Be light enough to be carried as part of my regular kit, replacing my heavy hand axe.
Be sturdy enough to take a bit of abuse, using it to split small logs, function as an improvised hammer etc
Be something that looks like I can be reasonably proud of making it.
Fit my hand perfectly, I don't like blisters.
Have a tip delicate enough to do a bit of wood carving
Hold a sharp edge
I deplore the prospect of knives as weapons, if you have any comments along those lines, please keep them to yourself, I don't want to know.
Asides from that, I'd love to know your thoughts. This is my first attempt at such a project and I have likely missed a few vital steps.
Remove these ads by
Signing UpStep 1Materials and tools
Steel, at least 3mm thick.
Wood, a couple of different kinds, I used pine and redwood
Threaded rod and nut, for fixing the handle in place
Tools
You can probably get away with less powertools than I used, so I'll list them in order of importance
MIG welder
Bandsaw
Grinder
Vice
Pillar Drill
Hacksaw
Disk sander
Others
Wood Glue
Anti-rust primer
Polishing wax
Sandpaper/Glasspaper
Cloths and rags
Neither of my hardware stores have any...
However, if you insist on buying metal, I suggest www.onlinemetals.com/
*Don't fret, my friend, I was only kidding.*
Anyway, I've just finished the blade for my dagger-style Bowie knife. It has a full tang, and I was exploring different handle designs. I like the looks of the layered wood handle, however, ergonomics is my primary concern since I intend on wrapping the handle in paracord for increased comfort.
Hardness comparisons for various steels are here:
http://www.mcmaster.com/param/html/steel/default.htm
1095 is toward the center, left. A2 and O1 are way right (harder) and will hold a better edge.
