First let me give a little back story / problem. I have a Dell XPS laptop that gets hot, Really hot. I first bought a belkin laptop stand for 20 bucks and the thing still works well its just that it elevates the laptop an inch and a half in the front and almost 3 inches in the back so for extended usage really kills my wrists.
I decided that I could figure out a way to build a fan in to my desk and power it by USB just like my laptop stand and never have to worry about the heat or the bad angle again.
I tried to be as thorough as possible in my instructable but its actually a pretty simple concept that anybody with a few tools could see exactly how I did it with just the pictures and recreate it rather easily.
I hope you enjoy the instructions and if you have any questions please feel free to email me or comment.
FanWorking.wmv2 MB
Remove these ads by
Signing UpStep 1What you need!
1 Rocketfish 120mm case fan (Best Buy, $14)
1 Spare USB cable that you can cut.
1 Desk with enough room underneath to mount.
1 Scrab 1by4 Piece of Wood
4 Wood screws, Length varies by the thickness of your desk. Mine were an Inch and half long.
TOOLS NEEDED :
1 Pair of Wire Snips
1 Router or Heavy duty Dremel
1 Table saw of some variety.
1 Drill and Wood Screw
Electrical Tape
Wire Connectors of some sort. I used this plastic material you cover the wires over and melt down to make a a nice seal.
A few odds and ends, Marker, Piece of Cardboard, Scissors...etc etc.
![IMG_0341[1].JPG](http://img.instructables.com/files/deriv/FTR/I0E5/GAPV3A9M/FTRI0E5GAPV3A9M.SQUARE.jpg)
my laptop lcd was on it's way out. flickering and sometimes not even coming on. Also the battery was shot lasted about 2 min the max. I had a 18.5" lcd monitor so i thought i used that.
I ripped the screen on and decided to keep the power jack in at all time.
i cut a hole in my laptop desk and installed a 80mm 12 volt fan.
i went and purchased a harddrive/dvd rom adapter of ebay for a few bucks. this adapter put out both 12v and 5 volts. i hooked this up to the fan with a switch to run the fan at 12v or 5v. just a flip of the switch can turn the fan on or off, and or 5v or 12v. so when i wants a quite fan i switch it to 5v and when i'm using flash for example i flip it to 12v.
also i ran a few wires from this adapter non switched to a powered usb hub 5 volts, and ran another set of 12v wires to a led strip that shines light on my pull out keyboard.
(yes, I know all laptops have feet, which would bring the backside of the case, further away from the fan blades... still, why risk it?)
Great first write-up btw.. Enjoy!
http://www.amazon.com/KingWin-120x120mm-Long-Bearing-CF-012LB/dp/B002YFP8BK/ref=sr_1_7?s=pc&ie=UTF8&qid=1308989235&sr=1-7 ..surely this is a better option, or something like that.
either way, this is a good idea, it could just use a little more development.
it was well explained,simple cheap and save
my almost 10years all laptop which kept
overheating well done best tutorial of this site
