3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Crib Modification for Accessibility
Step 19Receiver Hole for Locking Pin
Keeping the rail closed, mark through the hole in the angle bracket onto the mattress support panel. Move the rail out of the way, and drill a 1/2" hole through the mattress-support panel at the mark. This hole needs to be aligned with and parallel to the 1/4" hole in the angle bracket: you may want to drill a 1/4" hole first with the rail closed, passing the bit through the angle bracket, and enlarge it to 1/2" in a second pass.
Insert the aluminum spacer tube into the hole. It should fit tightly; if not, pull it out, apply a thin bead of epoxy around the end you insert first, and put it back in. If you use epoxy on the spacer, wait for it to dry completely before testing the locking pin.
« Previous Step   View All StepsNext Step »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
83
Author:kelseymh
I've been an experimental high-energy physicist for 20 years (since I started graduate school in 1988). I got my BS in physics from UCLA, my Ph.D. at Caltech, and did a post-doc at UBC before moving ...
more »
