and application can vary from brown to deep red.  It is a nasty chemical and requires a respirator and ventilation. Ferric will give a nice warmth to the piece that is lacking from the grey birchwood.  We rubbed back some more areas after the ferric was applied to make sure they stood out and gave some visual intrigue.  Generally, traditional patinas like this one darken over time so it is important to make things a little lighter and sometimes exagerate contrast.
Finally, A clear coat is applied. Traditionally, especially with small sculptures, just a wax is applied.  However, this piece is going outside and is subjected to the elements, including UV light, which reacts with the patina. We chose a permalac clearcoat with a wax finish. The wax can be reapplied every year and acts as one more protective layer the bronze. It also can knock back the sometimes too refelective clearcoat.  Both the clearcoat and wax really change the depth and saturation of the colors from the patina. It is helpful to be acustomed to this so the previous stages are handled properly.  We also used a matte spray to knock back the "hotness" of the clear coat before waxing the sculpture. Too shiny can kill an organic look so we opted to not buff the wax.
Step 15: Loading, Delivery and Installation
Now the monument is ready for delivery and installation.  The cougar was picked up by its center of mass using a winch and placed on the trailer. Once onsite the monument was picked by an 8000lb extension forklift.  The sculpture had to be carefully lowered on the pedestal, sleeve over the rod and come down evenly to avoid cracking the granite.
We had a removable plug in the top of the rock that we could inject the remaining epoxy down through the tubing surrounding the rod. As soon as the epoxy set up everything was soundly tied together.
Originally our engineer, condescendingly asserted that we should not pre epoxy the rod into the foundation, but rather leave it floating, get someone to quickly inject the epoxy into the base (getting between the rock and a hard place), lower the monument and then inject it through the top of the rock before the fast set epoxy went off.  We rejected his authoritative instructions and thankfully so, because we found that the 15 minute epoxy sets up much faster when in an enclosed space heated by surrounding catalyzing epoxy.  I mention this as a lesson.  Sometimes you need to go with your own intuition and experience and reject authority!
Surprisingly, this project required 17 independent contractors to complete. It is important to manage the project to guarantee everything comes together when it needs to.  Generally everyone is late and over budget so account for this in your timelines and stay on each subcontractor. If anyone tells you "don't worry" be worried. Ideally a contract is a good idea as one sub can throw the entire project off. We had Apple Cup as our deadline, so being late was not an option.
Step 16: Scanning, 3d Printing and SLA
Now that the monument is in place and ready for the dedication it is time to make some small bronze replicas to be sold to alumni. The monument was first scanned with a large format scanner and then a high resolution ATOS scan was performed and stitched over the large format scan to maximize resolution and the accuracy of overall geometry - marvelously performed by Additive Workshop.
We would be creating an 11", 18" and 30" version, the latter had to be created using SLA because it was not feasible on the smaller format Objet printer. The 11" and 18" were printed on the Objet which has greater detail than SLA (amazing detail in fact).
The sculpture had to be digital cut up to best plan for rapidprototyping.  It is an optimization problem as the printer creates build lines which reduce detail.  For example if you were printing a long cone you would want to print it with the tip up to maximize resolution but this would increase build time and therefore cost.
Kelyniam Engineering/ M2 Systems did the SLA work and put a lot of time into creating hexagonal male/female fittings so that each part would be precisely come together. Additive Workshop did the objet printing and did a great job as well.
A note, make sure that proper internal structure is printed inside the sculpture. This will minimize sag and other deformation as 3d printing had some issues maintaining overall geometry on larger prints (not referring to resolution).
Here is an example video of the objet machine at work:
Step 17: Model Cleanup
The rapid-prototypes came out beautifully, but unfortunately there is still finish work to do.  The tiny build lines, sometimes hard to see or even feel will be captured by the silicon rubber mold.  If you look close you can see them in one of the images. The build lines must be filled and or tooled to eliminate them. I learned the hard way and had to use my molds as scrap molds. We poured new resins in the scrap molds and i retooled them with more diligence.  In some way this is kind of necessary as the build lines are not just on the surface but penetrate into the piece with a slight gummy-ness in between layers. This means that no matter how hard you work they do not go away in some areas.  I assume this is a cure issue. This might have been an operator issue or because this was in '08 - new objet prints may not have this issue.
In some cases I assembled the parts together before cleanup, but in the case of the large cougar it was easier to work on it in parts first. I joined the parts with a high grade aerospace filler (you can use car body filler as well but the good stuff is smoother and less prone to creating pinholes). There are different color catalyst - it is best to chose one that matches your model best.
Then the seams were tooled with die grinders using ruby and diamond bits. Then the seams were sanding with progressively finer sand paper. The seams are sometimes challenging to merge since the filler and the prototyping resin are slightly different hardness.
Some of the detail was lost, mostly in the SLA version. I spent dozens of hours retooling and accentuating the detail.  I used a primer as well as the filler to fill in the build lines and tool and sand them back. This is a lengthy and tedious process. The SLA (Stereolithography) resin was fairly hard so sanding took a while. It was also semi transparent. Since good contrast lighting is important, this created a challenge of seeing the surface.
Pinholes can be a nightmare. I fill the reluctant ones at the very end with wax.
Rapidprotyping is a blessing because when you finish a sculpture the last thing you want to do is re-sculpt the same sculpture in different sizes.  Also, it is impossible to created an exact replica. Thank you technology!  Some artists resist the advancements in technology, but the fact is that artist throughout the ages always were on the leading edge, taking advantage of whatever tool or tech they could, from the projector for painting to systematic enlarging. Tools are tools and creation is through the artisan.
Step 18: Finished Replica Bronzes
This project was a spectacular experience and the monument and the replicas have been received with immense gratitude.  This was a rewarding and challenging project. It was fun being able to use the latest technology on this project (completed in 2008).  As far as I know I was the first to use the entire sequence of technology end to end on a project of this kind.
Remember the importance of presentation. We were up against 65 other artist nationwide, but won the project because we went above and behond in our presentation. Unfortunately, to stay in business you have to be a salesman, marketer, and business professional in addition to being an artist. Don't underestimate the need for contracts, unless you prefer to learn the hard way.
WSU's football team now has a tradition called "Cougar Prowl" where each player touches the monument before the game. Pretty cool!
Special thanks to:
Heather Soderberg - assistant sculptor (great talent and amazing person)
Valley Bronze - Foundry that cast monument
T. Hunter Bronze - Foundry that casts the replica bronzes
1-40 of 54Next »
flamekiller says: May 28, 2012. 1:56 AM
Wow, awesome project. I haven't seen the actual statue ... looks like an excuse to go to a game in Pullman next season! Well done!
Go Cougs!
phil182 says: May 13, 2012. 8:44 PM
Its really a ton of work, so Great!!!
Sculpture (model) in zbush can be slice w/ section?
Thanks for sharing,
precisionart (author) in reply to phil182May 14, 2012. 8:25 AM
I'm actually not positive in which program the model was cut up for the SLA but it was definitely not Zbrush. It was exported as obj file and then managed in different programs for CNC, SLA and 3d printing. I hope I understood your question correctly.
phil182 in reply to precisionartMay 15, 2012. 12:21 AM
Thanks for your reply.
Cheers,
Phil
mnpazan says: May 14, 2012. 11:14 AM
Since SLA printing uses light-curing resin, maybe "baking" the parts under a UV lamp would fix the soft inter-layer problem? Dunno if that would work (don't know if it's a cure problem, or what light wavelength you'd actually need), just tossing it out.
precisionart (author) in reply to mnpazanMay 14, 2012. 11:28 AM
That is a reasonable proposal. Actually, the SLA had no cure issues, just the 3d print. This may no longer be an issue. If it is, I will definately explore your suggestion. Thanks
mnpazan in reply to precisionartMay 14, 2012. 10:29 PM
SLA is a type of 3D printing, so "the SLA had no cure issues, just the 3d print" is a little confusing. I guess you mean some of the prints were printed using a different process than SLA,? What process did those prints use, do you know?
Baking with a UV light might work if it was a laser-cure resin process, but it wouldn't work for a hot extrusion/deposition or laser sintering process.
precisionart (author) in reply to mnpazanMay 14, 2012. 11:11 PM
I guess the word 3d printing could be used as the larger category. What I am intending to mean is that the Stereolithography part created with the Viper, which I believe is with a focused laser curing a liquid resin, came out fine. The polyjet version (objet), which is 'printed' and then lamp cured, occasionally had some cure issues (at the time of this project).
I think there might be two different substrates used in the process, one that cures and one that doesn't (support) maybe that is the issue. If so, perhaps your suggestion would not help.
This is how I am using the terminology: http://www.finelineprototyping.com/intro/technologies.php
acoleman3 says: May 14, 2012. 11:14 AM
every time i go there i have to visit the cugar. now i know how it actually came to be! nice one mate and a serious bang up job on it.
chaitanyak says: May 13, 2012. 9:47 PM
what a well documented project! thanks for sharing with the community!
i've been getting some of my models 3d printed via shapeways.. its definitely a great feeling seeing something you've sculpted in actual physical form.
i did a bronze casting(lost wax process)elective in art school(7-8yrs back)..created a handfull of bronze creatures.., so have always appreciated the work that went into making these large monuments.. never thought it had got this technologically advanced though!
have you tried sculptris? its a lightweight and free app thats great for sculpting(pixologic the makers of zbrush own it now..but have still kept it free)
ps: small typo: please correct "Marquette" to "Maquette"
precisionart (author) in reply to chaitanyakMay 14, 2012. 8:38 AM
I haven't tried it yet or the new dynamesh feature. Both seem like they would satisfy some of he items on my Zbrush wishlist.
Thanks for the spell check...English was my weakest subject:)
chaitanyak in reply to precisionartMay 14, 2012. 10:22 AM
i make typos all the time :P
only spotted yours because i googled it .. (had heard it used before and was wondering what it meant)
jongscx says: May 13, 2012. 10:35 PM
I love the 5th picture in the "superstructure" section where there is a guy coming out of the Cougar's behind...
Sorry, I guess some of us stay 8 yrs old on the inside :-D
precisionart (author) in reply to jongscxMay 14, 2012. 8:35 AM
It didn't get posted by accident:) I'm an 8 year old too.
Sucks to be low man on the totem pole..."hey Jimmy, get in the cougar's butt"
robecker says: May 13, 2012. 6:53 PM
This is a wonderful 'ible. My dad's first teaching job was in the WSU art dept in the mid '60s. My earliest memories include roaming the halls of higher education and then visiting the live mountain lion they kept in a large cage on campus. These big "little" cats are so beautiful and powerful. I hope this sculpture has replaced the real thing.
precisionart (author) in reply to robeckerMay 14, 2012. 8:20 AM
Yup, this sculpture is placed exactly where "Butch" use to be. Definitely, wouldn't want to run into one on a Mt. hike! We have a local zoo that had a phenomenal looking cougar, Samson. I got most of my reference images from him... unfortunately he did in the middle of this project.
rashoot says: May 13, 2012. 10:04 AM
How long did it take from start to finish?
What was the contract amount?
precisionart (author) in reply to rashootMay 13, 2012. 11:26 AM
1 month in Zbrush (first time I used this awesome software). 10 weeks of clay work. Three months to cast. Total time ~7 months. It was a private donor so out of respect for him, I won't disclose the amount.
rashoot in reply to precisionartMay 13, 2012. 2:57 PM
Thanks for the reply. If you had to make another one, approximately, what should you charge? The reason I ask is I maybe creating a 14' Grizly and it may be more feasible to contract it out to you if you are interested. It would be the typical stand up attack pose
Regards
Tony
precisionart (author) in reply to rashootMay 14, 2012. 8:13 AM
Hi Tony - I would start by getting bids on scale-up, molding and casting etc and then add the profit you want to justify your time. I cast my work at two different foundries - Valley Bronze of Oregon and T. Hunter Bronze of Walla Walla WA. I wouldn't be able help you on this one...I'm co-founding a startup company www.cbuy.tv and I am pretty busy.
De Bergamo says: May 14, 2012. 5:59 AM
This is absolutely impressive! Congratulations, very good work!
SeaPanther says: May 14, 2012. 2:38 AM
That is just too cool! Thanks for sharing
goldpen says: May 13, 2012. 10:42 PM
thanks for sharing this amazing work and detailing the processes which made it happen. Much appreciated
martiro7 says: May 13, 2012. 8:24 PM
Astonishingly good Instructable! I knew basically how bronzes are made, but yours really put it all into perspective, especially slicing up the piece to fit within the foundry's casting capabilities. Amazing work!
robecker says: May 13, 2012. 7:28 PM
Absolutely amazing. All the information makes me appreciate the beauty of the sculpture even more.
Andrew Pearce says: May 13, 2012. 2:06 PM
I want to cast a giant bronze sculpture of myself as an angel. You know, for the lounge. This will be a big help. You have awesome skills!
Pattymouth says: May 13, 2012. 1:59 PM
WOW! Amazing Instructable! Now could you buy me the equipment, draw me up a prototype, foam it & wax it & make it for me? My garage is already packed with other projects. But seriously, great job - even though I'm a BYU Cougar & my loyalty lies with that one. ;~}
lkuziez9680 says: May 11, 2012. 3:59 PM
There is a cougar just like that at SIUE
clazman in reply to lkuziez9680May 13, 2012. 11:59 AM
I'm sorry, but the SIUE cougar is very poorly done compared to this.
It is quite like a cartoon.
And... it looks like he is high on chew. Terrible!
There is NO comparison. You have done a beautiful job!!!!
My wife says: "Go Cougs"
signed,
Jerry, arch rival, Husky.
lkuziez9680 in reply to clazmanMay 13, 2012. 1:42 PM
I agree, your statue has more texture to it. However, it was the overall figure that reminded me of the SIUE Cougar
valveman says: May 13, 2012. 1:41 PM
Wow that is amazing. Looks of hours went into that and it looks fantastic. Bravo
keegancdr says: May 13, 2012. 11:40 AM
Haha I'm on stadium right now! Lol I just passed the coug a minute ago! Go cougs!!
precisionart (author) says: May 10, 2012. 10:32 AM
Hi Everyone. This is my first instructable and I am looking for feedback before I enter it into the "Make it Real" challenge. Comments and feedback are greatly appreciated. Mike
askjerry in reply to precisionartMay 13, 2012. 6:52 AM
You did an incredible job both with the monument and the instructable. Every step was well explained, lots of pictures, very clear. I really think this was the best written instructable that I have read... if not definitely in the top 3.
Excellent job!
Jerry
precisionart (author) in reply to askjerryMay 13, 2012. 11:33 AM
Wow, thanks!
cartola says: May 13, 2012. 7:38 AM
Man, astonishing! One of the most interesting instructable I have seen around here. I am not mentioning your total professional job, I also congratulate you for the very good tutorial and sharing.
Obviously I know that there are professionals doing this (and many other things), but I really didn't expect one of them to share the whole experience with us. Hope others get inspired by you and we get more from professionals to complement and give ideas to the poor DIY mortals :)
Thanks a lot!
precisionart (author) in reply to cartolaMay 13, 2012. 11:31 AM
I kind of feel that one of the biggest downfalls of capitalism is the lack of sharing. I absolutely love communities like this here, Zbrush community, etc. because they offer an opportunity to overcome this limitation. Thanks to everyone here!
Honus says: May 13, 2012. 7:49 AM
Wow- talk about an awesome project!
Were there any issues casting the SLA model? I know from experience that sometimes the resins used don't burn out completely leaving an ash residue in the cavity that can affect the casting.
Honus in reply to HonusMay 13, 2012. 7:52 AM
Nevermind- I just realized you probably made waxes from the SLA model. :)
precisionart (author) in reply to HonusMay 13, 2012. 11:27 AM
Correct. Unfortunately, it was SLA/3d print to resin (scrap mold) for rework, then to waxes.
1-40 of 54Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
