Crochet Hook Organizer
Published
Introduction: Crochet Hook Organizer
About: It's just in my nature to make things rather than buy them. One, because I was raised watching my mom and dad building things. Two, I'm a recent college grad, which pretty much means poverty-stricken. A lo...
If you are like me, you are always in need of storage, especially storage for tools and craft supplies. After gawking at the prices for crochet hook rolls at the store, I decided to make my own using everyday items you can find at home.
WARNING: Machine sewing is definitely required for this project. You will most likely be sewing with thick material, so make sure the machine you are using can handle this!
Step 1: Materials
For this instructable, you will need:
*An old pair of pants or shorts with back pockets INTACT
*Matching thread
*A sewing machine
*Crochet hooks (to use as a sewing guide)
*Buttons (if not already supplied on the garment)
Step 2: Cutting Up
Take the pants, shorts, or skirt and cut off the legs, excess length, and front panels. Focusing on the back panel, cut around the back pockets, allowing as much space away from the pockets as possible. For a larger organizer, you can purchase a used pair of plus-size pants or shorts at your local thrift store.
I recommend using a zigzag stitch around the cut fabric edges. This will keep the fabric from fraying.
Step 3: Pocket Detail
Since the outer pockets will hold the crochet hooks, you will need to determine the sizes of your hooks so you can make slots that fit them.
I made small slots on one pocket to hold my small hooks, and larger slots on the other pocket for my big hooks.
Using chalk and/or sewing pins, mark the areas you plan to sew. After pinning, try sliding a crochet hook into the slots. They should slide in and out easily without falling out on their own.
Now for the sewing. If your pockets have pocket flaps, safety pin them up and out of the way. This will help a LOT while sewing!
Take your time sewing, especially if you have thick material to work with. To make sure the tops of the slot seams would last, I backstitched over them several times.
The picture below shows the backside of the pocket so you could see my stitching.
Step 4: Creating the Bag
Now that the slots are sewn, you can remove all remaining pins from your bag pieces.
Next, match the pockets right sides together and pin the sides and bottom. This will create the main bag.
Sew the sides and bottom, using a quarter inch seam allowance. I also zigzag-stitched around the edges a second time.
Turn inside out. If necessary, press edges with an iron.
OTHER OPTIONS
If your pockets have a buttonhole, you can add a funky button closure for your pocket.
You can also add a strap using leftover fabric.
    • Flowers Challenge
      Flowers Challenge
    • Slow Cooker Challenge
    2 Comments
    A couple inside pockets might be useful as well... I love this! Thanks!
    Not a bad idea! I still haven't put a lining inside mine, so there's still a chance for more lovely storage!
