Introduction: Crimson Powder a Black Powder Substitute
Picture of Crimson Powder a Black Powder Substitute
Crimson powder is a pyrotechnic powder that can be used as a substitute for black powder that can be easily made from items you can buy at local stores.
Step 1: Obtain Materials
Picture of Obtain Materials
1.potassium nitrate:I got mine from spectricide stump remover that I found at Home Depot. 2.vitamin c tablets/caplets: can be purchased at any pharmacy 3.iron oxide: can be made or bought from paint suppliers. A cheap place to buy is baileypottery.com 4. An old skillet 5. A scale(accurate to a gram or less)
Step 2: Dissolving Vitamin C and Straining Out Cellulose Fibre
Picture of Dissolving Vitamin C and Straining Out Cellulose Fibre
For this step, to will need to get 11 crushed up 500mg tablet/caplets of vitamin c and dissolve them in 30 millileters of boiling water. After the vitamin c is dissolved, you need to filter it through a double layer of paper towel or coffee filter to get rid of the cellulose fibre. If you use paper towel, be sure to squeeze out all the fluid afterwards, because it has a tendency to absorb a lot of the vitamin c. Once you have filtered all the cellulose fibre out, store your vitamin c water in a small glass cup. You'll need this for later.
Step 3: Measuring Out Ingredients
Picture of Measuring Out Ingredients
Measure out potassium nitrate(stump remover) and iron oxide. Here are the amounts: 6.2grams potassium nitrate, .5 grams iron oxide.
Step 4: Time for Cooking.
Picture of Time for Cooking.
Pour the vitamin c water onto your skillet or wherever you are going to cook your crimson powder mix. Dump your iron oxide and pottasium nitrate into the water. Heat the pan to 300 degrees and stir constantly. When about the consistency of oatmeal, scrape off the pan and put your mixture into an aluminum cooking sheet covered with aluminum foil.
Step 5: Drying Your Mixture
Picture of Drying Your Mixture
Preheat your oven to 150 degrees and put your mixture in the oven for about an hour.
Step 6: Crushing Your Mixture Into a Powder
Picture of Crushing Your Mixture Into a Powder
For this step, you can either screen your dried mixture or just crush it up with mortar and pestle.
Step 7: Done!!!
Picture of Done!!!
You have just made your own crimson powder! Make sure you store it in an airtight container, because it is somewhat hydroscopic. Just don't use a glass or metal container.
witherman (author)2016-04-08
does this explode? I need it to explode so I can get rid of an ant hill.
bpetno (author)witherman2016-05-09
Yes, if you wrap it up in some electrical tape you can make a pretty nice cherry bomb and blow up some ant hills
going to detonate an ant hill.
bpetno (author)2013-09-16
If this stuff were to go off in a glass container, the flying shards of glass would be Wayyy more dangerous than the blast itself. Don't use metal, because it contains an explosion very well and it would be better for the crimson powder to go poof than to go boom if it were to go off. So just safety precautions. I would recommend a little plastic container for storage
pete.buckston (author)bpetno2015-03-24
Sorry, but you are wrong, plastic bags equal static charge, you would not get a static charge through glass. I personally keep materials like these in brown paper and stored in cardboard boxes.
pete.buckston (author)2015-03-24
just a quick tip that will save a LOT of time.....if you are wanting to make this don't buy vitamin C tablets, buy it as pure powdered vitamin C (pure ascorbic acid). It's available at all health food shops or online. I got mine from a Holland and Barret health food shop. Hope this is useful :-)
fancypants23 (author)2014-09-15
WILL TRY THIS!!!!
WastelandMan (author)2014-05-30
Great build! Just a happy suggestion, a well cleaned and washed prescription, or over the counter Pill Bottle makes a great container for these types of powders. :)
Air tight, water proof, and FREE!
kretzlord (author)2013-09-15
nice 'ible. The simplicity is pretty awesome
rimar2000 (author)2013-09-15
Interesting, but why "Just don't use a glass or metal container."?
About This Instructable
9,203views
107favorites
License:
Bio: I love engineering and playing soccer. I also play the violin. GO ZIPS. UA Commit Class of 2017
More by bpetno:DELTA TWISTER: A DIY 3D PRINTER ANYONE CAN MAKE (FOR LESS THEN 400 BUCKS)Crimson Powder a black powder substituteKnex robopong!!!
Add instructable to:
