Crochet: Magic Ring (Adjustable Ring for Amigurumi)
 by canucksgirl
Featured
The Magic Ring (or Adjustable Ring) is used when crocheting in rounds, and should be used for Amigurumi projects. The advantages of using the Magic Ring, is that once tightened, it leaves no hole in the center of your work. It replaces the step of "Ch 2 and single crochet x in the 2nd chain from the hook", which is the first step in many crochet projects.
If you refer to the main photo, you will see the old method in green, and the Magic Ring in blue.
(Notice there's no hole in the middle of the Magic Ring).
To make the Magic Ring continue on to the next step.
For more crochet instructions, how to read patterns, choose tools & materials, and make a variety of stitches, read my Instructable on How to Crochet: Amigurumi Basics
Step 1: Making The Magic Ring: Steps 1 - 4
To make the Magic Ring, refer to the photos.
Step 1: Begin by wrapping the yarn around your fingers, like shown.
Step 2: Put your crochet hook through the center of the loops, like shown.
Step 3: Pull the yarn (that comes from the ball) through the center of the loops, like shown.
Step 4: Hook the yarn (that comes from the ball), like shown, and pull the yarn through the loop on the crochet hook.
The start of the Magic Ring should now look like Photo 2.
Proceed to the next step.
craftpro says: May 17, 2013. 3:05 PM
Ooooh thanks so much it just clicked in my mind how to do it! Thanks so much!!
cluelessrebel76 says: Apr 9, 2013. 7:48 AM
Thank you for this! My mom taught me the basics of crocheting and helps when I get stuck, but doesn't know how to do a magic ring. I'm new to the amigurumi and was O lost on how to do the magic ring. I have a new project I want to start today that calls for the magic ring and I'm going to try your instructions. :)
Instructablonian says: May 13, 2012. 4:55 PM
I'm confused... Could you post a video????? It would totally help! Thanks!!! :P
sunshiine in reply to InstructablonianJun 16, 2012. 10:40 AM
sunshiine in reply to sunshiineJun 16, 2012. 10:41 AM
I found this link that might help. Hope it does!
canucksgirl (author) in reply to sunshiineJun 17, 2012. 1:16 PM
Thanks sunshiine. That looks like it should help Instructablonian.
sunshiine in reply to canucksgirlJun 17, 2012. 1:27 PM
Your welcome! I hope it does help!
canucksgirl (author) in reply to InstructablonianMay 14, 2012. 10:03 AM
Unfortunately, I don't have a video handy.
What you want to do is wrap the thread around your fingers (like shown in step 1) to make a large loop. Then insert your hook into the center of the large loop of yarn and pull the thread through, and then take the thread from the top and pull it through the yarn on your hook. Essentially, you are making a slip knot with the thread wrapped around your fingers.
The next step is to make a traditional single crochet as many times as your pattern indicates. Normally, a single crochet is done in a stitch. Consider the yarn looped around your fingers as one BIG stitch. On step 2 the images show you how to single crochet. When you've completed the number of single crochets as your pattern indicates, you'll have what looks like the image in step 3. Note that the single crochet stitches were done around the loop of yarn (that was on your fingers).
At this point, the only thing you need to do is grab the short yarn end and pull. It "magically" pulls your single crochets into a closed ring, and the center hole pretty much disappears. The advantage to that is when you're done your project, you don't have this unsightly hole.
If you still need help, please let me know.
Also, refer to my Instructable on How to Crochet: Amigurumi Basics.
dylanrichards says: Apr 12, 2012. 7:48 AM
oooooooo
canucksgirl (author) in reply to dylanrichardsApr 12, 2012. 9:19 PM
aaaaaaah. :)
enuscher says: Apr 11, 2012. 5:55 PM
Hmm, that's definitely one way to do it. I've been crocheting amigurumi for such a long time that magic rings became so natural to me, I can never explain how to do it to someone else! :P
canucksgirl (author) in reply to enuscherApr 11, 2012. 6:25 PM
I know what you mean. Doing something isn't always the same thing as trying to show someone how. It took me a while to do it, but it seemed needed. (I couldn't find one done here yet).
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
