Pac-Man and his ghosts!  This started as a project to just crochet Pac-Man.  Then this expanded to making the ghosts, then to making the ghosts with movable eyes, and lastly to adding in covers to make the ghosts switch to dark blue.  I am most pleased with how the ghosts turned out.  Hope you enjoy!
Supplies:
  • Yarn (Yellow, Light Pink, Red, darker yellowish tan, turquoise blue, dark blue, black)
  • Crochet Hook Size G/6 4.25mm
  • Plastic Canvas Needle
  • Brads (Brass Fasteners) (8)
  • Black and White Felt
  • White Thread
  • Sewing Needle
  • Good Scissors
  • Hot Glue Gun
  • Button (optional for tracing)
Step 1: Making Pac-Man
Pac-Man is really simple.  The main body is Yellow and his mouth is Black.
Body: (in Yellow)
  1. Magic Ring 5, ch 1, turn (I tried to do this with just chaining 2 and then crocheting 5 sc. into the second st. from the end, but this caused a big hole to show so I think a magic ring works better because it makes the stitches tighter)
  2. Skip first st., Inc across (10) ch. 1, turn
  3. Skip first st., [Sc. in next st., inc. in next] Repeat (15) ch. 1, turn
  4. Skip first st., [Sc. in next 2 sts., inc. in next] Repeat (20) ch. 1, turn
  5. Skip first st., [Sc. in next 3 sts., inc. in next] Repeat (25) ch. 1, turn
  6. Skip first st., [Sc. in next 4 sts., inc. in next] Repeat (30) ch. 1, turn
  7. Skip first st., [Sc. in next 5 sts., inc. in next] Repeat (35) ch. 1, turn
  8. Skip first st., [Sc. in next 6 sts., inc. in next] Repeat (40) ch. 1, turn
  9. Skip first st., [Sc. in next 7 sts., inc. in next] Repeat (45) ch. 1, turn (It might help later to keep a marker here)
  10. Sc. across (45) ch. 1, turn
  11. Sc. across (45) ch. 1, turn
  12. Sc. across (45) ch. 1, turn
  13. Sc. across (45) ch. 1, turn
  14. Sc. across (45) ch. 1, turn
  15. Sc. across (45) ch. 1, turn
  16. Sc. across (45) ch. 1, turn
  17. Sc. across (45) ch. 1, turn (It might help later to keep a marker here)
  18. Skip first st., [sc. in next 7 sts., dec.] Repeat (40) ch. 1, turn
  19. Skip first st., [sc. in next 6 sts., dec.] Repeat (35) ch. 1, turn
  20. Skip first st., [sc. in next 5 sts., dec.] Repeat (30) ch. 1, turn
  21. Skip first st., [sc. in next 4 sts., dec.] Repeat (25) ch. 1, turn
  22. Skip first st., [sc. in next 3 sts., dec.] Repeat (20) ch. 1, turn
  23. Skip first st., [sc. in next 2 sts., dec.] Repeat (15) ch. 1, turn
  24. Skip first st., [sc. in next st., dec.] Repeat (10) ch. 1, turn
  25. Skip first st., dec. (5) slip stitch closed and tie off
Mouth: (in Black)
  1. Chain 8, turn
  2. Sc. across (7) ch. 1, turn
  3. Sc. across (7) ch. 1, turn
  4. Sc. across (7) ch. 1, turn
  5. Sc. across (7) ch. 1, turn
  6. Sc. across (7) ch. 1, turn
  7. Sc. across (7) ch. 1, turn
  8. Sc. across (7) ch. 1, turn
  9. Sc. across (7) ch. 1, turn
  10. Sc. across (7) ch. 1, turn
  11. Sc. across (7) ch. 1, turn
  12. Sc. across (7) ch. 1, turn
  13. Sc. across (7) ch. 1, turn
  14. Sc. across (7) ch. 1, turn
  15. Sc. across (7) ch. 1, turn
  16. Sc. across (7) ch. 1, turn
  17. Sc. across (7) ch. 1, turn
  18. Sc. across (7) ch. 1, turn
  19. Sc. across (7), tie off
You will have to decide how long the mouth piece needs to be based on how big your Pac-Man's body ends up being.
To attach the mouth on the body, start at one corner of the black piece and one corner of Pac Man's mouth.  I single crocheted around with yellow yarn.  If you marked where you stopped increasing and started decreasing you should be able to match up the corners of the black piece easily to the corners of his mouth.  To make it easier and make sure the piece attaches evenly, use paperclips to hold the mouth to his body.  It will look like he has many lip piercings.
I put in some stuffing when I started to make it easier to grab him and then finished stuffing him before I finished crocheting him up.
cheshire54 says: May 26, 2013. 9:57 AM
My daughter would LOVE to have these but doesn't know how to crochet. I can get her going, but she wants to know how to change pattern to create the ghosts too???
Penolopy Bulnick (author) in reply to cheshire54May 26, 2013. 10:08 AM
Yeah, I have the pattern for the ghosts in there too! Make sure you click view all at the top of the page and you can see all the steps. I show how to make the ghosts in Step 2 and the Blue Ghosts cover in Step 4 :)
mtorres26 says: May 16, 2013. 2:01 AM
I want to make this:)
Penolopy Bulnick (author) in reply to mtorres26May 26, 2013. 10:05 AM
I hope you do!
twinkleshine says: Feb 8, 2013. 9:28 AM
really cute!
Penolopy Bulnick (author) in reply to twinkleshineMay 26, 2013. 10:05 AM
Manderson1091 says: Nov 29, 2012. 5:12 PM
I've almost finished Pac Man! I can't wait to give the finished project to my brother for Christmas. :D
Your instructions are so easy to follow! This is the first crochet design I've been able to work from. Thank you!
Penolopy Bulnick (author) in reply to Manderson1091Nov 30, 2012. 12:38 PM
That's awesome! I'd love to see how it turns out! It's nice to know my directions aren't too hard to follow :) Be sure to let me know if you run into anything that doesn't make sense!
navyfamily4 says: Jun 1, 2012. 6:05 PM
love it so wish I could crotchet.
Penolopy Bulnick (author) in reply to navyfamily4Jun 1, 2012. 12:12 PM
Thank you! It's not too hard. When I first started trying to crochet I just used one of those teach yourself to crochet books, and just keep doing it over and over again. And to learn the magic ring, which I can do better than normal straight crocheting, I actually watched this video :)
Good Luck :)
yamayka says: May 20, 2012. 1:17 PM
Sooooo cute!
Penolopy Bulnick (author) in reply to yamaykaJun 1, 2012. 12:09 PM
Thank you :)
alexsmaue says: May 16, 2012. 6:21 PM
Adorable!
Penolopy Bulnick (author) in reply to alexsmaueMay 18, 2012. 12:11 PM
Thanks!
dollarcraft says: May 15, 2012. 2:55 PM
These guys are adorable!
Penolopy Bulnick (author) in reply to dollarcraftMay 18, 2012. 12:11 PM
Thanks! They are so cute to look at :)
Englee says: May 2, 2012. 3:56 PM
sweet
Penolopy Bulnick (author) in reply to EngleeMay 18, 2012. 12:11 PM
Thanks!
wold630 says: Apr 24, 2012. 5:32 PM
I really really wish I knew how to read a crochet pattern. I want those!!
emilyvanleemput in reply to wold630May 15, 2012. 9:29 PM
try this: http://www.instructables.com/id/how-to-read-a-crochet-pattern/
Penolopy Bulnick (author) in reply to wold630Apr 25, 2012. 4:08 PM
It's not too hard. I tried to write it out how I think others are written out. Let me know if there is something I can do to make it more clear!
Jetpack5 says: Apr 27, 2012. 5:48 PM
So cute!
Penolopy Bulnick (author) in reply to Jetpack5Apr 30, 2012. 3:02 PM
Thanks!
ATatteredCanvas says: Apr 26, 2012. 10:30 AM
Adorable!!!!!
Penolopy Bulnick (author) in reply to ATatteredCanvasApr 26, 2012. 11:39 AM
SHIFT! says: Apr 25, 2012. 3:38 PM
OMG, Something this adorable should not exist! The internet will implode in of itself!
Penolopy Bulnick (author) in reply to SHIFT!Apr 25, 2012. 4:08 PM
You are too kind :)
SHIFT! in reply to Penolopy BulnickApr 25, 2012. 5:15 PM
Any way I might be able to coerce a Crocheted Kirby out of you?
lmnopeas says: Apr 24, 2012. 3:25 PM
Awesome!
Penolopy Bulnick (author) in reply to lmnopeasApr 24, 2012. 4:06 PM
Thanks!
BIOhazard_inc says: Apr 24, 2012. 2:04 PM
amazing
Penolopy Bulnick (author) in reply to BIOhazard_incApr 24, 2012. 2:12 PM
Thanks!
mikeasaurus says: Apr 23, 2012. 9:47 PM
Movable eyes, blue covers, and the whole gang?! What a great project!
Penolopy Bulnick (author) in reply to mikeasaurusApr 24, 2012. 2:11 PM
And now the gang is hanging out on my desk with Mega Man!
DeandrasCrafts says: Apr 23, 2012. 9:23 PM
The moveable eye is genius! Love, love, love it!
Penolopy Bulnick (author) in reply to DeandrasCraftsApr 24, 2012. 2:11 PM
Thank you! I love that it was so simple to do too!
Atlas Portal 2 says: Apr 23, 2012. 8:20 PM
I love pac-man so much I couldn't help but to vote very good job
Penolopy Bulnick (author) in reply to Atlas Portal 2Apr 23, 2012. 9:07 PM
Thank you!
jessyratfink says: Apr 23, 2012. 7:32 PM
Yay! They're perfect.
Penolopy Bulnick (author) in reply to jessyratfinkApr 23, 2012. 9:06 PM
Thanks :D
allisontendo says: Apr 23, 2012. 7:15 PM
Oh my gosh! These are SO Adorable!!!
The movable eyes are such a clever idea!
Penolopy Bulnick (author) in reply to allisontendoApr 23, 2012. 9:06 PM
Thanks! I just couldn't decide which way to make their eyes face, and now I don't have to decide!
Riley Planalp says: Apr 23, 2012. 6:57 PM
Om nom nom nom nom!
Penolopy Bulnick (author) in reply to Riley PlanalpApr 23, 2012. 9:06 PM
Nom, nom, nom, nom, nom....
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
