3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Creepy Cobweb Shooter!
Step 4How to Use it...
How to Use it...
Turn on your compressor and get around 30-50psi.
NOTE: Wear gloves because the hot glue can get on your skin and burn you.
While slowly opening the air valve on the assembly begin to slowly squeeze a tiny amount of hot glue out. It should start to spray in a steady stream. Move your hand around to spray the glue and form your cobweb. You can adjust the flow of both the air and the glue for different results. You've just made your own spiderweb glue gun! The glue will come off pretty easy as you can roll it up in a ball and remove it from whatever it was sprayed on. Have fun, be safe and Happy Halloween!
2 comments
Mar 11, 2009. 11:46 AMkristopheryee says:
holy crap. this is rad.
Oct 17, 2008. 12:22 PMpsuddeth says:
pretty cool. How does this compare to the rotary ones that use rubber cement , used in the film industry? obviously fewer fumes, but anything else?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2394
Author:Kipkay(Kipkay Videos)
Tinkerer, hackster and prankster. Hit me up on Facebook: http://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
