Step 3Building in more detailed features
Mr Morton's face is quite angular, coming down in a triangle, so I started by drawing a rough sketch of one side of his face on one side of the cereal packet. I made full use of the flaps when positioning the ears rather than having to add something on later. I then cut out the shape and used this as a template to draw the other side on the remaining piece of cereal packet. The cardboard was just long enough: I considered adding more later to make his chin, but in the end decided this wasn't necessary.
I then used strips of masking tape to fix the pieces to the balloon shape, lining them up to make the shape of his face. I had some PVA glue but masking tape is better for this since you can reposition it easily. I also used masking tape to shape the flaps to make the ears.
I then packed the space between the cardboard and the balloon with scrunched up newspaper. This is where I made my first mistake: I forgot to cut the eye holes before fixing the face to the balloon! I had to remove some of the scrunched up paper and use the Stanley blade to cut out the eyes. With that done, I replaced the scrunched up newspaper, using masking tape around the eyes to leave a space between the eye socket and the balloon so that I could cut a hole for the eyes later. I discovered later just how difficult it was to cut through the papier mache balloon, so it may have been wiser to leave eye-shaped sections of the balloon uncovered when applying the papier mache. This would have been a good measure of where the eyes would be placed (as I discovered later, I made a critical mistake!)
I then covered the whole structure in more papier mache. I'm not sure how many layers, but I would recommend at least two. Once that had dried, I rolled up half-pages of newspaper to make the grooves for Mr Morton's hair and stuck these in place using more masking tape. I then covered this in more papier mache.
Although I didn't consider it at the time, I think the final result would look better if the more detailed features like the beard and lips were built up using papier mache.
Add Comment
