Creative Switch: Faucet Lamp
121
Posted
Introduction: Creative Switch: Faucet Lamp
Use the handles of a faucet to dim LED's
Step 1: Things You Will Need
  • Faucet
  • 6 LED's
  • 2 #v Button Batteries
  • Electrical Tape
  • Wire
  • Wire Cutter
  • Wire Stripper
  • Solder
  • Solder Iron
  • 2 Potientiometera
    • Possible Supplies
      • Heat Shrink
      • Wax
Step 2: Tape Around the Edge of BatteryWith Electrical Tape
Also tape the inside of faucet where the battery will sit.
Step 3: Solder All the Anodes Sides of 3 LED's Together
Split the Led's up into groups of 3
Then solder all the anodes together
Step 4: Solder All the Cathode Sides of the Clump of LED's Together
Strip and solder a wire to the cathodes of the LED Clump
Step 5: Strip and Add Another Wire
Attach the second wire to the ground side of the button battrey using electric tape
Step 6: Solder the Other Two Ends of the Wires to a Potieniameter
Check to make sure LED's light up before soldering.
Step 7: Secure Anodes Legs of the LED's to the Positive Side of the Battery
Step 8: If Needed, Use Heat Shrink to Make the Potentiometer Handle Fit Into Faucet HAndle
Step 9: Repeat Steps on the Other Side of the Faucet
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    That's a unique switch idea!
