Introduction: Crochet Dragon - Smaug From the Hobbit
While I was crocheting my dragon, I noticed that he started to look too cute, and Smaug the Chiefest and Greatest of Calamities is not cute. To make him look more fearsome I added some extreme elements (well extreme as far as crochet goes). I used red LEDs for the eyes and smoke and sparks rising from his nostrils.
Step 1: What You Will Need
- Yarn: yellow and two shades of red (the yarn for the spikes is weight class 4 and the primary red and yellow yarns are weight class 3 -though I'm guessing about the 3 since it is not listed on the package, it is slightly thinner than the other red)
- crochet hook (2.5mm)
- stitch marker
- fibrefill
- felt
- embroidery thread and needle
- glitter glue
- cotton ball
- LEDs: two red -I bought a bunch of different colour LEDs on eBay
- LED tealight - you can find these at a dollar store
- needle nose pliers
- conductive thread - I bought mine online at Soft Circuit, you can also get it at Spark Fun, Aniomagic, or if you live in Canada there is this place.
- optical fibres - I found a dollar store toy that had optical fibre ( you can also find some on eBay)
Step 2: Head and Ears
We will be crocheting in spirals so use a stitch marker to mark the rounds. For all body parts leave a long strand after you tie (fasten) off for stitching the pieces together.
Here is the nomenclature that I used (these are US stitches see link for conversion to UK):
Rnd round
ch(s) chain stitch(s)
sc single crochet
dc double crochet
hdc half double crochet
tc triple crochet
sl st slip stitch
st stitch
sc2tog decrease by crocheting 2 stitches together
Head
In the primary red coloured yarn crochet the head.
Rnd1: Ch 2, work 6 sc in first chain from hook (6st)
Rnd2: 2sc in each (12st)
Rnd3: 2sc in first and 6th, sc in rest (14st)
Rnd4: 2sc in first and 7th, sc in rest (16st)
Rnd5-10: Sc in each (16st)
Rnd11: 2sc in first 8, sc in rest (24)
Rnd12-14: Sc in each (24st)
Rnd15: Sc in next 6, skip next, sc next two, skip next, sc next two, skip next, sc in rest (21st)
Rnd16: Sc in next 4, skip next, sc next two, skip next, sc next two, skip next, sc in rest (18st)
Rnd17: Sc in each (18st)
Rnd18: Either sc2tog in first and 9, sc in rest (16st) if you don't plan to put any electronics into the head or Sc in each (18st) -16st looks better when you connect the head to the torso but it is too narrow to stuff the electronic components into the head.
Ears
In the primary red coloured yarn crochet the ears (make two).
Rnd1: Ch4
Rnd2: Sc in first 3, turn, ch1
Rnd3: Sc in first 2, 2sc in next, sc in rest, turn, ch 1
Rnd4: Sc in first, sc2tog next, sc next, turn,
Rnd5: Sc 2, tie off
If you are wondering the nostrils appear in step 9.
Step 3: Torso
Rnd1: Ch 17 sl st into first (16st)
Rnd2-5: Sc in each ch (16st)
Rnd6: Sc 7(R), 1 sc(Y), 8 sc (R) (16st)
Rnd7: Sc 7(R), 1 sc(Y), 8 sc (R) (16st)
Rnd8: Sc 7(R), 1 sc(Y), 2sc in next(Y), 7 sc (R) (17st)
Rnd9: Sc 6(R), 2sc in next(R), 4 sc(Y), 6 sc (R) (18st)
Rnd10: Sc 8(R), 3 sc(Y), 2sc in next(Y), 6 sc (R) (19st)
Rnd11: Sc 7(R), 2sc in next(R), 6 sc(Y), 5 sc (R) (20st)
Rnd12: Sc 9(R), 5 sc(Y), 2sc in next(Y), 5 sc (R) (21st)
Rnd13: 2sc in 5th red, red sc in rest of red, 2sc in 4th yellow, rest yellow sc in yellow sc,
2sc in 3rd red, rest red sc in red sc (24st)
Rnd14: 2sc in 5th red, red sc in rest of red, 2sc in 4th yellow, rest yellow sc in yellow sc,
2sc in 3rd red, rest red sc in red sc (28st)
Rnd15: 2sc in 6th red, red sc in rest of red, 2sc in 3rd and 7th yellow, rest yellow sc in yellow sc,
2sc in4th red, rest red sc in red sc (32st)
Rnd16-22: Red sc in red sc, yellow sc in yellow sc (32st)
Rnd23: Sc2tog first, rest red sc in red sc, yellow sc in yellow sc (31st)
Rnd24: Sc2tog in yellow, rest red sc in red sc, yellow sc in yellow sc (30st)
Rnd25: Sc2tog first, rest red sc in red sc, yellow sc in yellow sc (29st)
Rnd26: Sc2tog in yellow, rest red sc in red sc, yellow sc in yellow sc (28st)
Rnd27: Sc2tog first, rest red sc in red sc, yellow sc in yellow sc (27st)
Rnd28: Sc2tog in yellow, rest red sc in red sc, yellow sc in yellow sc (26st)
Rnd29: Sc2tog first, rest red sc in red sc, yellow sc in yellow sc (25st)
Rnd30: Sc2tog in yellow, rest red sc in red sc, yellow sc in yellow sc (24st)
Rnd31: One sc2tog in red, one sc2tog in yellow, rest red sc in red sc, yellow sc in yellow sc (22st)
Rnd32: One sc2tog in red, one sc2tog in yellow, rest red sc in red sc, yellow sc in yellow sc (20st)
Rnd33: One sc2tog in red, one sc2tog in yellow, rest red sc in red sc, yellow sc in yellow sc (18st)
Rnd34: Red sc in red sc, yellow sc in yellow sc (18st)
Rnd35: Red sc in all sc, tie off yellow (18st)
Rnd36: Sc2tog first, rest sc -all red, tie off (16st)
Step 4: Tail
With the primary red yarn crochet the tail:
Rnd2: Sc in each ch (16st)
Rnd3-4: Sc in each sc (16st)
Rnd5: Sc2tog in first sc, sc in rest around (15st)
Rnd6-8: Sc in each sc (15st)
Rnd9: Sc2tog in first sc, sc in rest around (14st)
Rnd10-12: Sc in each sc (14st)
Rnd13: Sc2tog in first sc, sc in rest around (13st)
Rnd14-15: Sc in each sc (13st)
Rnd16: Sc2tog in first sc, sc in rest around (12st)
Rnd17-18: Sc in each sc (12st)
Rnd19: Sc2tog in first sc, sc in rest around (11st)
Rnd20-21: Sc in each sc (11st)
Rnd22: Sc2tog in first and 5th sc, sc in rest around (9st)
Rnd23-24: Sc in each sc (9st)
Rnd25: Sc2tog in first and 4th sc, sc in rest around (7st)
Rnd26-27: Sc in each sc (7st)
Rnd28: Sc2tog in first sc, sc in rest around (6st)
Rnd29: Sc2tog in first sc, sc in rest around (5st)
Rnd30: Sc2tog in first sc, sc in rest around (4st)
Rnd31: Sc2tog in first sc, sc in rest around (3st)
Rnd32: Sc2tog in first sc, sc in rest around (2st)
Rnd33-38: Sc in each sc (2st)
Rnd39: Sc2tog in first sc (1st)
Rnd40-52: ch1
Tie off
For the fork at the end of the tail:
Ch 4 sl st in 4th chain from end on the tail then ch 4 tie off.
Step 5: Legs
Front legs
Rnd 1: Ch 2, work 6sc in first chain from hook
Rnd 2-5: Sc in each st around. (6st)
Rnd 6: 2sc in first, (sc2tog)x2, 2sc in next st (6st).
Rnd 7: 2sc in first, (sc2tog)x2, 2sc in next st (6st).
Rnd 8: 2sc in first, (sc2tog)x2, 2sc in next st (6st).
Rnd 9: 2sc in next st, (sc2tog)x2, 2 sc in next st (6st).
Rnd 10: 2sc in next st, sc in each of next 4 sts, 2 sc in next st (8 st)
Rnd 11: 2sc in next st, sc in each of next 6 sts, 2 sc in next st, tie off (10st)
Back Legs
Rnd 1: Ch 2, work 10sc in first chain from hook
Rnd 2-3: Sc in each st around (10st)
Rnd4: 2sc in first two sts, sc in next, sc2tog x2, sc in next, 2sc in next two (12st)
Rnd5: 2sc in next st, sc in next three, sc2tog x2, sc in next three, 2sc (12st)
Rnd6: 2sc in next st, sc in next three, sc2tog x2, sc in next three, 2sc (12st)
Rnd7: Sc in first 5, sc2tog, sc in next 5 (11st)
Rnd8: Sc in first 5, sc2tog, sc in next 4 (10st)
Rnd9: Sc2tog in first, sc in next two, Sc2tog in next, sc in next two (8st)
Rnd10: Sc2tog in remaining, tie off
Step 6: Wings
With the primary red colour crochet the wings(make 2).
Rnd1: Ch 30
Rnd2: Sc in each chain (skip the last) turn and ch1 (29st)
Rnd3: Sc in each sc, turn (28st)
Rnd4: Sc in each sc (skip the last) turn and ch1 (27st)
Rnd5: Sc in each sc, dc in last sc, turn (26st)
Rnd6: Sl st in first two sc, sc in each sc remaining, turn(23st)
Rnd7: Sc in each sc, turn ( 21st)
Rnd8: Sc in each sc, turn and ch1 ( 20st)
Rnd9: Sc in each chain, dc in last sc, turn (20st)
Rnd10: Sl st in first two sc, sc in each sc remaining, turn( 18st)
Rnd11: Sl st in first three sc, sc in each sc remaining, turn(15st)
Rnd12: Sl st in first four sc, sc in each sc, turn (10st)
Rnd13: Sc in each sc, turn (8st)
Rnd14: Sc in each sc ( 6st)
Rnd 15: Sl st in first three, dc, sl st 3, tie off(6st)
Step 7: Spikes
Starting on the neck of the torso:
Sc, sc, (sc, hdc, sc in one hole), sc , sc, (sc, hdc, sc in one hole), *sc, (hdc, dc, hdc in one hole), sc, repeat from * three times, **hdc, (dc, tc, dc in one hole), hdc, repeat from ** four times, #sc, (hdc, dc, hdc in one hole), sc, repeat from # two times. Tie off or if tail is already attached continue on below.
Starting from the widest part of the tail:
*Sc, (hdc, dc, hdc in one hole), sc, repeat from *six times, **sc, (sc, hdc, sc in one hole), sc, repeat from ** three times, sc, sc, (sc, hdc, sc in one hole), sc, sc, sc until row 32 of tail, then sl st until the end.
Step 8: Assembly
Step 9: Details
For the nostrils I single crochet 2 small half circles along the top front of the head with the primary red colour. I crocheted directly into the crochet holes on the head.
Starting at the Rnd1 hole of the head: make one sc, sc into the hole directly above in Rnd2, sc in same row one to the right, sl st one hole to the right, down one row . Repeat to the left.
Eyes
The LEDs did not look that great on there own for eyes so I glued some black felt around them.
Mouth
I stitched a mouth with brown embroidery thread and added two teeth on both sides of the face.
Belly
Smaug's belly is covered in gems so I covered it with glitter glue. Remember to leave the hollow of his left breast free. This is the weak spot in his armor that Bilbo discovered which ultimately led to his demise (oops -spoilers).
Step 10: LEDs
Step 11: Electronics
Step 12: Smoke
Fill the inside of the head with a bit of fiberfill, try not to disturb the circuit and sew the head onto the neck, leaving an opening underneath so that you can reach the on/off switch.
