This Instructable is intended to be followable for people that are new to crocheting.
The pictures should make it fairly easy.
These are made for sizes 6-8 shoe sizes, but can be adjusted without a lot of trouble.
What You Need:
A 364 yard spool of yarn.
A 3.75MM crocheting needle.
Something to cut yarn.
Remove these ads by
Signing UpStep 1: Toesies
Row 1
I chained 9 stitches. Depending on the size of your foot, you might want more or less. Have this chain reach from your pinky toe, to your middle toe.
Row 2
Now, I used a single stitch. At each of the ends use three stitches (shown in the picture) and keep going to make a continuous row (a full circle).
This will make an oval shape.
It's also how I tend to make the base of purses/bags because of the nice shape.
Row 3
You want to continue to make an oval. Add two stitches at what would be the corners of the oval (I recommend referring to the picture)
Row 4 - 5
Continue to add stitches on one side (this will be where your big toe will fit), as shown in the picture. On the other side, just continue a single stitch without adding.
This will make one side of the work keep increasing, and the other will curl in.
Row 6+
Your toes should fit now. You want to add to the work by continuing rows without adding anymore new stitches. I did this for 9 rows. Basically, I added until the toe part of the shoe covered a little more than a pair of flats would.
Penolopy Bulnick
says:
Nov 19, 2012. 10:06 AMReply
Not Nice
Visit Our Store »
Go Pro Today »
