Introduction: Crochet Locutus
Recently the two part episode of Star Trek the Next Generation called Best of Both Worlds was released on DVD. If you are a fan of Star Trek :TNG you would remember this episode as the one were Captain Picard is assimilated by the Borg and becomes Locutus. As I was watching these episodes I was inspired to make a crochet Locutus. My Locutus has a working laser on the side of his head and his arm prosthetic has a small motor that spins a claw (see video below).
Step 1: What You Will Need
Yarn weight 4:
Rnd round
ch(s) chain stitch(s)
sc single crochet
fp front post
hdc half double crochet
bp back post
sl st slip stitch
st(s) stitch(s)
sc2tog decrease by crocheting 2 stitches together
- Black
- Off-white colour
- Small amount of grey yarn or embroidery thread (for eyebrows)
- 2.25mm crochet hook
- Yarn needles
- 5mm doll eyes and small piece of grey felt
- Black felt
- Silver and gold metallic paint
- Black wire
- Glue
- Small laser pointer
- 3V (CR2016) and two 1.5V button battery (LR44H and LR1120)
- Black wire
- Battery holder
- Electric tooth brush (I used a Oral-B Cross Action)
- Needle nose pliers, soldering iron
Rnd round
sc single crochet
fp front post
bp back post
sl st slip stitch
st(s) stitch(s)
Step 2: His Head
Head
With off-white yarn.
Rnd 1: Magic Circle 6
Rnd 2: 2sc in each (12sts)
Rnd 3: 2sc in first sc, sc in next, repeat (18sts)
Rnd 4-8: sc in sc (18sts)
Rnd 9: sc2tog in first, sc in next, repeat (12sts). Stuff head.
Rnd 10: sc2tog in each
Fasten off. Leave tail.
Step 3: His Torso
Torso
With black yarn.
Rnd 3: 2sc in first, sc in next, repeat (18sts)
Rnd 4: 2sc in first, sc, sc, repeat (24sts)
Rnd 5-11: sc in sc (24sts)
Rnd 12: bpsc in each sc (24sts)
Rnd 13: sc2tog in first sc, sc, sc, sc, repeat (18sts)
Rnd 14 sc2tog in first sc, sc, sc, repeat (12sts). Stuff torso
Rnd 15: sc2tog in rest
Fasten off. Weave in ends.
With black yarn.
Step 4: His Arms
Arms:
First arm:
Start with off-white yarn and *switch to black.
Rnd 1: Magic Circle 4
Rnd 2: 2sc in sc (8sts)
Rnd 3-12: *change colour, sc in sc (8sts)
Stuff it. Fasten off. Leave tail.
If you don't want to make the prosthetic arm make two of the above.
Second arm:
With black.
Rnd 3-8: *change colour, sc in sc (8sts)
(you may need to adjust length to accomadate prosthetic arm)
First arm:
Second arm:
With black.
Step 5: Legs
Legs:
Using the black yarn, make two.
Rnd 2: 2sc in each (8sts)
Rnd 3-5: sc in sc (8sts)
Rnd 6: 4hdc in next 4sc, sc in sc in rest (8sts)
Rnd 7-18: sc in sc (8sts)
Step 6: Assemble
Sew each of the parts to the body. Head on top, feet on bottom etc. The shorter arm should be on the right side.
Step 7: Face
Nose
chs 2
Rnd 1: 2sc in 2nd ch(s) from hook
Attach the nose to his face and add the doll eyes. I thought the 5mm eyes were a bit small for the head so I used two circles of grey felt under the plastic eyes. Use the grey yarn to stitch eyebrows above the eyes.
chs 2
Step 8: Armor
I used some images I found on Google to determine what his armor looks like. I cut out the pieces from black felt and painted them with silver metallic craft paint. For the abdominal armor I embroidered lines with black thread to imitate abdominal muscles.
Step 9: Borg Prosthetic Arm
To make the Borg arm I needed a small dc motor. I took the motor from an Oral-B toothbrush (here is some instructions on how to get the motor unit out:https://www.instructables.com/id/How-to-Make-a-Better-Bristlebot/ ). I extracted the whole unit from the toothbrush which includes the switch motor and battery holder. I modified the battery holder from an AAA to hold a small button/cell battery. I then painted the unit black. I attached two small metal pieces (to form a claw) with Super Glue to the spinning part of the motor. I then stuffed the battery end of the unit into the crochet arm leaving the switch accessible.
Step 10: Head Piece
For the head piece I layered two pieces of felt and added some silver metallic paint around the edge. I attached two loops of black wire by sticking the ends into the felt and gluing them in place. I painted the hot glue gold then sewed the piece onto the side of his head. I also sewed another small piece of felt to the other side of his head.
Step 11: Laser
I used a small laser pointer cat toy which can be found at a dollar store. Caitlinsdad has some great instructions on how to extract the laser module in step 2 of this instructable :https://www.instructables.com/id/Star-Trek-USS-Enterprise-Phaser-Red-Shirt/. I extracted my laser module leaving the switch intact). I connect it to the battery holder with black wires long enough to stretch from his head to his pants. I solder the wires in place. The laser requires 4.5v to operate so I used a 3v CR2016 and a LR1120. I was able to fit both into the battery holder (one on top of the other). I stuffed the battery holder into his pant armor and sewed the felt around it to keep it in place. I then sewed the laser to the head (looping the thread around the laser module).
To finish off I added some more armor pieces to the arms and shoulders and added black wire around the arms and legs.
