3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fake Glowing Plutonium
This was something I made to creep my house mates out with. It is a glowing Jar with a radiation sign on it. I left it in the cupboard once they were so confused.
What you need:
  • A glass spice jar
  • Access to a printer (to print a radiation label)
  • A cheap foam light stick (for raves)
  • UV reactive powder (I got mine from here)
  • UV LED
  • Spray mount glue (aerosol type)
  • A scaple or sharp knife
Simple Version: Will glow at a reduced brightness over a long period of time
  1. Spray the inside of the glass jar with glue
  2. Coat the inside of the jar with a mix of aqua blue and spooky green UV gowing powder and allow to dry.
  3. Print out the small radiation sign
  4. Stick the sign on the jar with some more, spray mount glue
  5. Finally place on your windowseal or under a desk lamp to charge up the powder.
And TA DA Your done, just switch off the lights and watch it glow for hours upon hours.
Visit my website : http://www.mywikid.info/
If you like it (even the slightest) please vote for it in the make it glow contest, and the halloween prop contest. Thank you guys; in advance.
More Complex: Gives a cool pulsing & throbing effect due to a UV led (Much Brighter)
  5. Remove the light module from the foam by cutting it out.
  6. Desolder the 3 LEDs.
  7. Replace the blue led with a UV LED, this is because the blue and UV LEDs have similar operating voltages.
  8. Place the newly made UV LED module in the top of the jar and screw the origanal jar lid on top of that.
  9. Finally turn the light module on You are done !!
7 comments
Oct 23, 2011. 9:44 AMkarlpinturr says:
Thanks - that much makes sense.
But I'm still concerned that you've removed 3 LED's, but only replaced 1 - didn't you have to solder in some jumper/bridging wires to keep the circuit complete?
Oct 23, 2011. 1:21 PMkarlpinturr says:
Sooo, the LED's are in parallel, and would flash simultaneously in the original foam stick?
Oct 22, 2011. 5:19 AMkarlpinturr says:
I'm confused...
Your foam stick has 3 LED's, which you remove and replace with just 1 UV LED - no jumper leads, or anything - and it still works..?
And if "it can keep glowing the entire night once the powder is charged up under a desk lamp", what's the LED actually for?
Oct 24, 2011. 3:26 AMkarlpinturr says:
Ah, NOW I understand - Thank you!
And I'm sorry to have been so insistent on such a small point.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:eXtremeSomething(My Wikid Info)
