loading
Step 12: Foundation, Superstructure and Pedestal
From a project management perspective, the foundation and pedestal had to be poured inline with the casting. 30" deep of concrete was poured as a foundation. Originally we planned to have a solid black granite rock carved and imported, but this offered a risk of missing our deadline. The granite rock was going to weigh 100k lbs and the foundation was poured to support that.
An elongated and tapered octagon was chosen as the pedestal design. The concrete form had to be designed in CAD to ensure precision. The form needed external and internal support. Once poured and given some cure time, the pedestal was ready for its decorative granite.
Tan brown granite slabs were precision cut and installed over the cement pedestal form. Before being installed, we had the WSU logo waterjet cutout and inlaid and also had a dedication sandblast etched into the front facing granite slab. Since the cement continues to dry out and contract, it is not only important to have strong re-bar to reinforce the form, but it was also important to add a rubber bladder between the granite and the cement. This allows the granite to float on the granite. It turned out the granite weighed almost as much as the bronze cougar!
Next, the solid steel rod was epoxied in place.  We needed to have a custom welded support to make sure the rod was perfectly vertical since the tubing was quite a bit larger than the rod. The cougar would suspend on this rod, floating just above the granite. We cut out a rubber pad to place on the granite to eliminate the gap and avoid chatter between the bronze and granite.
This was such an amazingly beautiful project--and a fantastic 'ible. You guys are real pros! <br> <br>Thanks!
Wow, awesome project. I haven't seen the actual statue ... looks like an excuse to go to a game in Pullman next season! Well done! <br> <br>Go Cougs!
Its really a ton of work, so Great!!! <br> <br>Sculpture (model) in zbush can be slice w/ section? <br> <br>Thanks for sharing,
I'm actually not positive in which program the model was cut up for the SLA but it was definitely not Zbrush. It was exported as obj file and then managed in different programs for CNC, SLA and 3d printing. I hope I understood your question correctly.
Thanks for your reply.<br><br>Cheers,<br><br>Phil
Since SLA printing uses light-curing resin, maybe &quot;baking&quot; the parts under a UV lamp would fix the soft inter-layer problem? Dunno if that would work (don't know if it's a cure problem, or what light wavelength you'd actually need), just tossing it out.
That is a reasonable proposal. Actually, the SLA had no cure issues, just the 3d print. This may no longer be an issue. If it is, I will definately explore your suggestion. Thanks
SLA is a type of 3D printing, so &quot;the SLA had no cure issues, just the 3d print&quot; is a little confusing. I guess you mean some of the prints were printed using a different process than SLA,? What process did those prints use, do you know? <br> <br>Baking with a UV light might work if it was a laser-cure resin process, but it wouldn't work for a hot extrusion/deposition or laser sintering process.
I guess the word 3d printing could be used as the larger category. What I am intending to mean is that the Stereolithography part created with the Viper, which I believe is with a focused laser curing a liquid resin, came out fine. The polyjet version (objet), which is 'printed' and then lamp cured, occasionally had some cure issues (at the time of this project). <br> <br>I think there might be two different substrates used in the process, one that cures and one that doesn't (support) maybe that is the issue. If so, perhaps your suggestion would not help. <br> <br>This is how I am using the terminology: http://www.finelineprototyping.com/intro/technologies.php
every time i go there i have to visit the cugar. now i know how it actually came to be! nice one mate and a serious bang up job on it.
what a well documented project! thanks for sharing with the community! <br>i've been getting some of my models 3d printed via shapeways.. its definitely a great feeling seeing something you've sculpted in actual physical form. <br> <br>i did a bronze casting(lost wax process)elective in art school(7-8yrs back)..created a handfull of bronze creatures.., so have always appreciated the work that went into making these large monuments.. never thought it had got this technologically advanced though! <br> <br>have you tried sculptris? its a lightweight and free app thats great for sculpting(pixologic the makers of zbrush own it now..but have still kept it free) <br> <br> <br> <br>ps: small typo: please correct &quot;Marquette&quot; to &quot;Maquette&quot;
I haven't tried it yet or the new dynamesh feature. Both seem like they would satisfy some of he items on my Zbrush wishlist. <br> <br>Thanks for the spell check...English was my weakest subject:)
i make typos all the time :P<br><br>only spotted yours because i googled it .. (had heard it used before and was wondering what it meant)
I love the 5th picture in the &quot;superstructure&quot; section where there is a guy coming out of the Cougar's behind... <br> <br>Sorry, I guess some of us stay 8 yrs old on the inside :-D
It didn't get posted by accident:) I'm an 8 year old too. <br> <br>Sucks to be low man on the totem pole...&quot;hey Jimmy, get in the cougar's butt&quot;
This is a wonderful 'ible. My dad's first teaching job was in the WSU art dept in the mid '60s. My earliest memories include roaming the halls of higher education and then visiting the live mountain lion they kept in a large cage on campus. These big &quot;little&quot; cats are so beautiful and powerful. I hope this sculpture has replaced the real thing.
Yup, this sculpture is placed exactly where &quot;Butch&quot; use to be. Definitely, wouldn't want to run into one on a Mt. hike! We have a local zoo that had a phenomenal looking cougar, Samson. I got most of my reference images from him... unfortunately he did in the middle of this project.
How long did it take from start to finish? <br>What was the contract amount?
1 month in Zbrush (first time I used this awesome software). 10 weeks of clay work. Three months to cast. Total time ~7 months. It was a private donor so out of respect for him, I won't disclose the amount.
Thanks for the reply. If you had to make another one, approximately, what should you charge? The reason I ask is I maybe creating a 14' Grizly and it may be more feasible to contract it out to you if you are interested. It would be the typical stand up attack pose <br> <br> Regards <br>. <br>Tony <br>
Hi Tony - I would start by getting bids on scale-up, molding and casting etc and then add the profit you want to justify your time. I cast my work at two different foundries - Valley Bronze of Oregon and T. Hunter Bronze of Walla Walla WA. I wouldn't be able help you on this one...I'm co-founding a startup company www.cbuy.tv and I am pretty busy.
This is absolutely impressive! Congratulations, very good work!
That is just too cool! Thanks for sharing
thanks for sharing this amazing work and detailing the processes which made it happen. Much appreciated
Astonishingly good Instructable! I knew basically how bronzes are made, but yours really put it all into perspective, especially slicing up the piece to fit within the foundry's casting capabilities. Amazing work!
Absolutely amazing. All the information makes me appreciate the beauty of the sculpture even more.
I want to cast a giant bronze sculpture of myself as an angel. You know, for the lounge. This will be a big help. You have awesome skills!
WOW! Amazing Instructable! Now could you buy me the equipment, draw me up a prototype, foam it &amp; wax it &amp; make it for me? My garage is already packed with other projects. But seriously, great job - even though I'm a BYU Cougar &amp; my loyalty lies with that one. ;~}
There is a cougar just like that at SIUE
I'm sorry, but the SIUE cougar is very poorly done compared to this. <br> <br>It is quite like a cartoon. <br> <br>And... it looks like he is high on chew. Terrible! <br> <br>There is NO comparison. You have done a beautiful job!!!! <br> <br>My wife says: &quot;Go Cougs&quot; <br> <br> <br>signed, <br>Jerry, arch rival, Husky.
I agree, your statue has more texture to it. However, it was the overall figure that reminded me of the SIUE Cougar
Wow that is amazing. Looks of hours went into that and it looks fantastic. Bravo
Haha I'm on stadium right now! Lol I just passed the coug a minute ago! Go cougs!!
Hi Everyone. This is my first instructable and I am looking for feedback before I enter it into the &quot;Make it Real&quot; challenge. Comments and feedback are greatly appreciated. Mike
You did an incredible job both with the monument and the instructable. Every step was well explained, lots of pictures, very clear. I really think this was the best written instructable that I have read... if not definitely in the top 3. <br> <br>Excellent job! <br>Jerry
Wow, thanks!
Man, astonishing! One of the most interesting instructable I have seen around here. I am not mentioning your total professional job, I also congratulate you for the very good tutorial and sharing. <br> <br>Obviously I know that there are professionals doing this (and many other things), but I really didn't expect one of them to share the whole experience with us. Hope others get inspired by you and we get more from professionals to complement and give ideas to the poor DIY mortals :) <br> <br>Thanks a lot!
I kind of feel that one of the biggest downfalls of capitalism is the lack of sharing. I absolutely love communities like this here, Zbrush community, etc. because they offer an opportunity to overcome this limitation. Thanks to everyone here!
Wow- talk about an awesome project! <br> <br>Were there any issues casting the SLA model? I know from experience that sometimes the resins used don't burn out completely leaving an ash residue in the cavity that can affect the casting.
Nevermind- I just realized you probably made waxes from the SLA model. :)
Correct. Unfortunately, it was SLA/3d print to resin (scrap mold) for rework, then to waxes.
Quite a tour de force for your first Instructable. I can hardly imagine what your *second* one will be about. Cold fusion? Peace in the Middle East? Understanding women?
In that order, save the most challenging for last:)
*like*
So was this cast in bronze? From the pictures it looks like aluminum... <br> <br>Thanks <br> <br>Kurt
Yup, bronze. For some reason when a piece is freshly sandblast is is more silvery. It will slowly yellow by itself.
It is fantastic to be able to see what goes on behind the scenes to create such a monument. Thank you! Congratulation for being featured.
This is super impressive work! <br> <br>Congratulations on an outstanding job and for creating an equally impressive instructable to show us your process!
Wow! <br>Magnificent <br>Good work!
Master, I take my hat, stand and applaud you mightily.
About This Instructable
42,689views
177favorites
License:
Bio: I began drawing when I was very little. I chose to stay inside for school recess on the terms that my teacher would keep my ... More »
More by precisionart:Creating a University Monument and Replica Bronzes
Add instructable to:
