Crimp Connector
1,732
Posted
Introduction: Crimp Connector
I would just like to explain how great I think Crimp Connector's can be when working on large (or even small) projects.
When you have a mess of wires running from one sensor or board to another, it can become frustrating when the stop working.  When they move back and forth the wired connections start to break and the solder doesn't connect the terminals anymore.  I have found it very useful to place crimp connectors on the ends of all the wires and the plug them into each board.  This keeps all your wire connection neat and organized, and strong and sturdy.
Folding the crimp on the wire can be tricky at times, but after doing it a few times you will get the hand of it.  The crimps i usually use have two spots where they fold down onto the wire.  The technique I've always followed (and had great success with) is placing the wire in far enough that the first fold goes over just the bare wire and the second fold goes over the rubber coating on the wire.  This ensures that the wire will stay firmly in the connector and prevents the metal of the wire from bending and breaking easily.
Once you have all your wires on the crimps you can place them into slots in a plug.  If you ever need to change a pin or switch a wire, the crimps can be removed from the slot and placed into another without having to re-do the crimp, so switching your circuit around becomes very easy. (Usually to remove the crimp consists of placing a small screw driver in a slot and pressing down on a pin.  You can see in the fourth image the pin coming down from the bottom  that would catch the edge of a slot)
I have a few images here showing how the connectors come in tons of different sizes and shapes to match almost any project requirements.  They are great and easy to use so I highly recommend trying them out.
    • Space Challenge
      Space Challenge
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    6 Comments
    I have a project at the moment that uses molex connectors and I am struggling to find a crimping tool that is made for such small crimps.
    Is it advisable to just go at it with another tool or should i try find this darn crimper??
    The crimp tools are nice if you know how to use them... Personally I've gotten used to just using pliers to do the job. It isn't the cleanest work but when you get the hang of it, it gets the job done...
    I'm considering using crimp connectors on an upcoming project and your post caught my eye. Thanks for the info!
    Thanks, I hope they help you out.
    I've found crimp connectors very useful on projects. They make it very easy to connect/disconnect entire sections/boards or just switch out a few wires if you need to make a pin change.
    Let me know how they work out for you.
    Buy a crimp tool, less than $10 if you know where to look
    Crimp tools can be handy, but you need to get the hang of them. Also, they can be bulky when you're working around different places. I'm constantly working on projects in different areas and get tired of carrying all my tools. I've gotten used to just using pliers and getting the job done.
